Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-01-2006, 08:33 PM   #1
daprez
Visiting NASIOC Timeout
Member#: 105645
2002 WRX Sedan
WRBP
Default another question about noise from the rear!
I recently installed AGXs, Prodrive springs, and Group N mounts on my 02 WRX. Since then, I've been getting a faint clunk, occasionally, often as not when I am backing up, from the general rear area (can't tell if it is right or left).
I'm going to have access to jacks and tools tommorrow and I was wondering if anybody has any suggestions as to what to look for in the back.
I've done my searching on noises but there is so much about wagons or swaybar installs that I can't tell if this question has been discussed before.
Thanks!
daprez is offline   Reply With Quote
Old 04-02-2006, 01:30 AM   #2
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Make sure that the tapered washer is seated correctly on the end of the shaft. While you are at it, make sure that you torque down the three strut top bolts properly (since you will have to remove the strut to check the tapered washer).
Before you do that, check your rear sway bar and make sure it did not flip when you did your install.
bcblues is offline   Reply With Quote
Old 04-02-2006, 11:37 AM   #3
daprez
Member#: 105645
2002 WRX Sedan
WRBP
Thanks. Those three nuts should be 14 ft-lbs, right?
Another question -- Whining noises from engine at low rpm = good/bad? cerelius Newbies & FAQs 31 06-09-2005 03:00 PM
Clunking noise from the rear of the car popnfresh Warranty Issues & SOA Problems 32 03-18-2005 09:30 PM
Weird clunking noise from the rear of the car. popnfresh Transmission (AT/MT) & Driveline 6 02-06-2005 05:13 PM
Getting a noise from the rear while turning the wheel. Alfaneggio Brakes, Steering & Suspension 0 10-12-2004 02:22 AM
question about noise from clutch/tranny jjshin Transmission (AT/MT) & Driveline 15 10-18-2002 10:29 PM
