Old 10-01-2001, 06:06 PM   #1
RallyNavvie
Member#: 7113
2008 Spec B
Exclamation have a bad MAF? important tip...
For those of you with turbos on your MY99 and your MAF seems to be going rather often you may want to try this trick I found on my car to bypass or fix the problem. My set-up includes an AFC so that may have something to do with it. My MAF went after only 3000 miles after I bought it, then only 300 miles, and then 3 miles. Wierd huh? Actually it was very frustrating, but this is something I found out about how to make it work again without throwing another $300 MAF at it again and again.
Whenever the MAF "fails" (it happens randomly on my car, seriously) I pull the connector to the MAF and run it in limp mode for a while (anywhere from 50-100 miles), When I get to place where I have a friend handy I start the car in limp mode, let it warm up for a minute or two (more in colder conditions, I actually wait until I see the A/F meter starts showing the engine doing closed-loop operation) and then rev the engine up to ~2000rpm and have my friend plug the connector back in. The engine doesn't die like if I try to restart after the MAF "fails" but stutters when the MAF is reconnected and then runs fine. I then rev it up past 3500 a few times and then let it idle for about 5 minutes. After that the car runs fine until the MAF randomly "fails" again. I'm not really sure if this has to do with the MAF or not or the AFC. But after reconnecting the MAF the ECU is getting a signal and runs fine (or as fine as it normally does).
So before you throw that MAF out give this a try. It won't hurt anything running in limp mode for a short period of time, although it may after repeated occurences. Just a helpful hint.
~Garrett
RallyNavvie is offline   Reply With Quote
Old 10-02-2001, 12:28 AM   #2
Delicious Tuning
Member#: 1990
I am wondering if you have a bad connection to your MAF? I had a loose wire attached to my MAF once and it caused my MAF to fail. But itreally didn't fail, it was the fact that the connection was bad. Anyway i fixed the connection and that seems to have the solved the problem. Just something ot look into. Also make sure all your ground are connected well, that was another issuse i had form time to time.
Delicious Tuning is offline   Reply With Quote
Old 10-02-2001, 08:58 AM   #3
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
that sounds like an electrical or computer problem....plug it into an OBD scan tool and see what pops up...
STiShawn is offline   Reply With Quote
Wagon roof spoiler removal - important tip PartsDept Interior & Exterior Modification 20 11-16-2014 02:51 PM
bad coil pack and bad maf meter symptoms Ysidro Newbies & FAQs 5 05-10-2009 10:57 PM
What is the best way recalibrate MAF & tip-in? 69_Lex AccessPort 1 11-08-2006 08:43 AM
very important tip nhluhr Mid Atlantic Impreza Club -- MAIC 17 11-06-2003 01:45 PM
98 Impreza : Kartboy/K&N Intake Problems : Bad MAF? XeviousR Normally Aspirated Powertrain 8 09-09-2001 01:18 AM
