Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-03-2006, 07:23 PM   #1
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default I have a question....
What is the plate with the flexible rubber center section mounted right above the center front crossmember jacking plate?
I think it may be a there to put force on the front swaybar when it loads up but I'm not sure.
ss
subysouth is offline   Reply With Quote
Old 04-04-2006, 03:06 AM   #2
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
i can tell you what it is NOT there for, better than I can tell you what it IS there for...
janikphoto is offline   Reply With Quote
Old 04-04-2006, 08:57 AM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
[edit]
Looks like you’re talking about the tranny crossmember assembly?
The tranny crossmember is 3 individual pieces, a front, a rear, and a center which holds the two halves together via “cushion rubber” mounts where they connect. Also on the front of the tranny crossmember assembly is a "dynamic damper" which looks like a little rubber door-stop or something. I imagine this is what you're talking about? No idea what this does other then “Dynamic Dampening”…
xcntrk75 is offline   Reply With Quote
Old 04-04-2006, 09:31 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Reduces NVH, thats all. Its a good weight saver if you're stripping down a race car (just like the one under the engine )
Old 04-04-2006, 09:38 AM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yea if its what I am picturing its exactly what Anthony described.
Ben
Old 04-04-2006, 06:16 PM   #6
janikphoto
Member#: 10471
2000 BMW Z3
well, it it was tossed to save weight, you had better be building a race car. without all that extra dampening, your car would not feel too cozy on long road trips!!!
Old 04-04-2006, 06:21 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I guess it could be the frontmost tranny crossmember but its also the engine mount crossmember. Its under the joint where the engine mates with the tranny.
There a relatively square jacking plate on the bottom of the engine/tranny crossmember. This piece in question is sandwiched between that jacking plate and the bottom of the crossmember. Its right below the front swaybar and steering rack. I cant really see how its dampening vibration as the jacking plate is solid steel and spanning the same exact space but I dont know.
ss
Old 04-04-2006, 10:50 PM   #8
skunkfifty
Member#: 73102
1998 legacy outback
white
ss
i know the one you're talking about. the rubber square under the frontmost jack plate. its there to dampen vibration, i thought it wouldnt do much until i took mine out, it does make a noticable difference.
i read about it on a page, i dont remember for what, i think it was an install how to for katboy shifter bushings, or maybe a primative racing skid plate. if you use the car for comfy riding and such, i'd leave it in. taking it out doesnt make the ride any different, but it keeps something from vibrating that was annoying to listen to (at least in my case)
skunkfifty is offline   Reply With Quote
Old 04-04-2006, 11:00 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Mine's gone, didn't make any difference at all as far as I could tell.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-05-2006, 09:20 AM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
So you guys are talking about the plate which spans the engine crossmember, with the steering rack and sway-bar underneath right?
Mine BD never had one of these rubber things. Only the one on the tranny cross-member assembly.
I wonder if this is a manual tranny related thing?
Old 04-05-2006, 09:24 AM   #11
skunkfifty
Member#: 73102
1998 legacy outback
white
i was surprised that i did. i read that it makes no difference, so i took mine out.
however i also put on an aluminum front skid plate, i'm guessing that had something to do with the noise that cropped up.
Have to see the BAR Referee & have some questions STI05 Southern California Impreza Club Forum -- SCIC 17 03-10-2010 12:58 AM
I have a Rear sway bar, I have a question about the front WRblueX_Guy Brakes, Steering & Suspension 3 03-15-2006 02:41 PM
Anybody in the SE have Prodrive Headlights.I have a question enewtabie South East Region Forum 3 02-26-2004 10:08 PM
I don't see much about Whiteline springs anymore, I have them & have a Question Drew888 Brakes, Steering & Suspension 2 09-18-2003 12:15 AM
I do not have Subaru but I have a question to Tire Rack guys krzyss Brakes, Steering & Suspension 2 02-27-2002 06:11 PM
