Old 04-01-2006, 10:53 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Help swap won't start!
The car is an MY97 impreza with and MY05 LGT swap and running an MY04 Sti ecu. The car has been wired and the ecu flashed for this combo. The car cranks, the spark plugs spark, the fuel injectors are getting power, the fuel pump is pumping. But it's not starting. Any suggestions?
Joshua
yebokmj is offline   Reply With Quote
Old 04-02-2006, 12:58 AM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
egad. LGT swap using an STi ecu? I'm not going to even venture on this one.
subbyspeed is offline   Reply With Quote
Old 04-02-2006, 09:35 AM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
To get around the immobilizer issue, I suspect.
Check the basics, spark, compression, fuel.
jamesfacts is offline   Reply With Quote
Old 04-02-2006, 09:51 AM   #4
yebokmj
Member#: 2213
Brilliant Red
Yep to get around the immobilizer. I've checked all that, the injectors are working and there is spark and the compression is fine. I starting to wonder if there is a problem in the fuel delivery system. But not the pump because the pump primes and if I unscrew the gas gap the is th woosh of air so the system is under pressure.
Joshua
Old 04-02-2006, 10:22 AM   #5
yebokmj
Member#: 2213
Brilliant Red
Default confusing
The manuals seem to be conflicting on the fuel delivery system. Unless I'm reading it wrong. See pictures below.
The first diagram shows the top connection to the Fuel Pressure Regulator being the Return line. Yet the Bottom picture talks about the fuel supply line and the diagram is labled with the top connection to the FPR being a fuel supply based on the arrows and it saying fuel out. Am I missing something?
Thanks,
Joshua
Old 04-02-2006, 11:01 AM   #6
jamesfacts
Member#: 51282
98 RS
Post a underhood pic?
Old 04-02-2006, 12:54 PM   #7
yebokmj
Member#: 2213
Brilliant Red
underhood as requested:
Old 04-02-2006, 07:25 PM   #8
jamesfacts
Member#: 51282
98 RS
Woah.. I always knew that LGT motors were different than the other recent turbo motors... but I haven't seen a setup like that before.
I know on my 05 intake manifold/fuel rails, the middle soft line went to the top rail (feed), top soft line went to the middle rail (return). Hmmmm...
Old 04-02-2006, 07:36 PM   #9
yebokmj
Member#: 2213
Brilliant Red
I'm also getting a constant wine noise from the electric throttle body when the ignition is in the on position(engine obviously not running). Is this normal?
Joshua
Old 04-02-2006, 11:49 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm not necessarily ...
have you done a compression check?
Old 04-03-2006, 08:29 AM   #11
yebokmj
Member#: 2213
Brilliant Red
Yep compression is fine, so your legacy doesn't have the wine of an electric motor comming from the throttle body when the key is in the on position?
Joshua
Old 04-03-2006, 10:49 AM   #12
jamesfacts
Member#: 51282
98 RS
Joshua
I've heard this before from STi swaps. It's normal.
Old 04-03-2006, 12:06 PM   #13
yebokmj
Member#: 2213
Brilliant Red
well that's good, I don't have to investigate that. What about the car not starting is that normal? :b
Does anyone have any suggestions at all?
Old 04-03-2006, 02:57 PM   #14
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
your not getting a cel? tried pulling codes?
XENONSVX is offline   Reply With Quote
Old 04-03-2006, 06:07 PM   #15
yebokmj
Member#: 2213
Brilliant Red
No check engine lights other than those related to the gas tank emissions. I figured it out. I feel kind of silly. I some how flipped the FPR 180 degree so in was out and vice versa. Car runs now. I have yet to drive it. I'm cleaning up the wires some and have to put the heater core back in so I can put coolant in and actually drive it.
Joshua
Old 04-03-2006, 06:17 PM   #16
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
Nice work! How far are you from crabtree?
enewtabie is offline   Reply With Quote
Old 04-03-2006, 07:40 PM   #17
yebokmj
Member#: 2213
Brilliant Red
I'm about 10-15 minutes from the mall, right down 70 in brier creek. I'll be posting completed pictures and results once I get the dash in and such.
Joshua
Old 04-04-2006, 07:36 AM   #18
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
Joshua
Cool..I'm over on W.Millbrook alot. Never heard of a LGT swap into a impreza.
Old 04-04-2006, 07:39 AM   #19
yebokmj
Member#: 2213
Brilliant Red
Yeah I think I'm the first, never seen anyone post about it and when I needed help there was no one there. So I'm pretty sure I was the pioneer. If you want toe check it out some time feel free to pm me and stop on by.
Joshua
Old 04-04-2006, 12:23 PM   #20
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sooooo
is it running?
does it drive yet?
do you think the proublem w/ the imobilizre wasn't a proublem but the FPR instead?
Old 04-04-2006, 01:35 PM   #21
yebokmj
Member#: 2213
Brilliant Red
No it wasn't the FPR because before the Sti ecu none of the relays were switching. So it was a completely seperate issue. Then after that it would have been the FPR.
Joshua
Old 04-04-2006, 04:12 PM   #22
yebokmj
Member#: 2213
Brilliant Red
Okay so the FPR was the right way origionally. It was the feed and return lines that were swapped. The Impreza the feed line is up top, legacy feed line is at the bottom. I got a chance to look under the hood of my neighbor's LGT and it all made sense. Car runs, perfect now, I still have yet to drive it other than to pull it out of the garage so I can clean up some before putting the dash back in. I'll go for a test drive tonight.
Joshua
HELP!!! My swap won't start... Clicking starter? NicFunkadelic Subaru Conversions 27 04-24-2010 01:43 AM
swap won't start. HELP wrx2102 Subaru Conversions 2 01-18-2010 05:30 AM
help! car won't start after swap ejpowerguy Service & Maintenance 0 03-17-2009 09:37 PM
Utec Experts: Shortblock swap won't start jefersun Engine Management & Tuning 12 08-31-2005 11:29 PM
swap won't start subiedreamin Subaru Conversions 14 08-24-2005 11:08 AM
