Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-01-2006, 01:50 PM   #1
njskatchmo
Member#: 94618
2002 Bugeye
Default Need some map for this setup
My friend has a car that is runnign so rich that it's not driveable. I need a UTEC map for this set up or ANYTHIGN SIMILAR just so it's driveable. It is currently on stg 2 maps so just anythign similar will be great. Keep in mind it will be driven to the tuning shop as soon as we get somethign to just drive it on. We won't be using boost so whatever you give is good.
small 16g pnp ,Injen FMIC, Pink injectors, Fuel Pump, Turbo Inlet hose, APS ram intake, Catless uppipe and Helix down pipe w/ HKS ti muffler,
njskatchmo is offline   Reply With Quote
Old 04-01-2006, 08:17 PM   #2
TurbojonLS
Member#: 38772
2 Cars, No Bling
Regular Stage 4 map.
TurbojonLS is offline   Reply With Quote
Old 04-02-2006, 12:10 AM   #3
njskatchmo
Member#: 94618
2002 Bugeye
nooone has a 16g map?
Old 04-02-2006, 12:11 AM   #4
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
That friend ! Bump for 2 good guys!
Chandy69 is offline   Reply With Quote
Old 04-02-2006, 12:17 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the stage 4 base is rich on purpose.
don't forget the parameter files need to
be updated also.
Old 04-02-2006, 12:20 AM   #6
Chandy69
Member#: 16087
02 WRX
Think it will be cool to drive on it for say few hours to a tune shop?
Old 04-02-2006, 12:27 AM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
it will run rich, but we already know that.
how far to the dyno?
just put-put to the shop..
Old 04-02-2006, 12:29 AM   #8
njskatchmo
Member#: 94618
2002 Bugeye
far, thats why we are looking for a reasonable 16g map.
Old 04-02-2006, 12:31 AM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
far...please elaborate..a number of miles..
Old 04-02-2006, 05:56 AM   #10
njskatchmo
Member#: 94618
2002 Bugeye
Old 04-04-2006, 12:18 AM   #11
njskatchmo
Member#: 94618
2002 Bugeye
anyone have a 16g map?
Old 04-04-2006, 12:16 PM   #12
TurbojonLS
Member#: 38772
2 Cars, No Bling
You're making this into a much bigger deal than it needs to be - just use the regular Stage 4 map. Load up the map, edit the parameters to account for your injector size, and drive away. The car should be in closed loop the entire time, so the stock ECU will be adjusting to make sure you're getting a good amount of fuel. Plus you shouldn't be going all out WOT anyway. And its not like there's that much difference between a 16g & a VF30, and when you're off boost, they're the same.
Old 04-04-2006, 01:39 PM   #13
Division By Zero
Member#: 7555
You willl have NO problem with the stage 4 map and driving it. Just be light on the throttle and don't get into much boost ~5psi - even if you do it will probably just dump rich and stumble. It's got low timing so no worries. That 16G is a stg4 set up FWIW. Afterall, this is to get the car through the time from now until the actual tune.
Division By Zero is offline   Reply With Quote
Old 04-04-2006, 09:28 PM   #14
njskatchmo
Member#: 94618
2002 Bugeye
how do i edit the parameters for the injector size. He has pinks. so what change would this be. Sorry I'm new to the utec.
Old 04-05-2006, 10:52 AM   #15
Division By Zero
Member#: 7555
Once in the UTEC maps area you need to select the "Parameters" section. The select "Open Loop Fueling". Then input the "Scaled injector size". I would say to 550 to 560. Back out of that screen and then make sure you save it.
Old 04-08-2006, 05:46 PM   #16
njskatchmo
Member#: 94618
2002 Bugeye
I cant find the injector Size section in the parameters, I uploaded the map without the parameters but it sounds like it is still misfiring. I cant directly upload the map because the utec is on version 3.1 and the map is for 5.0 should i update the utec
Old 04-08-2006, 06:11 PM   #17
TurbojonLS
Member#: 38772
2 Cars, No Bling
Yes, upload the latest version.
Old 04-08-2006, 07:51 PM   #18
njskatchmo
Member#: 94618
2002 Bugeye
I updated, and put the stage 4 map with the stage 4 parameters, Still ran rich and heard audible misfires. Here are the logs.
