Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-03-2006, 01:37 AM   #1
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Default Track/Rally guys, what do you use for STi 6sp transmission fluid?
Right now we are using Royal Purple 75W90 gear oil in the car and after 5-8ish laps or so, the 4th gear synchro starts to get a bit crunchy unless I shift it slow. Until it gets hot though, its perfect. We need something that will last 20 laps. Any ideas?
-Tom
trhoppe is offline   Reply With Quote
Old 04-03-2006, 02:53 AM   #2
homiusang
Member#: 88836
06 Evo IX
GG
-Tom
I had the Royal purple on my 350z and it was ok shifting when cold.
Aren't the RP gear oil synthetic? I heard the STi tranny doesn't link synthetic lube...
Sorry couldn't be more help, but free bump
homiusang is offline   Reply With Quote
Old 04-03-2006, 06:24 AM   #3
david amor
Member#: 111578
Redline Heavy Shockproof Redline Heavy Shockproof Redline Heavy Shockproof.
david amor is offline   Reply With Quote
Old 04-03-2006, 08:42 AM   #4
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
Motul Gear FF, formulated specifically for competition trans with limited slip diffs
my RS rally car had a croonchy 2nd gear synchro, w/the good French go juice, it's now happy and quiet.
Dave G
RB5 Clone is offline   Reply With Quote
Old 04-03-2006, 09:19 AM   #5
JoBoo
Member#: 23423
05 STi / 08 Dmax
IDP Racing Tech Monkey
Motul Comp FF. its a 75w140 also formulated for LSDs. also $$$
The big problem with the sub's transmissions is heat. It doesnt deal with it very well, even with the oil pump, pan and fins... with the heavier wt you have a better chance dealing with the heat issues. also the synchros seem to like heavier viscosities for "better" shifting.
I toasted 3rd gear (5mt) last year using another brand... after looking at the failure site, the it looks like it was heat induced (long story short..) switched to FF since (in the 5mt and 6mt) and been very happy. We'll see how it hold up in the STI this year.
JoBoo is offline   Reply With Quote
Old 04-03-2006, 09:23 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
ding! ding! ding!
Jamie
Old 04-03-2006, 09:31 AM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
This is based on my own personal experience, so I can't say for sure it will work for you, but this is what I used...
Tried Redline 75W90NS and got the same problem you're having. Eventually got to the point where it was grinding going into 4th every time, not just when it was hot. Replaced the tranny and ran Coastal semi-synth 75W90. That worked for a one track day and about 5K miles. Next track day the 3rd->4th grinding returned. I decided to try the Valvoline 75W90 dino oil so I went to NAPA to get it. They didn't have the dino oil, but they had the 75W90 Valvoline Synthetic. Decide to give that a try. Once that was in, I NEVER got grinding again after 15+ track days and maybe 20K+ miles. It really worked wonders for me.
Old 04-03-2006, 09:35 AM   #8
bjorn240
Member#: 17598
2016 Open Class
Subaru WRX STi
Motul Comp FF.
bjorn240 is offline   Reply With Quote
Old 04-03-2006, 12:08 PM   #9
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
Originally Posted by bjorn240
Motul Comp FF.
how much is that stuff anyway?
greg donovan is offline   Reply With Quote
Old 04-03-2006, 12:09 PM   #10
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Or....I agree with all the above...or...you can use GM Sycromesh that has the LSD additive in it FTW..
Bill
Old 04-03-2006, 12:27 PM   #11
dch
Member#: 1057
2004 WRX STi
Very Yellow
Castrol B373 gear oil (as specified by Prodrive). Hard to find, had to import mine from the UK.
dch is offline   Reply With Quote
Old 04-03-2006, 12:27 PM   #12
greg donovan
Member#: 60743
'95 Impreza L
Bill
that is what is in my car now. works just fine. but i dont track it. but that is what Mark Utecht used in his GN WRX and he didnt have too many trans issues aside from bent shift forks.
Old 04-03-2006, 12:28 PM   #13
greg donovan
Member#: 60743
'95 Impreza L
how much does THAT cost?
i dont recall you havng many transmission issues. so it must work pretty good.
