Old 04-03-2006, 10:15 AM   #1
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
Default How do I check my MT oil level?
If my gear oil is crystal clear? My gear oil (MolyLube 75W90 synth) is like water. I'm pretty sure I put in between 3.6 and 3.8 quarts, but for like life of me I can't read the dipstick except to see that there is a drop forming on the tip when I pull it out. And frankly, I don't know that I like the way this stuff feels in my gear box. Getting into all gears except first is nicer, but first sucks now. It doesn't want to get into gear at any speed about 2mph, and twice when trying to drop into first at about 5mph (with the clutch fully depressed) it offered very little resistance but grinded bigtime trying to get in... and I was giving it a very light touch.
Asinine is offline   Reply With Quote
Old 04-03-2006, 10:40 AM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
you check it the same way you check the engine oil....
Pull the dip stick out, wipe it off, and stick her in again, and pull out...
then have a look see where on the stick it reached... It helps to be in a well-lit area though..
Oh, and make sure the car is parked on a level surface.... Oh... and I always like to take the reading after the car has been sitting overnight...
Perhaps it is time to try a different fluid? How about Uncle Scotty's cocktail?
Good luck
jigga is offline   Reply With Quote
Old 04-03-2006, 10:52 AM   #3
Asinine
Member#: 55173
with paddles.
You fill your gear box with vodka and see if you can read the dip stick!
Old 04-03-2006, 12:07 PM   #4
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
I had a similar problem when working on an Excursion AT. Clean the dip stick with lacquer thinner and make sure it is dry before re-inserting. When you pull out the dipstick, hold it under a work light and look for the wet/dry line.
jac04 is offline   Reply With Quote
Old 04-04-2006, 05:27 PM   #5
Syncade
Member#: 64883
Good luck
Im pretty sure hes not a retard. Its very hard to read the level on brand new synthetic oil, espically that weight.
Syncade is offline   Reply With Quote
Old 04-05-2006, 08:22 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Now I'm glad I used Lightweight Shockproof/MTL90 blend in mine. No missing that goofy blue fluid...
bluescoobywagon is offline   Reply With Quote
Old 04-05-2006, 11:32 AM   #7
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Your dipstick has a tiny hole in it. If it's full the hole will hold fluid to let you know it's full. At least mine does.
drivin blind is offline   Reply With Quote
Old 04-07-2006, 02:56 AM   #8
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
dunno man... I can read mine pretty easily.... you can see where the fluid reaches on the dipstick, even though the colour differentiation is not there...
Old 04-07-2006, 02:59 AM   #9
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Don;t get me wrong, I'm not suggesting he is retarded or anything
It is hard to read, yes, but the same rules apply though.... It helps to have a bright light overhead though I find....
When Do I Check The Tranny Oil Level? williaty Service & Maintenance 11 12-11-2006 09:57 AM
How do i check my air fuel sensor? rekondyte Newbies & FAQs 0 01-19-2006 03:41 PM
how do i check my battery voltage? Caddy Daddy Off-Topic 50 12-13-2005 07:52 AM
How do I check my cat? AntiochCali Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-25-2004 01:58 PM
how do i check my post count? Imprez Me Newbies & FAQs 7 11-06-2002 10:18 PM
