Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 04-02-2006, 06:21 PM   #1
RaceTechPerformance
Vendor
Vendor Sales Rating: (7)
Member#: 110026
Default ATE,Axxis/PBR,Eibach,Espelir,Brembo,Hawk,NRG,Progress,RTP,Te in
BRAKE PADS
Axxis/PBR Brake Pads
High performance brake pads for the street and track. Great consistency and brake feel, with minimal dusting.
Deluxe
Specially formulated organic material designed with maximum rotor and pad life in mind. Providing minimal noise and brake dust, these pads are recommended as quality replacement for OEM brake pads. Designed for street/highway use with frequent stop and go driving.
MetalMaster
High performance metallic brake pads with moderate friction levels and resistance to fade. Designed to provide excellent pedal feel and consistent stopping power in aggressive, sporty driving conditions with elevated levels of heat.
Ultimate
Ceramic formulation high friction compounds designed for maximum stopping performance. Providing the highest possible fade resistance at the highest possible temperatures. Internally designed to prevent squealing. Designed for ultra-high performance braking needs on tracks, but suitable for street driving.
02 WRX
Front Deluxe $ 46 MetalMaster $ 57 Ultimate $ 58
Rear Deluxe $ 41 MetalMaster $ 52 Ultimate $ 53
03+ WRX
Front Deluxe $ 66 MetalMaster $ 77 Ultimate $ 83
Rear Deluxe $ 52 MetalMaster $ 56 Ultimate $ 60
04+ STi
Rear ONLY Deluxe $ 55 MetalMaster $ 67 Ultimate $ 71
All prices include shipping!
HAWK HPS BRAKE PADS
Hawk HPS pads are formulated with a Ferro-Carbon compound to provide excellent braking characteristics. Providing 20-40% higher stopping power and fade resistance, these pads are also very quiet and gentle on rotors providing extended rotor life. Excellent cost-effective OEM replacement pads.
02 WRX
Front $ 120
Rear $ 103
03+ WRX
Front $ 115
Rear $ 107
STi
Front $ 157
Rear $ 103
Project mu B-Force
Great fade resistance and initial bite, these pads offer better braking characteristics than stock pads but aren't too aggressive for the street. Rotor wear is kept to a minimum along with squeal and vibration. Braking temperatures up to 400C.
STi ONLY
Front $ 132
Rear $ 118
BRAKE ROTORS
Brembo Rotors
Genuine,high quality replacement rotors for both track and street use. Manufactured with the highest standards to offer the best in performance. We offer slotted, drilled, and slotted/drilled rotors for all WRX/STi applications, please specify when ordering. All rotors are originally produced from Brembo's factory and are not drilled or slotted by third parties. Comes gold zinc plated.
02-05 WRX
Front: $ 253/pair shipped
Rear : $ 228/pair shipped
04 STi
Front: $ 469/pair shipped
Rear: $ 451/pair shipped
RTP Rotors
RTP high performance, quality rotors available in plain, slotted, drilled and slotted/drilled. Great, cost efficient replacement for factory rotors. Manufactured for us specifically to OEM specifications and tolerances to be the closest alternatives to the highest performing rotors available. All vented rotors feature variable vane lengths for increased ventilation and are gold zinc plated to offer the best in rust and corrosion resistance.
02-05 WRX
Front: Slotted, Drilled, Slotted/Drilled $ 135/pair shipped
Plain(Blank) $ 121/pair shipped
Rear: Slotted, Drilled, Slotted/Drilled $ 135/pair shipped
BRAKE/CLUTCH LINES
Techna-Fit Stainless Steel Brake Lines
DOT approved stainless steel wrapped teflon lines with nylon outer coat. Lines available in Blue, Red, Smoke or Yellow. The addition of stainless steel lines will help to enhance pedal feel by the use of lines which do not expand as much as OEM rubber lines when brake pressure increases. These lines are also great replacement lines for old, worn OEM pieces.
All WRX/STi $ 95 shipped
Lines also available for Legacy and Outback models.