Old 04-03-2006, 03:21 PM   #14
randy zimmer
Member#: 4560
93 buy my rally
build manual
Doug,
Aren't you using a dogbox?
rz
randy zimmer is offline   Reply With Quote
Old 04-03-2006, 03:22 PM   #15
randy zimmer
Member#: 4560
93 buy my rally
build manual
Greg,
He doesn't make it far enough to have any.
(we kid because we care)
rz
Old 04-03-2006, 03:37 PM   #16
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
^- that was on the 5-speed, no?
Old 04-03-2006, 04:05 PM   #17
grippgoat
Member#: 62182
2005 STI
Just don't put redline shockproof in your rear diff. It will hate you.
-Mike
grippgoat is offline   Reply With Quote
Old 04-03-2006, 05:21 PM   #18
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Really, Why not, other than it will hate you?
(.... Ahhh.. You have a clutch type LSD not a VC......)
LyveWRX is offline   Reply With Quote
Old 04-03-2006, 05:35 PM   #19
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
So we have 3 choices, listed in terms of price
1) Valvoline Synthetic 75W90 ($10/quart)
2) Redline Heavy Shockproof ($12/quart)
3) Motul FF ($25/quart)
edit: I talked to another rep from Redline for a while, this guys seemed to know a lot more about racing fluids. For my problem he 100% recommended a 75W90NS/75W140NS mixture. He said that their shockproof fluid, as well as the RP Max Gear contains 5% friction modifiers. While helping clutch differentials, these friction modifiers will do nothing for my front helical diff in the STi and will actually cause the synchros a little longer to synch up. Their NS fluid doesn't contain those friction modifiers, so the synchros should link up quicker and not grind. Interesting.
-Tom
Old 04-03-2006, 06:43 PM   #20
dch
Member#: 1057
2004 WRX STi
Very Yellow
I don't remember off the top of my head, but shipping was as much as the B373 and it's NOT cheap for sure. Yes, I have a dogbox and EMCD. The EMCD used to chatter and make all kinds of unhappy noises when we tried "regular" gear oil. The B373 makes it all happy.
And thanks Randy, I only tease the people I like, too. Or the really stupid ones... Hey wait a minute!
Cheers,
-Doug
Old 04-03-2006, 07:39 PM   #21
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Originally Posted by Subie Gal
ding! ding! ding!
Jamie
Jamie, so you agree that Redline Heavy Shockproof (RHS) is a good transmission fluid? Do you use it in your 5 speed? Please help educate me... Does the DCCD in the 6 speed share the same lubricant as the transmission? So is RHS a good lubricant for the DCCD too? So is it a good differential lubricant for all the STi diffs too?
Tks...
STirocket is offline   Reply With Quote
Old 04-03-2006, 08:55 PM   #22
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I also got a vote from a Subaru Mechanic to run the factory "Extra-S" fluid.
Gah, decisions.
-Tom
Old 04-03-2006, 09:37 PM   #23
Sir_Xenon
Member#: 9666
02 WRX
Ver. 7 STi swap'd bugeye
ding! ding! ding!
Jamie
Ding, and ding for that too.... very good oil, been running it for a year or so, two winters, very good.
Sir_Xenon is offline   Reply With Quote
Old 04-03-2006, 09:57 PM   #24
Joel Gat, 1.8L
Member#: 32
Hello,
I, too, have heard from people who seem quite knowledgeable, that the factory fluid is the answer to the broken transmission woes.
I believe, but am not certain, that ESX is using factory fluid in their uber-powerful cars. I know dragracing isn't road racing, but they did solve their exploding transmission problems with the OE fluids.
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 04-03-2006, 10:24 PM   #25
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I am autocrossing so it isn't to much of a problem for me, but I want to start doing HPDE's soon, so I'm interested in this thread.
silver arrow is offline   Reply With Quote
motorcycle guys who do you use for insurance H-Dtech Off-Topic 10 12-09-2007 06:00 PM
What do you use for tuning 0% column for non stock injectors? cky211 UTEC 4 07-29-2006 09:59 PM
IT guys- What do you use to monitor your server room environment? beachbum Off-Topic 12 08-03-2004 04:20 PM
subaru front 4 pot brake pads, what do you use for less dust? M32WRXin3seconds Brakes, Steering & Suspension 18 04-13-2004 02:11 PM
Photo Folks: What do you use for workflow? Idjiit Off-Topic 30 12-31-2003 02:50 PM
