Old 04-02-2006, 10:35 PM   #1
03mbpREX
Member#: 33953
2015 STI
Default anyone go to stage 3 yet????
I just installed my vf39 turbo on my 06 wrx. lol but I lost the restrictor pill while doing it, so im gonna order a new one through subaru and then install it then reflash the ecu. I was just wondering if anyone has done it yet, and what are their thoughts
03mbpREX is offline   Reply With Quote
Old 04-03-2006, 05:47 PM   #2
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
i have a vf39 laying around that i just bought...
which intercooler are u using? that's all i need to get. it says sti tmic... but... i kind of wanted to get the aps.
ill let you know how it is in 2 weeks. haha.
toekneeyo is offline   Reply With Quote
Old 04-03-2006, 06:02 PM   #3
F-H
Member#: 79775
PDXTuning has already done several of these. I'm sure they have a map for your set-up.
F-H is offline   Reply With Quote
Old 04-04-2006, 09:28 PM   #4
REX WHITE
Member#: 60762
2006 WRX Wagon LE
Cobb Stage VOOOSH!!!!
You won't be disappointed.
I picked up a used VF39 and a used STI TMIC for $650. I'm running the map Cobb designed to support these mods, and this thing flat out rips. I made the mistake of not reading the notes and didn't realize the restictor pill needed to be bored out.
In 1st and 2nd gear, I had no problems. WOT in 3rd gear (also happened in 5th gear), I threw a cel and my cruise control light began to blink. I'm guessing their was too much pressure built up and the throttle cut out so that further damage would be prevented. After the engine "checked itself", everything went back to normal - I was still within the expected boost range. However, everytime I got on it in 3rd gear, it would cut out. After drilling out the restrictor pill, I was able to drive it hard w/o the CEL coming on or the engine cutting out.
I wasn't able to find a #57 drill bit, which is what Cobb specs, but I was able to get a 3/64 Dremel bit. Cobb specs the hole to be .043", 3/64 = .0468. Since the pill is brass, it isn't very hard to drill it out.
REX WHITE is offline   Reply With Quote
Old 04-04-2006, 10:38 PM   #5
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
What?!!Cobb as stg 3 map?!!?!?I dont see it on there site.Where did it tell you about drilling out the pill?
Needles is offline   Reply With Quote
Old 04-04-2006, 11:02 PM   #6
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
the stg. 3 map is in the list with the rest of the maps...and if you open the map notes it will explain the need for and how to re-size the restrictor pill.
sluflyer06 is offline   Reply With Quote
Old 04-04-2006, 11:05 PM   #7
REX WHITE
Member#: 60762
2006 WRX Wagon LE
http://www.cobbtuning.com/wrx/accessport/25index.html
Check out the VF39 map.
As for the restrictor pill, Cobb does an excellent job outlining and providing visuals as to what you need to do. You can download the map notes from the same page, it's right under the base and real maps.
I forgot to mention, I have a Cobb catless TBE. I'm not sure if it's necessary, but it's what Cobb specs for this particular map. Actually, they don't specify catless. I figured if I was going...I'm going all the way.
Old 04-05-2006, 09:08 AM   #8
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Please post the link for stg 3 maps.I must be blind I don't see it.
I see the VF39 maps for the 06.Thats it.
Old 04-05-2006, 11:06 AM   #9
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
looks like its for 06' only...but seems you 02'05 guys have plenty of options...sorry for the mislead I have a 06' and haven't even looked through the list for the 02-05 yet.
Old 04-05-2006, 07:35 PM   #10
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Cobb is still developing the stage three map for the 02-05's.
