Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-01-2006, 03:21 PM   #1
N1mxer
Member#: 100987
2002 wrx
blue
Default error when loading tune
i have the verson 5.0 , basicly i just tryed to load the stage 2 into my utec but i keep geting bad check sum, corupt blah blah any ideas? i tryed to copy the map that was in the utec originaly to my computer and that worked but couldnt send it back
N1mxer is offline   Reply With Quote
Old 04-08-2006, 01:43 PM   #2
Bolster
Member#: 22290
2002 WRB WRX Wagon
You need to rename the map. It's a known issue with hyperterminal. Just add a letter to the end of it, or something and that will suffice.
Bolster is offline   Reply With Quote
Old 04-09-2006, 06:05 PM   #3
N1mxer
Member#: 100987
2002 wrx
blue
ok,but im just copy pasting the tune from the web site and puting it in notpad and creating my own file name so where am i suppost to add a letter ?
Old 04-11-2006, 12:22 AM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
Well, your map is named something like stage2blahblahblah.txt. All you need to do is rename it to stage2blahblahblah1.txt and it should fly.
Old 04-12-2006, 03:10 AM   #5
N1mxer
Member#: 100987
2002 wrx
blue
ill try that next time, i ended up just loading it with a computer that has a serial port and worked fine, the usb to serial adapters have some kinda buffer that will cause problems, it loaded fine , i did notice theirs a slight hesitation when shifting into the next gear, feels like a flat spot or something any ideas? i still need to do a run with my LM1 and do data log and stuff but maybe you guys would know thanks
Old 04-12-2006, 07:43 AM   #6
Bolster
Member#: 22290
2002 WRB WRX Wagon
Can you tell us a little about your setup? Anything different than the "standard" stage 2? Maybe a BOV that vents to the atmosphere? What about your parameters?
Old 04-12-2006, 05:19 PM   #7
N1mxer
Member#: 100987
2002 wrx
blue
mods: gp moto headers i belive hot coated and also the up pipe, turbo back MRT with 1 cat on the dp , k&n panel filter thats it .. it ran great with the stock tune , it will do it between 3k and up i was thining it has to do with the transsition from closed to open loop the delay but i have it at 0 so i dont think thats it
CEL flashes under light load and goes away when load increases. No code. Aleksey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-01-2010 01:55 PM
Link Error when trying to pull codes jimbui Newbies & FAQs 6 03-29-2008 12:14 AM
PHP error when acessing teh b4rn ?!? The Tree Off-Topic 11 07-14-2005 07:54 PM
why am i getting this error when i come to nasioc? alacrity024 Off-Topic 6 04-27-2004 02:31 PM
CMOS Checksum Error - Defaults Loaded Bigred14 Texas Impreza Club Forum -- TXIC 5 04-05-2002 11:04 AM