1399 000 -10.6 00 ECU. 14.7 00000
1415 000 -10.6 00 ECU. 14.9 00000
1397 000 -10.6 00 ECU. 14.5 00000
1387 000 -10.6 00 ECU. 14.3 00000
1390 000 -10.6 00 ECU. 14.5 00000
1397 000 -10.6 00 ECU. 14.7 00000
1381 000 -10.6 00 ECU. 14.8 00000
1358 000 -10.6 00 ECU. 15.1 00000
1352 000 -10.6 00 ECU. 14.9 00000
1367 000 -10.6 00 ECU. 15.4 00000
1405 000 -10.4 00 ECU. 15.1 00000
1411 000 -10.4 00 ECU. 14.8 00000
1396 000 -10.4 00 ECU. 14.7 00000
1411 000 -10.4 00 ECU. 14.6 00000
1410 000 -10.6 00 ECU. 14.7 00000
1429 000 -10.6 00 ECU. 14.6 00000
1427 000 -10.6 00 ECU. 14.3 00000
1430 000 -10.6 00 ECU. 14.0 00000
1404 000 -10.8 00 ECU. 14.3 00000
1403 000 -10.8 00 ECU. 14.6 00000
1397 000 -10.8 00 ECU. 14.8 00000
1379 000 -10.8 00 ECU. 14.8 00000
1380 000 -11.0 00 ECU. 14.8 00000
1325 000 -11.0 00 ECU. 14.9 00000
1348 000 -11.0 00 ECU. 15.0 00000
1348 000 -10.8 00 ECU. 15.1 00000
1373 000 -10.6 00 ECU. 15.2 00000
1377 000 -10.6 00 ECU. 15.2 00000
1383 000 -10.4 00 ECU. 15.2 00000
1386 000 -10.4 00 ECU. 15.6 00000
1423 000 -10.2 00 ECU. 14.9 00000
1433 000 -10.2 00 ECU. 14.2 00000
1438 000 -10.4 00 ECU. 13.8 00000
1432 000 -10.4 00 ECU. 13.9 00000
1406 000 -10.6 00 ECU. 14.3 00000
1392 000 -10.6 00 ECU. 14.3 00000
1373 000 -10.6 00 ECU. 14.8 00000
1365 000 -10.6 00 ECU. 12.5 00000
1356 000 -10.6 00 ECU. 14.8 00000
1361 000 -10.6 00 ECU. 14.8 00000
1360 000 -10.6 00 ECU. 14.9 00000
1342 000 -10.6 00 ECU. 15.0 00000
1379 000 -10.4 00 ECU. 15.3 00000
1372 000 -10.4 00 ECU. 15.4 00000
1409 000 -10.4 00 ECU. 15.4 00000
1397 000 -10.4 00 ECU. 14.6 00000
1392 000 -10.4 00 ECU. 14.5 00000
1388 000 -10.4 00 ECU. 14.2 00000
1404 000 -10.4 00 ECU. 14.3 00000
1170 000 -10.4 00 ECU. 17.0 00000
0937 000 -10.0 00 ECU. 16.8 00000
0706 000 -9.4 00 ECU. 21.1 00000
0507 000 -8.1 00 ECU. rich 00000
0399 000 -6.5 00 ECU. rich 00000
0000 000 -4.7 00 ECU. rich 00000
0000 000 -3.0 00 ECU. rich 00000
0000 000 -1.8 00 ECU. rich 00000
0000 000 -1.0 00 ECU. rich 00000
UUUUUHOME MENUTURBOXS UTEC (Version 5.0) (c) 2005 Key : Function------------------------------------------------------------e or E : Edit Maps (Caps lock must be OFF)d or D : Dashboardl or L : Logger1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format)r or R : Replay Last 25 Seconds of Data (Logger 1) UUUUUHOME MENUTURBOXS UTEC (Version 5.0) (c) 2005 Key : Function------------------------------------------------------------e or E : Edit Maps (Caps lock must be OFF)d or D : Dashboardl or L : Logger1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format)r or R : Replay Last 25 Seconds of Data (Logger 1)LOGGERTURBOXS UTEC (Version 5.0) (c) 2005To log this data use the 'CAPTURE' function in HyperTerminal(tm) <CTRL-x> : Exit to Main <p> : Pause <s> : Start <space> : Toggle   RPM TPS MAP MLP MOD AFR KNOCK  % psia IGN COUNT 1367 000 -7.7 00 ECU. 14.7 00000
1377 000 -7.7 00 ECU. 14.7 00000
1371 000 -7.7 00 ECU. 14.7 00000
1363 000 -7.7 00 ECU. 14.7 00000
1383 000 -7.7 00 ECU. 14.6 00000
1393 000 -7.7 00 ECU. 14.6 00000
1402 000 -7.9 00 ECU. 14.6 00000
1436 000 -7.9 00 ECU. 14.6 00000
1403 000 -7.9 00 ECU. 14.5 00000
1417 000 -8.1 00 ECU. 14.5 00000
1408 000 -8.1 00 ECU. 14.4 00000
1443 000 -8.1 00 ECU. 14.4 00000
1418 000 -8.1 00 ECU. 14.3 00000
1397 000 -8.3 00 ECU. 14.2 00000
1398 000 -8.3 00 ECU. 14.2 00000
1405 000 -8.3 00 ECU. 14.1 00000
1433 000 -8.3 00 ECU. 14.1 00000
1443 000 -8.3 00 ECU. 14.0 00000
1408 000 -8.5 00 ECU. 13.9 00000
1418 000 -8.5 00 ECU. 13.8 00000
1425 000 -8.5 00 ECU. 13.8 00000
1428 000 -8.5 00 ECU. 13.6 00000
1417 000 -8.7 00 ECU. 13.5 00000
1456 000 -8.7 00 ECU. 13.4 00000
1395 000 -8.7 00 ECU. 13.3 00000
1437 000 -8.9 00 ECU. 13.1 00000
1432 000 -8.9 00 ECU. 13.1 00000
1446 000 -9.1 00 ECU. 12.9 00000
1448 000 -9.1 00 ECU. 12.8 00000
1425 000 -9.1 00 ECU. 12.6 00000
1460 000 -9.1 00 ECU. 12.5 00000
1433 000 -9.1 00 ECU. 12.5 00000
1472 000 -9.4 00 ECU. 12.2 00000
