Old 05-07-2006, 09:05 PM   #1
gc835
Member#: 78080
2001 impreza
red biatch
Default na sohc build up
ive been tossing a few ideas about building up the na engine in my 01 rs. i would be looking to make about 250+ whp with a 8000 rpm limit. i know i know for the $$ wht not go turbo but i have 2 other cars that are turbo and you have to admit that 8000 rpm na subie would be pretty cool. i would replace the block, if needed??, pistons up the cr, rods and crank. would like a long stroke. i would use the sohc heads but get them p+p cams,springs ret, etc. and i would probably run it all on a hydra. i would be beating this thing pretty hard and would want the highest cr possible for 93 octane.would the stock block be ok?? what crank and rods?? any and all ideas and opinions wanted
gc835 is offline   Reply With Quote
Old 05-07-2006, 09:17 PM   #2
970subaru
Member#: 45703
build some ITB's
there are a few fuel injected snowmobiles or jet skis 2cyl that would work, or you could split a set of 4cyl bike ITB's from a busa or the like. busa bodies are like 46mm. they have a TPS on em too.
think of how bad ass that would sound and the crazy throttle response!!! get some sweet velocity stacks too.
these would be perfect, look how they split apart.
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
970subaru is offline   Reply With Quote
Old 05-07-2006, 10:04 PM   #3
gc835
Member#: 78080
2001 impreza
red biatch
me and my boy where discssing that the only thing was tps and throttle linkage
Old 05-08-2006, 12:19 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
ITB's being done --> http://forums.nasioc.com/forums/showthread.php?t=961467
You'll want to worry less about the block/motor and more about the heads. In an NA motor, the power is ALL about air delivery.
8Complex is offline   Reply With Quote
Old 05-08-2006, 01:59 AM   #5
970subaru
Member#: 45703
I would be more concerned about manifolds, throttle linkage is simple to make and all EFI bikes have a TPS. or I bet you could even adapt the stock one.
of course this kind of **** takes some doing.
Old 05-08-2006, 02:39 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
While you're at it...use the EM for the injected bikes.....Crazy stuff! I love it!!!!
Storm is online now   Reply With Quote
Old 05-08-2006, 11:34 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you pull it off, you will be the first person to do it. Zzyzx'z car put down something like 230whp on a dyno that had stock STi's at the same whp. But then maybe if you get a more "friendly" dyno you can pull it off. Search prooven power for Zzyzx's build and story...
Old 05-10-2006, 10:09 AM   #8
gc835
Member#: 78080
2001 impreza
red biatch
well i was thinking maybe picking up a 257 block with nothing in it a filling with the proper stuff. having it balanced to like 10k just to be safe. then getting the heads done to the extreme and put a pretty beeefy set of cams in it with springs , ret. run the stock intake man with a tb spacer and a ported tb. and tune it for 93 and see what i get and go from there. i just got another set of empty sohc heads so im gonna send them out to either cosworth or ??? suggestions welcome. right now im waiting for a clutch to install my 6 speed and 180
Old 05-11-2006, 04:22 PM   #9
Boost-Free Subee
Member#: 61052
1999 2.5 RS
http://www.techworkseng.com/Packages...e_Packages.htm
2.35L screamer short block (N/A) for the bottom end.
plus,
http://www.techworkseng.com/Packages...d_Packages.htm
stage II heads for the top end.
perfect power 6 or equivalent EM, WRX injectors and fuel pump, plus modified fuel rails to work with the injectors.
Already had this discussion with a previous employee of TWE, as well as Sam @xccelleration.com about the same setup for my car. I went with the heads for now, but am drooling over the de-stroked shortblock. Shortening the stroke will create a more rev-happy rod/stroke ratio. So, even though the displacement will go down, there will still be lots of power. when you want to go to 8000 rpm, you will most certainly have to give up some low end to get there.
Boost-Free Subee is offline   Reply With Quote
Old 05-11-2006, 09:45 PM   #10
gc835
Member#: 78080
2001 impreza
red biatch
awsome stufff thanks
Old 05-17-2006, 04:22 PM   #11
gc835
Member#: 78080
2001 impreza
red biatch
bump!!!
Old 05-21-2006, 07:38 AM   #12
LegacyJones
Member#: 48791
02 bugeye
wagon
I have a set of TWE valve springs and ret 4 sale.
LegacyJones is offline   Reply With Quote
Old 05-21-2006, 02:57 PM   #13
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
If your trying to stay N/A and get that kinda power. Why not go even more exotic and build an N/A EZ30-R or EG33?
Seems like a stock one would be closer to your goals, even in stock form. Granted it won't rev to 8k but you should be able to extract 250whp from it.
DoctorNick is offline   Reply With Quote
Old 05-22-2006, 03:11 PM   #14
gc835
Member#: 78080
2001 impreza
red biatch
mmmmmmmm ive just started to research this
Old 05-23-2006, 10:26 PM   #15
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Wayne_Coots is offline   Reply With Quote
Old 06-08-2006, 08:31 AM   #16
GetSideways
Member#: 44665
03 wrx sedan
platinum
gc835.....You read my pm's and dont respond it has been 2 weeks......have you shipped my utec yet?!?
GetSideways is offline   Reply With Quote
Old 06-08-2006, 10:27 AM   #17
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
The 257 block in my opinion would be a necessary upgrade for 8k rpms. I just don't see the cylinder staying in place for a very long time at that rpm on a fully open deck 25. Especially with high compression.
Or you could consider a super high compression 22t turbo block thats been stroked. O-ring, Head Studes and run a good mixture of methanol or ethanol and you should be able to bump compression up above 11:1.
MY99 2.5GT is offline   Reply With Quote
would you rather... turbocharge, supercharge or NA build up wop Normally Aspirated with bolt-on Forced Induction Powertrain 26 06-26-2008 02:35 AM
NA Build up need help HopesAndDreamsRacing Normally Aspirated Powertrain 3 05-28-2007 09:14 PM
Ej22 2.2 NA Build up Info Needed! wildfire Normally Aspirated Powertrain 13 04-25-2005 01:12 PM
Best parts for NA build up Stroke Normally Aspirated Powertrain 7 04-09-2003 04:47 PM
NA Build-up '99 RS Drifter Normally Aspirated Powertrain 5 05-10-2002 03:41 PM
