Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 04-02-2006, 09:48 PM   #1
kaisersouse
Member#: 85900
2001 Forester S
Default 2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l?
what will happen w/ 2.5 injectors in my 2.2l? kaboom/choke?
there are plenty of cams for 2.5 SOHC....ANY for 2.2 SOHC??
kaisersouse is offline   Reply With Quote
Old 04-02-2006, 10:03 PM   #2
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
if the injector is the same style of orientation to the fuel rail/intake, then they should swap over no problems. you would need to reset the ecu though.
if your OBS 2.2 has red top injectors, I do believe they are the same between the two motors, but I could be wrong. check the orientation and color. if they are the same color, you're wasting your time.
JonofScio is offline   Reply With Quote
Old 04-02-2006, 10:06 PM   #3
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Why would you want to put 2.5 injectors in? You can drop in 850cc injectors, but your ecu won't recognize the difference, at least not the way you would like.
t3hWIT is offline   Reply With Quote
Old 04-02-2006, 10:10 PM   #4
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
from what I have gathered, the single exhaust port EJ22 head could swap EJ25 cams with no issues. (words from Matt Monson)
2.5 longblock in 02 wrx injector latencies sgiord86 Built Motor Discussion 8 01-20-2010 03:51 PM
2.5 DOHC in place of my 1.8 SOHC ScoobKing Normally Aspirated Powertrain 8 01-16-2008 08:27 PM
Cobb Spicy CAMs for 2.5 SOHC slamck Private 'For Sale' Classifieds 26 12-09-2003 08:48 PM
Cobb Cams for 2.5 DOHC GTkrockett Legacy Forum 12 08-26-2003 07:43 PM
best cams for 2.5 RS AntonioS Normally Aspirated Powertrain 4 03-06-2003 12:06 PM