Stainless steel clutch lines also available for $26 shipped or combine with brake lines to save on shipping!
BRAKE FLUID
ATE DOT Blue Brake Fluid
High performance 100% synthetic brake fluid exceeds DOT4 requirements for both dry (593 degrees) and wet boiling points(420). Excellent resistance to moisture absorption. Distinctive blue color packaged in a metal canister.
$13/liter.
SUSPENSION
EIBACH
Pro-Kit and Sportline for WRX/STi/Wagon starting from $ 285 shipped
ESPELIR
Active Super Down
WRX front -0.8"/rear -0.8" $ 245 shipped
STi front -1.4"/rear -0.8" $ 245 shipped
Active GT
STi front -1.2"/rear -0.8" $ 245 shipped
H&R
Sport Springs
WRX front -1.5" rear -1.4" $ 245 shipped
STi front -1.4" rear -1.3" $ 286 shipped
HOTCHKIS
Hotchkis Sport Coil Spring Set
WRX front -1.5" rear -0.75" $ 267 shipped
STi front -1.5" rear -0.75" $ 267 shipped
NRG
LowerTieBar $ 70 shipped
PERRIN
WRX front -1.9"/rear -1.5" $ 188 shipped
STi front -1.9"/rear -1.5" $ 250 shipped
Progress Springs
02-03 WRX front -1.8"/rear -1.5" $ 188 shipped
04+ WRX front -1.8"/rear -1.5" $ 188 shipped
STi front -1.0"/rear -1.0" $ 188 shipped
RSR
Ti2000
02-03 $ 369 shipped
04+ $ 385 shipped
Down Springs
02-03 WRX front -1.8/rear -1.2" $ 238 shipped
TANABE
GF210
02-03 WRX front -2.0"/rear -1.5" $ 203 shipped
STi front -1.3"/rear -1.0" $ 228 shipped
DF210
02-03 WRX front -1.5"/rear -1.0" $ 215 shipped
STi front -1.3"/rear -1.0" $ 215 shipped
NF210
TEIN
WRX
S-Tech front -2.0" rear -0.7" $ 203 shipped
H-Tech front -1.4" rear -0.6"$ 215 shipped
STi
S-Tech '04 front -1.6" rear -0.9"
'05 front -1.7" rear -1.2" $ 215 shipped
H-Tech '04 front -1.0" rear -0.4"
'05 front -1.1" rear -0.6" $ 221 shipped
Email us to order parts as a package and save on shipping!
Parts for other models also available, please contact us for information.
We also offer springs, swaybars, and other suspension components from numerous manufacturers. If there are any other parts that you'd like to see us carry, please contact us and let us know! We're always looking to provide the best deals for our customers!
Please email me at [email protected] or pm for any questions or quotes.
Paypal as preferred method of payment to [email protected]. Please specify year and model of vehicle with order.
Thanks!
Dave
RaceTechPerformance
Last edited by RaceTechPerformance; 05-09-2006 at 01:36 PM. Reason: updated price list
RaceTechPerformance is offline   Reply With Quote
Old 04-03-2006, 03:31 PM   #2
RaceTechPerformance
Vendor
Member#: 110026
pms returned
Old 04-05-2006, 01:48 AM   #3
RaceTechPerformance
Vendor
Member#: 110026
pms returned!
Old 04-05-2006, 12:52 PM   #4
hanzo918
Member Sales Rating: (17)
Member#: 82148
1992 Daihatsu
Charade
+1 for RaceTech!!!!!
hanzo918 is offline   Reply With Quote
Old 04-05-2006, 01:44 PM   #5
RaceTechPerformance
Vendor
Member#: 110026
Parts shipped and feedback left! Thanks and keep the orders coming!
Old 04-05-2006, 05:59 PM   #6
RaceTechPerformance
Vendor
Member#: 110026
updated list!
Old 04-06-2006, 12:57 PM   #7
RaceTechPerformance
Vendor
Member#: 110026
morning bump!
