Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-03-2006, 08:10 PM   #1
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
Default problem with utec need your help
I am having a wierd issue with my utec. I am running the utec on top of the ecutek. Because of the power I am making, anyway I have an issue that just started recently. I am seeing in my utec logs the TPS going to 0% radonmly. Its almost like hitting fuel cut. Only seems to happen under boost.
Here is an example of what I mean:
3293 -4.5 3.0 36 10 00 +44.6 14.1 +20.1 -4.0 375.00 2.6
3220 -4.5 3.0 36 10 00 +44.6 13.8 +20.0 -4.0 375.00 2.6
3306 -3.0 3.2 45 10 00 +43.2 14.7 +20.2 -4.0 375.00 2.6
3390 -1.2 3.2 59 10 00 +41.9 16.8 +20.6 -4.0 375.00 2.6
3479 +0.4 3.4 65 10 00 +41.1 18.6 +20.8 -4.0 375.00 2.7
3671 +1.7 3.4 70 10 00 +40.2 20.7 +21.0 -4.0 375.00 2.9
3675 +2.3 3.5 70 20 00 +39.6 22.7 +18.0 -4.3 375.00 3.0
3762 +3.1 3.5 73 20 00 +36.8 25.4 +18.0 -4.9 375.00 3.0
3858 +4.1 3.6 79 20 00 +35.8 29.8 +19.2 -4.7 375.00 3.1
3940 +5.3 3.8 81 30 00 +34.0 32.3 +20.0 -5.0 375.00 3.2
4120 +7.0 4.0 81 40 00 +31.4 35.6 +20.2 -6.8 375.00 3.3
4295 +8.8 4.3 82 50 00 +28.7 40.4 +19.7 -8.6 375.00 3.4
4474 +11.3 4.5 79 60 00 +27.0 46.0 +18.5 -11.6 375.00 3.5
4721 +14.7 4.7 71 70 00 +25.2 54.8 +18.8 -11.1 375.00 3.5
4901 +17.6 5.0 70 80 00 +24.4 63.4 +19.9 -10.0 375.00 3.8
5257 +19.8 4.8 65 80 00 +25.2 63.6 +21.0 -9.1 375.00 3.9
4967 +21.2 4.8 61 80 00 +27.7 64.3 +27.6 -9.1 375.00 4.4
5592 +20.8 5.0 56 80 00 +26.0 62.6 +21.7 -7.6 375.00 3.9
4873 +16.6 2.0 1 00 00 +23.4 59.3 ECU. -3.0 ECU. 1.7
4374 +8.8 4.5 1 00 00 +23.6 59.3 ECU. -2.3 ECU. 3.5
3921 +0.4 3.5 1 00 00 +23.7 59.3 ECU. +0.2 ECU. 2.9
3483 -7.3 2.9 1 00 00 +23.6 59.3 ECU. +2.0 ECU. 2.4
4100 -11.2 2.3 11 00 00 +29.6 7.6 ECU. -1.9 ECU. 2.2
4060 -11.8 2.6 13 00 00 +44.4 11.1 ECU. -0.8 ECU. 2.2
4030 -11.8 2.2 12 00 00 +36.9 7.8 ECU. -1.1 ECU. 1.8
3958 -12.0 2.2 9 00 00 +40.5 7.9 ECU. -0.8 ECU. 2.0
3987 -12.4 2.4 9 00 00 +40.7 6.7 ECU. -0.5 ECU. 2.0
2878 -4.5 2.8 30 10 00 +43.4 12.8 +21.8 -4.0 ECU. 2.4
2858 -4.5 2.8 30 10 00 +44.2 11.1 +21.5 -4.0 375.00 2.4
3033 -3.2 3.0 36 10 00 +44.8 12.6 +20.0 -4.0 375.00 2.5
Any ideas?
thanks,
Dan
dlowman is offline   Reply With Quote
Old 04-04-2006, 01:52 AM   #2
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Code:
I see that you max out ur MAF twice and your mod maf volt looks lean too.
What is your A/F?
Maybe this cause your TPS went back to 0 because ur ECU think something was wrong and dangerous. Just my 2 cents
WRX-Blue-Mica is offline   Reply With Quote
Old 04-04-2006, 12:42 PM   #3
tmarcel
Member#: 7555
Originally Posted by WRX-Blue-Mica
Code:
What is your A/F?
I noticed that too. I'm not sure if it would be the ECU or not though. Something is weird with it.
tmarcel is offline   Reply With Quote
Old 04-04-2006, 01:06 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
Code:
What is your A/F?
The thing is the stock ECU will not "see" the maxxed MAF.
First try checking the conection on both TPS sensors. One at the TB and one at the peddle.
TMS
TheMadScientist is offline   Reply With Quote
Old 04-04-2006, 01:25 PM   #5
EAkrish
Member#: 108617
2003 WRX
Yellow
you know what, mine did the same thing....... i raised my boost cut and it stopped. not sure if this will help you........
EAkrish is offline   Reply With Quote
Old 04-04-2006, 02:51 PM   #6
TheMadScientist
Member#: 23717
2005 Big red
If I remember corectly, the sti Utec uses the peddle TPS sensor as the TPS reference.
I would start looking there.
TMS
Old 04-04-2006, 08:18 PM   #7
dlowman
Member#: 22998
2004 WRX STi
I found the problem. It appears that the peddle tps sensor was getting too high of a voltage. Was making it read inconsistant. We backed the voltage down from that and it seemed to resolve the issue. Wierd for sure.
The utec doesnt let the ecu see the maf so that wouldnt matter.
Thanks for the help guys, this was a bear to figure out lol
problem with 4eat. need your help! shootsbrah Transmission (AT/MT) & Driveline 4 09-04-2007 08:28 PM
Problems with brakes, need some help. Smoby Brakes, Steering & Suspension 3 05-19-2006 01:18 AM
OT need your help with lower back problems RSimport Off-Topic 19 09-18-2005 10:03 PM
problem with UTEC. need help vipmooneyes Engine Management & Tuning 2 08-28-2005 02:54 PM
I need help with utec logs. PLEASE HELP! dman918 Engine Management & Tuning 3 05-04-2003 02:54 PM
