Old 05-20-2007, 06:51 PM   #26
slvr03wagon
Member#: 85681
03 305awhp
of Bailey tuned goodness
Originally Posted by Valhakar View Post
It is the Cruise control cable. It came from the factory too tight on many of the 03-04s. When looking at the throttle body from the front, it is the cable that loops to the left and attached to a small black box on the wheel well next to the turbo.
This is the issue. As the turbo heats up the area the box/cable deforms and tightens. Loosen the cable to have at least 1/2 of slack while cold and the issue will go away. Do NOT loosen the cable on the right as that is the actual throttle cable.
-Dave
Just wanted to thank you for this tip. It seems to have totally fixed my high idle. My 03 wrx would start to idle fast during stop and go situations (only during hot months). It would go all the way to 2500 rpms and wouldnt chill out until I got a mile or so down the road with normal at speed driving.
slvr03wagon is offline   Reply With Quote
Old 05-20-2007, 10:06 PM   #27
Roy
Member#: 32241
1998 Impreza L Coupe
white
Checked with my son. He says the fast idle problem has been fixed. No trouble since I adjusted the cruise cable to have more slack.
Glad to see the "fix" has worked for others also.
Roy
Roy is offline   Reply With Quote
Old 05-21-2007, 12:30 PM   #28
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Yea, mine used to spike up ove 3k rpm on hot days in stop and go traffic.
No issues sonce I loosened the cable.
I also took up any remaining tension in my throttle cable while I was there.
skimobile is offline   Reply With Quote
Old 10-19-2009, 01:57 PM   #29
AsILayDying
Member#: 198985
2004 WRX
does anyone have a pic of exactly which one is the CC cable, just want to make sure Im adjusting the correct one. I know its a dumb question, but it would be even worse if I ended up adjusting something else and then had to figure that out. So thanks for the help.
AsILayDying is offline   Reply With Quote
Old 10-19-2009, 02:03 PM   #30
Haelan
Member#: 151045
2013 Subaru STI
CBP
Trace the cable from the throttle body to the small black box by the passenger side strut tower. That is the cruise control cable.
Haelan is offline   Reply With Quote
Old 10-19-2009, 03:11 PM   #31
partingwrex88
Member#: 170879
2002 impreza wrx
Sedona pearl red
-Dave
you are right valhakar, i used to have an 04 and the same problem. Once i loosened the cruise controll throttle cable everything was fine
simple as that...just like that dreaded pcv valve
partingwrex88 is offline   Reply With Quote
Old 10-19-2009, 03:21 PM   #32
krk206s
Member#: 27065
2004 WRX
OT, but what's the PCV value issue?
krk206s is offline   Reply With Quote
Old 10-19-2009, 03:25 PM   #33
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
its the cable - put some slack in it
BONFIRE074 is offline   Reply With Quote
Idle jumping high in stop n go traffic ReDHaTyGuY Newbies & FAQs 11 06-05-2009 09:45 AM
shift fork gets loose when car is in stop and go traffic? rougeben83 Transmission (AT/MT) & Driveline 3 06-02-2009 12:21 PM
How do you drive in stop and go traffic? Ken Off-Topic 49 09-26-2007 01:56 PM
high engine idle after stop & go traffic nocturn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-14-2005 11:52 AM
stop and go traffic for miles on end -- arrival of smelly clutch Xymox Newbies & FAQs 20 08-25-2005 03:56 PM