Old 04-07-2006, 08:38 PM   #8
RaceTechPerformance
Vendor
Member#: 110026
Bump for the weekend!
Old 04-11-2006, 01:26 AM   #9
RaceTechPerformance
Vendor
Member#: 110026
Bump for Monday!
Old 04-12-2006, 01:44 PM   #10
RaceTechPerformance
Vendor
Member#: 110026
Midweek Bump!
Old 04-13-2006, 04:25 PM   #11
RaceTechPerformance
Vendor
Member#: 110026
Thursday Bump!
Old 04-17-2006, 12:16 PM   #12
RaceTechPerformance
Vendor
Member#: 110026
Bump for the week!
Old 04-18-2006, 12:18 PM   #13
RaceTechPerformance
Vendor
Member#: 110026
PMs replied, orders will be shipped out today.
Old 04-20-2006, 12:57 PM   #14
RaceTechPerformance
Vendor
Member#: 110026
Thursday bump!
Old 04-21-2006, 02:01 AM   #15
Jelphree
Member Sales Rating: (15)
Member#: 48316
Where are you guys located...what streets? I live in Santa Fe Springs. A shop near me...I love it!!!
Jelphree is offline   Reply With Quote
Old 04-21-2006, 04:38 PM   #16
RaceTechPerformance
Vendor
Member#: 110026
Hi Jelphree,
We're located on Bell Ranch Drive, near the corner of Telegraph and Santa Fe Springs.
Regards,
Dave
RaceTech Performance
Old 04-24-2006, 09:24 PM   #17
Jelphree
Member#: 48316
I stopped my and I couoldn't find the shop. What's the address/suite?
What time are you guys open/closed?
Old 04-27-2006, 01:57 PM   #18
RaceTechPerformance
Vendor
Member#: 110026
Bump again!
Old 04-30-2006, 05:21 PM   #19
RaceTechPerformance
Vendor
Member#: 110026
Sunday Bump!
Old 05-01-2006, 12:12 AM   #20
04Silverex
Member Sales Rating: (20)
Member#: 77322
2016 STi
Cwp
can you get the brembo bracket for a wrx to sti conversion for the Brembo rear calipers?
04Silverex is offline   Reply With Quote
Old 05-01-2006, 04:26 PM   #21
Jelphree
Member#: 48316
I'd like to purchase the Hawk HPS brake pads, front and rear, for an 05 STi. Can I stop by and pick them up? I live less than 5 minutes from you guys. Thing is I work M-F from 8-5 and I don't know what time you guys close.
Old 05-02-2006, 08:03 PM   #22
RaceTechPerformance
Vendor
Member#: 110026
Hi everyone,
04Silverex- I'm checking for you right now of whether we can provide those parts for you.
Jelphree- Sent you a PM.
Regards,
Dave
Old 05-04-2006, 02:04 PM   #23
RaceTechPerformance
Vendor
Member#: 110026
PMs returned!
Old 05-08-2006, 11:46 PM   #24
biggreen96
Member Sales Rating: (7)
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
do you have Axxis utimates for 93 turbo legacy wagon, the rears only? (I have bugeye WRX front brakes)
biggreen96 is offline   Reply With Quote
Old 05-09-2006, 01:28 PM   #25
RaceTechPerformance
Vendor
Member#: 110026
PMs sent!
2002 wrx rear Brakes including BREMBO DRILLED ROTORS and KNUCKLES Dark WRX Suspension/Brakes/Handling 2 08-16-2008 11:38 AM
FS: Lots of WRX/STi braking parts MD@ Suspension/Brakes/Handling 20 08-28-2007 01:03 AM
WTB : 2 pots rear STi brake non brembo Mister_wagon Private 'Wanted' Classifieds 1 01-12-2005 11:12 PM
2004 Subaru WRX STi BBS Wheels/Brembo Brakes shanenlorenz Private 'For Sale' Classifieds 14 10-07-2004 05:58 PM
