Old 04-03-2006, 05:32 PM   #1
3rdTimeOffender
Member#: 53764
2013 Impreza Sport
Default Drivetrain or Suspension Problem??
Okay I have a 5-speed MT in a 99 Legacy. I had a horrible clicking/clunking sound when pulling into a parking space. Basically with the wheel turned left or right there is a bad sound either in the suspension or the transmission. I figured it was just my CV joints and decided to replace the axels since I had 116k miles on the vehicle. But nope didn't fix the problem. Does anyone have any suggestions what this might be? I have looked at everything in the suspension components while I had the car on the lift but I ddin't notice anything. Any suggestions would be helpful before I go to the dealer. I usually like to fix these things myself.
3rdTimeOffender is offline   Reply With Quote
Old 04-04-2006, 11:02 AM   #2
Trin_Starr
Member#: 102416
1995 Legacy L
red
might be your lower control arm bushings are busted
Or is your car lowered?
If so, mine was making a grating clunking noise whenever I turned into a parking space.
It turned out to be that the top spring perch was not aligned properly with the bottom perch that resulted in the noise...
Trin_Starr is offline   Reply With Quote
Old 04-04-2006, 11:07 AM   #3
3rdTimeOffender
Member#: 53764
2013 Impreza Sport
Completely stock car. I am really thinking that the problem is in the center diff which is inside the transmission on my 5-speed MT.
Old 04-04-2006, 02:52 PM   #4
blueb3
Member#: 108471
How many miles? It might be a worn strut bearing? Had that issue with my previous car.
blueb3 is offline   Reply With Quote
Old 04-06-2006, 11:25 AM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Question
What exactly is a strut bearing?
Do you mean strut mount? Sometimes calles a top mount or tophat?
KD7000 is offline   Reply With Quote
Old 04-06-2006, 11:53 AM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Up front the strut top mounts have a bearing plate. I believe this is what he is referring to.
Did it start after you had the axles replaced? If so it is probably a ball joint. The mechanic or yourself would have needed to seperate the ball joint from the control arm to get the axle out. It could have gotten damaged in the process. However broken ball joints don't normally show their faces until you get going a little faster. With that you would feel a lot of steering wheel shake and front end vibration. As well as some pretty good clunking as you turn while at speed.
Another area to look at are the wheel bearings up front. If they blow out you can get symptoms anywhere from a slight chirping squeek at lower speeds to a full on rhythmic grind.
Take it to a Tires Plus if you have one in your area. They do diagnostic and appraisals for $20.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 04-07-2006, 12:02 PM   #7
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Right, but I've never heard of anyone seperating said bearing from the rest of the mount. If something has gone bad in there, you normally replace the entire mount.
Shops or forum member in Central Jersey to fix suspension problem the HKIC Tri-State Area Forum 7 09-24-2009 03:56 PM
STI suspension problem or feature? padams64 Brakes, Steering & Suspension 17 04-17-2004 12:55 PM
Suspension Or Tranny Problems blackbeast Warranty Issues & SOA Problems 0 04-27-2003 11:57 PM
Suspension problems! Back end is unstable. shutters left or right??!!!??? Rallyspec Brakes, Steering & Suspension 9 01-28-2002 06:13 PM