Ahh stage three, so fun.
parker/slc/gc8fan is offline   Reply With Quote
Old 04-07-2006, 03:15 AM   #11
03mbpREX
Member#: 33953
2015 STI
well, i got my restrictor pill, didnt need to drill a hole it was already the right size, put it in, reflashed my ecu. Now , the car just flys, never dies out like the stocker turbo does. ecu is still learning as well. I would recomend this to anyone who has an 06. its a cheap mod, and its as fast as a stage1 sti or even faster, I know cause my friend had one. Thanks cobb for the good work. Now its time to get protuned. 1 month
Dan
Old 04-07-2006, 03:32 AM   #12
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
wow you live in Sarasota! thats my home but i'm currently at college right now in Saint Louis....if it wouldn't be too much trouble the next time i come home (soon) i'd like to take a ride in your car to get a feel for the vf39 so i can decide if i'm gonna go with that or skip it and go for a larger turbo etc.
let me know if that would be cool with you....if it is i'll just shoot you a PM next time i'm home.
Old 04-07-2006, 01:35 PM   #13
CynicX
Member#: 48199
06 WRX
thats what they are talking about....
CynicX is offline   Reply With Quote
Old 02-18-2008, 06:56 PM   #14
Zerogravity
Member#: 151638
2005 WRX Wagon
need to chk this out
Zerogravity is offline   Reply With Quote
Old 03-02-2008, 10:44 PM   #15
jasontee1
Member#: 111428
2006 wrx vf43 swap
wrb
the vf39 map is stage 3 i added the vf43 and sti tmic and i found the dill bit #57 at ace hardware bought it all for $700 only 6000 miles runs great
jasontee1 is offline   Reply With Quote
Old 03-03-2008, 08:11 PM   #16
bullittman68
Member#: 141857
2005 WRX Wagon
CGM VF39'd [email protected]
When you install a VF39 do you all not upgrade the fuel pump and injectors?
it says I need to for my 05 WRX, but maybe that is just on 02-05's
bullittman68 is offline   Reply With Quote
Old 03-03-2008, 08:21 PM   #17
jasontee1
Member#: 111428
2006 wrx vf43 swap
wrb
you have a 2 liter not a 2.5 if it says you do then i would
Old 03-03-2008, 08:27 PM   #18
bullittman68
Member#: 141857
2005 WRX Wagon
I already bought them and all, I just hope I didn't waste my money. I'll check the Cobb notes and see what it says. I don't see anything about the pill on the 05 notes.
Old 03-04-2008, 10:43 AM   #19
SubyJon47
Member#: 172146
2006 WRX Stage 2
Talking
I have come to believe that for any VF39 swap you really should upgrade the fuel pump and injector(pinks). Needlesstosay; the larger intercooler to accompany the larger turbo.
If you don't upgrade the pump and injectors than I think you run the risk of running lean bc they can't compensate for all the extra air the turbo is pumping through your engine.
Hope this helps.
SubyJon47 is offline   Reply With Quote
Old 03-06-2008, 07:36 PM   #20
jasontee1
Member#: 111428
2006 wrx vf43 swap
wrb
the 06 has larger injectors than the sti
Old 06-05-2008, 02:19 PM   #21
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Thumbs down
Sorry to bring this back from the dead (again) but W R O N G.
The 06 WRX has the same sized injectors as the 07 STi.
The 07 STi has top feeds, similar to the STi pinks.
The 06/07 WRX has the same sized top feed injectors.
Show me where the 06 WRX has "larger injectors."
Please?
The 04-06 STis have side feed injectors.
Even so, they are MAXed beyond 275 WHP without a bigger pump.
The pump will only give you very little extra breathing room (approx 10% IDC), and it is better to swap injectors to 740cc, if you have goals of 300WHP or greater.
sotc
saab-on-the-cobb is offline   Reply With Quote
cobb stage 2 looking to go to stage 3, turbo swap, but which one? brandon230573 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 57 04-02-2005 10:18 PM
Anyone going to Shamrockfest 3/12? Tur1smoWRX Mid Atlantic Impreza Club -- MAIC 2 03-11-2005 10:02 PM
Anyone going to the drift event 3/27 AWD2.5 Tri-State Area Forum 1 03-25-2004 12:34 PM
Anyone going to watch Scary Movie 3 this weekend ?? setiawani Off-Topic 12 10-27-2003 02:06 PM
Anyone going to the open track event at buttonwillow 3/2-3? 300ZX6R Bay Area Impreza Club Forum -- BAIC 0 02-20-2002 04:20 AM
