Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 04-03-2006, 03:30 PM   #1
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Default Headlight removal
Ok, I tried searching, and came up empty handed.
I need to remove both my headlights on my 96 legacy (one piece units), and the last time I tried I was horribly unsuccessful. What happened last time is, after I removed the three bolts that hold the assembly on, the light was being held in near the corner lamp. I could move the assembly around quite a bit, but could not remove it entirely.
Is there a clip or something over there that holds on to the assembly? Do I have to unhook the turn signal wiring from inside the fender to pull out the headlight? I thought I was told you could remove the headlight for an easier turn signal bulb replacement, but that would mean the wiring stays attached. All I know is, thursday is my window of oppurtunity to get my bumper off and get everything done, but the first step is getting the lights out.
By the way, chiltons is very ambiguous with this process, since they wrote it up for the 98+ two piece lights. Thanks for looking.
Plays_With_toys is offline   Reply With Quote
Old 04-03-2006, 03:37 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
There was a thread about this recently, but I don't remember any good key words to find it. I believe Wiscon_Mark gave they key element on how to remove them. I'm sure he'll chime in soon
fibuz
fibuz is offline   Reply With Quote
Old 04-03-2006, 08:28 PM   #3
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Hiya.
Yes, I did state how it was done. (I already posted on SLi, but for the good of the forum, I won't tell you to search )
Now, you have all (3) 10mm bolts off, there are no more bolts. However, there is a grooved bar that is located on the headlights behind the corner light (this is the 1 piece headlights, btw) that keeps the headlight aligned to the body. You have to pull/tug/wiggle it out, but it will come, it certainly feels like it is in there good, but it will come
Wiscon_Mark is offline   Reply With Quote
Old 04-03-2006, 08:42 PM   #4
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Yeah, after the bolts are removed, it needs a good tug from the signal light area - straight out.
aross is offline   Reply With Quote
Old 04-03-2006, 08:49 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
yes, straight out.
Old 04-03-2006, 09:03 PM   #6
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
ok........ Thats what I did with the grill and I snapped some stuff... I'll take your word on this one though...
WOOHOO! I'm really excited to mount up my fogs. And I'll be getting pics lickity split of the setup. Thanks for the responses.
(search: headlight, remove, removal, head light, take off, uninstall, headlamp)
Old 04-03-2006, 09:20 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
yeah, as long as you have both harnesses and the 3 bolts unplugged, you won't break anything (unless of course you launch your headlamps into a brick wall when you pull them out )
Gc8 headlight removal. AlbanianImpreza Interior & Exterior Modification 2 04-20-2005 12:05 AM
Headlight removal!!! HELP!! XS_WRX General Community 2 07-09-2004 05:32 PM
have to re-aim headlights after headlight removal? ASpec818 Electrical & Lighting 3 02-09-2004 09:28 PM
need help! headlight removal ton1179 Interior & Exterior Modification 9 11-13-2002 04:03 AM
Headlight Removal T-WRX Interior & Exterior Modification 2 09-22-2001 06:35 PM
