Old 04-02-2006, 08:13 PM   #1
98skuby
Member#: 52632
1998 impreza rs
black
Default ej25t
has anyone done the gc8 2.5rs engine mix. putting the sti short block and stock rs heads together? and turbo charged it? i have questions of matching the parts.
james
98skuby is offline   Reply With Quote
Old 04-02-2006, 08:22 PM   #2
cyrus923
Member#: 44425
2004 Impreza WRX
WR BLUE
A lot of people think that non-turbo heads are actually work better then turbo heads. I think they will be fine if you change the valve springs...ect. Maybe someone can give more info as to why they are better.
cyrus923 is offline   Reply With Quote
Old 04-02-2006, 09:05 PM   #3
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
the block mates up the same and will work fine. but you might want to invest in pistons with a dish designed for that head. they also have a rod/piston combo at crawford that would swap into your stock EJ25 n/a block. but you wouldn't really be able to get the same performance capability as the EJ257 block as yours is not semi closed deck... BUT, it is an option.
JonofScio is offline   Reply With Quote
Old 04-02-2006, 11:16 PM   #4
lasek87
Member#: 98262
1999 impreza 2.5rs
white
I have a 99 2.5rs with a FAT stage 1 kit on it. In a month im getting a sti short block installed along with a new ECU. The guys at xcceleration.com told after the block and the ECU ill be able to get around 350 hp at 15-18psi. Ill let you know what happens. Ill post some pics to!! Good luck though
lasek87 is offline   Reply With Quote
Old 04-03-2006, 10:53 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
It's never been done, ever. Just giving you a hard time. There's a bunch of threads in the proper forum (aftermarket forced induction) about this seet up. It's not a swap, it's an RS-T. Drop a PM to skully. He's in your neck of the woods, and can steer you towards the right people to help you out with this and get it tuned properly...
EJ25T or TT bwolf33 Legacy Forum 4 05-13-2003 02:39 PM
('93-'01) EJ25T swap - who will be the first? Radar_Lover Impreza Forum 8 03-05-2003 11:12 AM
EJ25T? N'CTRL STi Forum Archive 3 01-07-2003 11:49 PM
Marcin's EJ25T buildup -Discusion- Marcin Mid West Subaru Owners Club Forum -- MWSOC 21 12-31-2002 11:42 AM
EJ20T vs EJ25T... Digital_Boy Factory 2.0L Turbo Powertrain 5 03-25-2001 12:59 AM
Message Board Statistics All times are GMT -4. The time now is 04:59 AM.
