Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-02-2006, 05:31 AM   #1
wagonrx03
Member#: 36865
2003 WRX wagon
platinum silver
Default no boost!!!!!!!
Ok so i just installed my utec last night, along with a vf39, sti pinks, fuel pump, and tmic. it idled fine but when driving, it gave me almost no boost, probably even less than stock. I was running it on stock setting. I think that might be it but wanted to confirm it by asking you guys first. thanks.
kit
wagonrx03 is offline   Reply With Quote
Old 04-02-2006, 12:52 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Switch the small tubes on the turbo around(make sure the one with the metal bb inside is going to the turbo and not the wastegate actuator).
peace
Old 04-02-2006, 03:32 PM   #3
wagonrx03
Member#: 36865
2003 WRX wagon
platinum silver
damn forgot to tell you im running the blitz sbc-id. now what? but thanks for te replay.
Old 04-02-2006, 10:47 PM   #4
hippy
Member#: 36528
2002 Impreza Wrx
I'd think it has something to do with the boost controller, but I dunno.
peace
Old 04-06-2006, 01:00 PM   #5
rodrigo.diaz3
Member#: 111873
2006 wrx/sti
aspen White
Question
Are you runing the utec with a electronic boost controller???
Because im thinking to do the same its the best to do???
I bought the utec and i have now installed the apexi avc-r
rodrigo.diaz3 is offline   Reply With Quote
Old 04-06-2006, 01:18 PM   #6
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
you shouldnt have installed the apexi avc-r...or at least you won't need it for too long
turboxs is actually working on that same thing for your utec upgrade so you just use the utec to control gear specific boost
gcm05 is offline   Reply With Quote
Old 04-07-2006, 01:00 PM   #7
TurbojonLS
Member#: 38772
2 Cars, No Bling
kit
Why are you running it on the stock setting?
TurbojonLS is offline   Reply With Quote
Old 04-07-2006, 02:38 PM   #8
gcm05
Member#: 105948
i was wondering the same
boost... no boost... now boost again? WRX SEX Factory 2.5L Turbo Powertrain 4 04-27-2010 11:41 AM
STi with no cats, and NO BOOST CREEP V6TurboTA Factory 2.5L Turbo Powertrain 61 08-23-2009 08:10 PM
boost, no boost, more boost...***!!1!11 03twrx Factory 2.0L Turbo Powertrain 12 11-05-2004 03:16 AM
No boost creep-no boost spiking!!-excellent boost response. odin1 Factory 2.5L Turbo Powertrain 19 01-04-2004 07:21 AM
No boost but no CEL?? ideas? OBDii scanner help? iceweazel Factory 2.0L Turbo Powertrain 2 08-21-2001 04:18 PM
Message Board Statistics All times are GMT -4. The time now is 08:51 PM.
