#1 |
Vendor
Member#: 69072
I am here to answer any questions you may have about the kits...
#2 |
Member#: 75129
Vehicle:09 WRX stg 2+ Lost the boxer rumble |
I'm interested in the stg2 MAF boost cooler system , I'm currently running a turbo xs stg 4 setup tuned by turbo xs My boost is 20.5 on my dyno map and 19.5 on my daily driver map, When the car was tuned I had a octane boost that contained meth and some variation of alcohol If I run straight 93 i'll get knock because my timing is advanced some. im wondering if I just got a basic kit to help with detonation , then get it tuned more aggresively later on.
Any help?? |
#3 |
Vendor
Member#: 69072
You could run the kit and spray a very small amount and it will probably help out your situation but you really need to be tuned for alcohol injection. When I through my kit on and started tuning my afrs they went from 11.3 to 10s and 9s at places.
#4 |
Member#: 60691
is it safe to use the intercooler spray reservoir in the trunk of the sti
as the methanol storage for striaght meth? i see alot of people doing it but dont know how safe it is. thanks |
#5 |
Vendor
Member#: 69072
Yea it is perfectly safe to use that tank for a resevoir. I run my stock windshield washer tank in my trunk of my evo for mine. There is always a slight danger to having methanol in your car no matter where it is but keeping it in your trunk is probably the safest place for it in your car. A great alternative is to you use 50/50 mix as it is much less corrosive and dangerous and the power gains are great from it.
#6 | |
Member#: 75129
Would there be any benefit to running 90% water 10 % alcohol for my situation, I'm trying to avoid paying another fee for tuning, but I do realize if you want to play you gotta pay.
#7 |
Vendor
Member#: 69072
Even with water injection you would still need to be tuned..
#8 |
Member#: 42564
Vehicle:2002 wrx black |
In the stg2 MAF boost cooler system, will it work ok if it is a blow through MAF system?
#9 |
Vendor
Member#: 69072
Yes, it just reads maf voltage and sprays according to that in a linear pattern. Like say you have it start at 2v and have it max at 4.5v.
#10 |
Member#: 102948
Vehicle:2006 STI |
I just came across this GB - seems like an awesome deal. http://newcelica.org/forums/showthread.php?t=206730
#11 |
Vendor
Member#: 69072
Don't worry bout that
Just pm me if your interested in a kit... |
#12 | |
Member#: 75129
Does that go for me too ?
#13 | |
Member#: 102948
Vehicle:2006 STI |
PM sent - I would always rather support a forum vendor. |
#14 |
Vendor
Member#: 69072
Yea, I pmed you back, I was told one thing by snow and I guess someone else is selling cheaper so guess what (my prices will be cheaper...)
#15 |
Member#: 76110
Vehicle:2005 STi Silver |
Is it a fact that you cannot run 100% methanol with the pump you guys provide?
#16 | |
Member#: 48503
Vehicle:2004 STi ATP3071 Silver |
Obviously tuning is far preferable, but if you plan to get injection and a tune in the long run, it certainly can't hurt to try out a small injection and see if it helps. The success may depend in part upon the ECU's ability to adjust. I think a UTEC setup (which I'm guessing you have) may be less likely to learn than an AP (which I have). Just make sure you're not injecting much. Not to rain on the Snow parade, but a CoolingMist system might even be better because you can programmatically adjust the flow rate of the injection nonlinearly, which, especially if you're not getting tuned would be an advantage. |
#17 | |
Member#: 62211
South East
Vehicle:03 WRX Sonic Yellow |
And any limit? ![]() |
#18 |
Member#: 41227
TXIC
Vehicle:2005 Legacy 2.5GT Garnet Red Pearl |
What are the advantages/disadvantages of the MAF Variable Controller vs. Variable Controller?
#19 |
Vendor
Member#: 69072
It depends on who you talk to about which controller is better, I personally like the map controller as its very easy to install and set and for me works great on the evo. The maf also works great and runs off maf voltage. I guess it depends how much whp you are pushing because if you start flowing more than your maf can handle then you alky will not be spraying the proper amount needed at times. On my evo I am pushing just under 400whp which is the limit of the stock maf so I went with the map kit just to be on safe side. An advantage of maf is that it can give you a more accurate spray for those of us that use faster spooling turbos.
#20 | |
Vendor
Member#: 69072
#21 | |
Member#: 41227
TXIC
#22 |
Vendor
Member#: 69072
I am currently working with Snow to develop a suby specific kit which will have option for this as well but the ETA is unclear at this point.
#23 |
Member#: 89995
Vehicle:05 Broke STI |
this is very tempting
#24 | |
Vendor
Member#: 69072
#25 | |
Vendor
Member#: 69072
I just picked up another 39 gallons today ![]() |
| Thread Tools | |
| Display Modes | |
| Aquamist (Water injection) questions and answers here... | Richard L | Water/Methanol Injection, Nitrous & Intercooler Cooling | 3712 | Yesterday 02:01 AM |
| Passing the NEW required OBDII Emissions test in PA Questions and Answers!! | mrtrex | Mid Atlantic Impreza Club -- MAIC | 29 | 03-10-2013 07:23 PM |
| snow performance questions | map450 | Water/Methanol Injection, Nitrous & Intercooler Cooling | 1 | 12-27-2008 10:37 PM |
| Snow Performance questions... | japslapr | Water/Methanol Injection, Nitrous & Intercooler Cooling | 3 | 09-10-2006 03:44 PM |
| Roll Center, questions and answers | Arnie | Brakes, Steering & Suspension | 5 | 12-21-2004 03:26 PM |