1440 000 -9.4 00 ECU. 12.1 00000
1446 000 -9.4 00 ECU. rich 00000
1459 000 -9.6 00 ECU. rich 00000
1436 000 -9.6 00 ECU. rich 00000
1463 000 -9.8 00 ECU. rich 00000
1443 000 -9.8 00 ECU. rich 00000
1466 000 -9.8 00 ECU. rich 00000
1443 000 -10.0 00 ECU. rich 00000
1434 000 -10.0 00 ECU. rich 00000
1460 000 -10.0 00 ECU. rich 00000
1478 000 -10.2 00 ECU. rich 00000
1500 000 -10.2 00 ECU. rich 00000
1486 000 -10.4 00 ECU. rich 00000
1490 000 -10.4 00 ECU. rich 00000
1486 000 -10.6 00 ECU. rich 00000
1483 000 -10.8 00 ECU. rich 00000
1475 000 -10.8 00 ECU. rich 00000
1460 000 -10.8 00 ECU. rich 00000
1454 000 -11.0 00 ECU. rich 00000
1445 000 -11.2 00 ECU. rich 00000
1443 000 -11.2 00 ECU. rich 00000
1432 000 -11.4 00 ECU. rich 00000
1417 000 -11.4 00 ECU. rich 00000
1415 000 -11.4 00 ECU. rich 00000
1396 000 -11.4 00 ECU. rich 00000
1372 000 -11.4 00 ECU. rich 00000
1361 000 -11.4 00 ECU. rich 00000
1340 000 -11.4 00 ECU. rich 00000
1274 000 -11.6 00 ECU. rich 00000
I turned the car off the first round and thats where it went rich and then i turned it back and now you can see the effects. Any ideas I changed the injectors to 550 and used teh stage 4 map w/ stage 4 parameters
Old 04-09-2006, 12:32 PM   #19
TurbojonLS
Member#: 38772
2 Cars, No Bling
Which injector size did you change to 550? It should have only been the 2nd set - the other should still stay 440.
Another thing to do is go into the 0 colum & start taking out fuel. Either that or have someone who's used to UTEC look at it.
Old 04-09-2006, 02:02 PM   #20
ejsportcom
Member#: 88905
i think the stage 4 map parameters has the injector size already inserted in it(for pinks that is). njskatchmo your in bergen county? cause i am also so i could always give you a hand getting it drivable if you need. I've tuned my own car with the utec quite a few times. PM me if your still having trouble....
ejsportcom is offline   Reply With Quote
Old 04-09-2006, 02:02 PM   #21
njskatchmo
Member#: 94618
2002 Bugeye
the second set is "stock injector size" - i should change that and not the other?
Old 04-09-2006, 02:14 PM   #22
ejsportcom
Member#: 88905
you pm box is full btw... whats your name again? sry im really bad with that. and i haven't met chuck but i've talked to him a few times. so what town do you live in? or would you be at chucks?
Eric
tele: 201.956.7063
Old 04-09-2006, 02:17 PM   #23
njskatchmo
Member#: 94618
2002 Bugeye
My name is tal. It's cool I didn't remeber your name. Hope that 6 speed swap went well btw. We'd have to go to chuck's in mahwah, cause it's his car, just i'm good with computers so i'm fiddling with it. I think at this point it may just be a combination of boost leaks and fouled injectors and plugs. Because I'm almost positive I put the map correctly.
Old 04-09-2006, 04:25 PM   #24
Division By Zero
Member#: 7555
Did you reset the ecu yet? Do that if you didn't. Also, you might want ot use a little higher scale number like 560.
Old 04-10-2006, 12:33 AM   #25
ejsportcom
Member#: 88905
i ended up going to chucks tonight and setting up the utec a lil better for him, it really just needed a few percent of fuel pulled and the stock injector was set to 550, so i changed it to 420. I also turned down the boost so its basically on wastegate pressure, whatever that may be ( i think its 6psi). So it should be fine to drive to get tuned, just no boost to be safe
I need some advice about this setup please? Boots Car Audio, Video & Security 6 04-08-2009 10:42 PM
I need some advice on this setup please? Boots Interior & Exterior Modification 1 04-08-2009 01:28 PM
need base map for this perrin gt30r.82 moorebl Engine Management & Tuning 2 02-23-2006 07:33 PM
Need some input on this setup macius Car Audio, Video & Security 1 11-08-2004 02:26 PM
I need some opinions and some help with this setup krazedant Car Audio, Video & Security 0 05-05-2003 01:59 PM
