Old 10-01-2001, 06:50 PM   #1
megatron
Member#: 4212
2002 Impreza WRX
Default How can you tell if your boost gauge is accurate?
I put in an autometer gauge this weekend and all seems to be working, but I was wondering how I can tell if it is accurate? I'm running a completely stock (other than the free intake mod) 02 WRX and the limited testing I've done with it shows maximum boost at around 13 PSI (full throttle) in 3rd and 4th gear. I show around 15 InHg vacuum when I'm idling and the weird thing is I show negative boost when my foot is on the pedal a little bit. Is this normal to have negative boost when you are accelerating slowly??
Thanks,
Andy
megatron is offline   Reply With Quote
Old 10-01-2001, 07:24 PM   #2
lgkahn
Member#: 9793
2002 2010 legacy gt
red
well max boost specified for the car is 14.2 .. my gaguge reads right around that at wot in 3rd and 4th
I read close to -20 when idling and 0 as soon as I touch the throttle.
lgkahn is offline   Reply With Quote
How can you tell if your turbo has a clipped wheel? SolidSnake General Community 0 02-25-2006 02:11 PM
So how can you tell if your post was deleted? jonny_boy Off-Topic 8 08-07-2003 09:42 AM
How can you tell if your clutch is slipping? SoLo OnE Transmission (AT/MT) & Driveline 7 06-12-2002 02:05 AM
how can you tell if your differential was damaged due to towing? yuzo Service & Maintenance 5 12-30-2001 02:53 AM
How can you tell if your diff is not working? codemunky Technical Forum Archive 5 09-17-2000 09:53 PM
