Old 04-02-2006, 08:39 PM   #1
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Impreza GC8 Pictures of my new engine and turbo buildup. Now JDM Version 8/5 hybrid, with a VF22.
The old shortblock: EJ205, JDM WRX Version 5 ('98 - '99) Type RA.
Bought with approx 50K miles, drove for around 18000 miles, suspected blown head gasket. Cylinder walls were pitted, decided to get a new engine.
The new shortblock: EJ207, JDM STI Version 8 ('04 - '05). 30K miles. Post professional cleaning:
I am using ARP head studs and a JDM complete gasket set. Crawford and others have convinced me to stick with the stock 3 layer stainless steel head gaskets. If Crawford can make 500WHP+ out of those, I don't think blowing them is going to be much of an issue with my 300 - 350WHP goals.
powerlabs is offline   Reply With Quote
Old 04-02-2006, 08:41 PM   #2
powerlabs
Member#: 45790
SUPERCHARGED
Default Heads.
The heads: Still my old V5 WRX Type RA. Professionally cleaned, valves reseated, 5 angle valve job.
Old 04-02-2006, 09:25 PM   #3
powerlabs
Member#: 45790
SUPERCHARGED
Default VF 22 Turbo.
The turbo: IHI VF-22. Ported and polished compressor inlet and compressor outlet, ported and polished and high temp ceramic coated turbine inlet:
Old 04-02-2006, 09:26 PM   #4
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
damn everythings so sparkly clean..
kenny08 is offline   Reply With Quote
Old 04-02-2006, 09:31 PM   #5
DFL2.5RS
Member#: 73228
2015 White STI
2013 WRX, 2003 Rally car
How long will this one last?? jk I'm looking forward to seeing this thing in action in a few weeks.
DFL2.5RS is offline   Reply With Quote
Old 04-02-2006, 09:34 PM   #6
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
make me jealous... grrr
WRXDriftR is offline   Reply With Quote
Old 04-02-2006, 09:42 PM   #7
imp2.5
Member#: 11354
Hopefully longer than the last one, but same here, I can't wait to see this thing auto-x
imp2.5 is offline   Reply With Quote
Old 04-02-2006, 11:06 PM   #8
powerlabs
Member#: 45790
SUPERCHARGED
"The star that shines twice as bright, only lasts half as long"...
I want this one to last untill I can buy a 2005 STI. I.E. At least another year/ year and a half. I'm not too demanding, am I?
Of course, I also want it to run 11s in the 1/4 mile, so maybe I am being too ambitious.
Old 04-03-2006, 12:03 AM   #9
InfamousDX
Member#: 25413
very nice...i especially like the shortblock. looks all nice cleaned up.
Old 04-03-2006, 12:09 AM   #10
whateverwrx
Member#: 99653
05 WRX
you lucky dog good luck!!! looks sweeet
whateverwrx is offline   Reply With Quote
Old 04-03-2006, 01:55 AM   #11
Beebs99
Member#: 73803
2008 4 Door WRX
Looking good. Just curious as to why you got a 5 angle valve job? Isn't 3 enough?
Beebs99 is offline   Reply With Quote
Old 04-03-2006, 02:17 AM   #12
azn2nr
Member#: 35276
why would you want an 05 sti after something like this? gc84life
azn2nr is offline   Reply With Quote
Old 04-03-2006, 02:23 AM   #13
powerlabs
Member#: 45790
SUPERCHARGED
I'm not sure, but if I had to guess, I think it would have something to do with 2 blown motors, 2 blown transmissions, 2 ruined wheel bearings, 3 clutches, 2 flywheels, blown power steering pump and some other misc. stuff I'm probably forgetting.
I *love* the GC8, and it will lay waste to any stock STI, as well as look a lot better than anything Subaru has made since then... But the sad truth is that the drivetrain wasn't meant to make all this power and I am spending way too much money modding and fixing the car. I need a stronger base to build up from and a newer car that won't need as much regular maintenance. Plus the interior is better :P
Old 04-03-2006, 02:24 AM   #14
powerlabs
Member#: 45790
SUPERCHARGED
That's just what the machine shop offered. Multi angle valve jobs flow more air at lower lifts, resulting in better throttle response.
Old 04-03-2006, 12:56 PM   #15
clamdip
Member#: 18709
very nice!!!!
clamdip is offline   Reply With Quote
Old 04-03-2006, 02:05 PM   #16
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
nice. But vf22 ?
ImprezaRSfan! is offline   Reply With Quote
Old 04-03-2006, 02:13 PM   #17
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Originally Posted by ImprezaRSfan!
nice. But vf22 ?
+1
why not go big 16g or 18g? especially if you want to run 11's... that way you wont have to push that 22 so hard that you blow the motor (again)
LatentWagen is offline   Reply With Quote
Old 04-03-2006, 02:18 PM   #18
RedlineFl
Member#: 99842
Wow that engine is sexxxyy! Well I have to admit a vf22 doesn't seem up to par with the engine what's the deal?
RedlineFl is offline   Reply With Quote
Old 04-03-2006, 03:51 PM   #19
powerlabs
Member#: 45790
SUPERCHARGED
Its called "limited resources" That VF-22 cost me under $450, ported and polished and ceramic coated. How much is a big 16G or an 18G again?
Furthermore, if I wanted to run anything bigger than a VF-22 I would need larger injectors. Bigger injectors would require stand alone EM, and the power made would require a JDM transmission (even more than the VF22 already does). The JDM transmission is a different gear ratio, so it needs a new rear diff, the rear diff needs new half shafts, and I would also need a new clutch and flywheel. Oh, and a new slave cylinder too.
So VF22 it is
Old 04-03-2006, 05:29 PM   #20
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
No respect for the VF22. If only they knew
Scoobie Steve is offline   Reply With Quote
Old 04-03-2006, 05:46 PM   #21
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Big Bump for the VF22 I have one and it is great. Best turbo I have ever bought for the money!!
Poweredbysnail is offline   Reply With Quote
Old 04-03-2006, 05:49 PM   #22
lovesmysuby04
Member#: 71494
07 Legacy GT
11 SSM Hatch
vf22 kicks a$$
lovesmysuby04 is offline   Reply With Quote
Old 04-03-2006, 05:52 PM   #23
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
maybe now you will be able to catch up to me at rich's ice races.
jdgrimm is offline   Reply With Quote
Old 04-03-2006, 06:51 PM   #24
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
solution: version 7 or 8 motor and drivetrain
solution to all your problems, including hair loss (if applicable)!
Capt Crunch is offline   Reply With Quote
Old 04-03-2006, 07:23 PM   #25
cronic
Member#: 9749
Exactly, you only went through so much trouble because you sold yourself short.. It woulda been more expensive upfront for a complete new age swap, but would been cheaper in the long run..
Good luck on the build..
cronic is offline   Reply With Quote
Pictures of my new kitchen... aka "the most horrible generic style-void of a kitchen" 2k2 Off-Topic 56 11-21-2009 11:49 AM
Pictures of my new GC JDM tailights jimithing412 Member's Car Gallery 10 02-28-2006 06:59 PM
New pictures of my new hood bra and emblem!! kevinsUBARU Tri-State Area Forum 4 08-19-2001 11:21 AM
Pictures of my new car Sean McElderry North West Impreza Club Forum -- NWIC 21 05-12-2001 06:56 AM
Pictures of my new Car.... Mike Moffa General Forum Archive 13 08-24-2000 12:52 AM
