Old 04-01-2006, 11:05 PM   #1
norcalboi114
Member#: 92808
02 vf34wrx
psm
Question new parts to be installed vf34
okayyy well right now im at tbe, jdm arc uppipe, aem ram air intake, and running a cobb ap stage 2 91 octane. well i just bought a vf 34, sti pinks, and walbro fuel pump. is anyone running the cobb map for this set up right now with a stock topmount ic? and what did yoy think of it?
norcalboi114 is offline   Reply With Quote
Old 04-02-2006, 12:49 AM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
If I were you, I will take CAI off of your car right away. OTS was not designed to work with aftermarket CAI. Your car will run fine with stock TMIC. That's how stage 2.5 map was designed by Cobb.
Old 04-02-2006, 01:53 AM   #3
norcalboi114
Member#: 92808
02 vf34wrx
psm
even though intake is a short ram ? i know it wasnt designed but will i lose hp or screw crap up?
Old 04-02-2006, 03:19 AM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You may want to ask Cobb directly for their input. It has been discussed hudreds of times here.
Old 04-02-2006, 03:21 PM   #5
Payback
Member#: 41328
2003 WRX Sedan
SOLD - 2/07
I'm running this set up right now and absolutely love it. I agree with the others; ditch the intake. The map is not designed for it. I have Cobb's SF intake on my car which they say is within tolerance of the map. It is highly reccomended not to use other aftermarket intakes.
A piece of install advice, if I may. Be careful when putting the fuel pump assembly back in the tank. Make sure the bracket is on top of the lid, the wires are out of the way, make sure you get a good seal, and don't over torque the nuts. If you break a stud, it cannot be replaced and you may have a pressure leak resulting in the P0457 CEL.
This was the ONLY problem I ran into with the install.
Good luck and enjoy it.
Payback is offline   Reply With Quote
Is $200 in labor too much for a new turbo and fuel injectors to be installed? kakarotoni Service & Maintenance 8 02-29-2008 11:04 PM
New mods BEGGING to be installed! Need Money Alaskan Impreza Club Forum -- AKIC 41 04-16-2006 08:22 PM
FMIC pics + Wrx Vs. M3 + parts waiting to be installed :-) blue blurr Member's Car Gallery 22 03-24-2006 06:15 PM
HELP! i need parts to be able to RACE! christoph1371 Bay Area Impreza Club Forum -- BAIC 0 09-11-2000 10:49 PM
