Old 04-02-2006, 09:08 PM   #1
gringorio
Member#: 111536
Default Legacy Outback lift kit?
Hi ya’ll
I’m wondering how feasible it is to put a 2” ‘lift kit’ on a 1998 Subaru legacy outback?
If so, where did you find the parts and how much, more or less, did it cost? Are there any potential problems to consider?
Thanks!
gringorio
gringorio is offline   Reply With Quote
Old 04-03-2006, 01:09 AM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
There is an auzi company called "Back Yard Boys" they made full lift kits for any subie. I think ISR in Cali was selling them. You might try a google search.
Here: http://www.renickmotorsports.com/osc...oducts_id=1219
subiekid is offline   Reply With Quote
Old 04-03-2006, 02:10 AM   #3
wrxsubaru
Member#: 65133
You would for sure get alot more responses over at http://www.ultimatesubaru.net/forum/ They have many members with lifted old and new school subes.
I belive scorpion makes springs for the outback to give it a 1-2 inch raise. Sorry i dont have there web site i just, but some over at ultimatesubaru would.
wrxsubaru is offline   Reply With Quote
Old 04-03-2006, 02:20 AM   #4
ten80
Member#: 53625
00 16' FXT
scorpion lift springs sure will give you close to 2" lift on stock struts, I've them in person and they look really nice, otherwise you need the lifting blocks/spacers, and all that jazz.
ten80 is offline   Reply With Quote
Old 04-03-2006, 08:50 AM   #5
steve_d
Member#: 315
I can vouch for scorpion kits...they're pretty nice. I did a baja once, a long time ago.
sjd
steve_d is offline   Reply With Quote
Old 04-03-2006, 10:17 AM   #6
gringorio
Member#: 111536
Default thanks
thanks everyone! i'll check out the scorpion kits.
gringorio
Old 04-03-2006, 11:14 AM   #7
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
How do the scorpion springs lift 2" when the shocks are at the full extension on normal outback springs?
The Renick kit pictures look like it's a strut spacing system, but there are some other components that look like they might be geometry correction.
mranlet is offline   Reply With Quote
Old 04-03-2006, 03:38 PM   #8
gringorio
Member#: 111536
Default springs
OK, so it sounds like lifting by springs will achieve the results I'm looking for with less hassle. Would it be better to switch to another kind of strut when I do this? The primary uses will be highway (getting to the sites) then rough dirt roads...
Old 04-04-2006, 09:56 AM   #9
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
They're not at full extenion man, not even close. If they were everytime you go over a bump you'd get air!
Samirr76 is offline   Reply With Quote
Old 10-25-2010, 07:16 PM   #10
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
I am looking to lift my 97 Wagon anybody have anymore info?? The links here are dead.
Looking for a 2 in. lift as cheaply as possible!
bangedlegacywagon97 is offline   Reply With Quote
Old 11-30-2010, 09:38 PM   #11
OCRentAPopo
Member#: 223094
1999 Legacy OB 5MT
Lots of guys on subaruoutback.org have lifted their first generation outbacks one way or another. King Springs (http://www.writerguy.com/primitive/susp.htm) are one way.
A cheaper solution are '04-'08 Forester strut assemblies (springs & struts) with subtle solutions 1" spacers in the rear. (http://www.subtle-solutions.com/prod...roducts_id=111) (http://www.subaruoutback.org/forums/...y-bg-98-a.html)
OCRentAPopo is offline   Reply With Quote
Old 12-27-2010, 12:43 AM   #12
cstuck
Member#: 245172
1999 Legacy Outback
Olive Drab and Black
I know this is going to sound a little sketchy but i put a lift on my 98 legacy outback with boat rollers. The trailer rollers that hold large offshore boats are solid high density rubber. I took the rollers and cut them into "pucks" about 2 1/2" thick to allow for some settling. I took the stock struts off the car and bought longer Grade 8 1/2" bolts from Fastenal. Placed the "pucks" in between the frame and the strut tower and reinstalled the struts. The outback sits about 2" higher now. I've been driving it for 6 months with no problems at all. They make a rubbery squeak when its cold and i go over a speed bump but thats it. No abnormal tire warring and the camber seems to have stayed stock. Any questions let me know
cstuck is offline   Reply With Quote
Old 12-27-2010, 12:45 AM   #13
cstuck
Member#: 245172
1999 Legacy Outback
The project cost was about $50 in bolts washers and nuts. I spent about $40 on the rollers. I did the whole thing in about 4 hours
Old 12-31-2010, 12:35 AM   #14
stockk5
Member#: 207051
I keep searching around, but is there any write up with pictures/descriptions on how to lift a 98 impreza? I also want to know how the CV's and any other hidden cost that are associated with this come into play. Thanks guys! sorry for such a newbie post!
stockk5 is offline   Reply With Quote
Old 01-01-2011, 08:50 PM   #15
glennwilson87
Member#: 171288
1998 Outback Sport
ultimatesubaru.org/forums will have TONS AND TONS of information about lifting subarus. but the site is down right now... again... so until then, here is my car
http://slcsubaru.freeforums.org/view...hp?f=14&t=4344
glennwilson87 is offline   Reply With Quote
Old 01-03-2011, 02:06 PM   #16
my48yr8
Member#: 257692
We used forester struts on a 95 impreza and it gave 3 " of lift. Fronts bolt right in, rears you can change the top hat or drill out the mounting holes a little. Works grate and we pulled the parts from a local junk yard and got all 4 of um for $50.
my48yr8 is offline   Reply With Quote
FS-Scorpion Lift Kit for Baja--possibly Legacy, too wrenchwoman Suspension/Brakes/Handling 4 09-02-2011 12:42 AM
Impreza/legacy 2 inch lift kit for sale old school NWIC Private Classifieds 3 03-07-2009 12:02 PM
Whiteline Anti Lift Kit for Impreza, Legacy, Outback Mx5racer Private 'For Sale' Classifieds 7 06-01-2006 01:31 PM
'01-style Legacy Outback sedan kits. Duende Interior & Exterior Modification 1 02-03-2006 09:59 AM
Legacy/outback lifted!!! Allied Armament Subaru Conversions 8 12-04-2005 04:13 PM
