#1 |
Member#: 69170
Does Hydra control engine's idle and low-rpm operation via close-loop control?
If so, which control scheme are you guys using? OL or CL?
#2 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
You can use whatever you want, OL or CL.
#3 |
Member#: 54918
The Element Hydra EMS has a number of closed loop fueling options:
Closed loop "14.7:1 AFR" utilizing the OEM rear 02 sensor. This is definable with a start and end rpm plus a load range within vacuum. Closed loop "14.7:1 AFR" utilizing the Hydra WB 02 sensor. This is definable with a start and end rpm plus a load range within vacuum. Closed loop "Wideband Target Table" utilizing the Hydra WB 02 sensor. This is definable with a start and end rpm plus all load ranges including boost. The target AFR is defined by a 32x32 ""Wideband Target Table" so you can decide what AFR you want to run for a given load and rpm. Closed loop/AutoTune "Wideband Target Table" utilizing the Hydra WB 02 sensor. This is definable with a start and end rpm plus all load ranges including boost. The target AFR is defined by a 32x32 ""Wideband Target Table" so you can decide what AFR you want to run for a given load and rpm. The difference here is that this alters the fuel map permanently by tuning the fuel table until the AFR matches those set in the "Wideband Target Table." Whatever is outside of either your rpm range or load range is then open loop fuel control. Thanks, Phil www.elementtuning.com |
#4 |
Member#: 69170
Thank you Phil for your answer.
So I need an optional Hydra WB O2 sensor for the type 2-4 close loop control. Question for Type 3 CL. To make it a real Close Loop control, the ecu has to constantly adjust AFR using feedbacks from Hydra WB O2. Can the system (as a whole) adjust AFR fast enough in higher rpm range? |
#5 |
Member#: 87446
NWIC
Vehicle:2005 STI 3 second start club |
How 'high' of an rpm range are you looking for it to remain CL?
I've had mine set at 4300rpm (based on the setup guide) and observed it using the STT (short term trim i'm assuming) to keep it right near 14.7 and after Phil tuned it he set it at 3800 rpm for various reasons... |
#6 | |
Member#: 54918
For tuning purposes the "Autotune" rate can be defined based on rpm. The higher the value the faster and more aggressive the "Autotune" system can react to off target AFRs. So for tuning purposes the “Autotune/closed loop” can be fine tailors to react quickly to substantially off target AFRs but to use “Autotune” your laptop must be connected. Thanks, Phil http://www.elementtuning.com |
#7 | |
Member#: 54918
#8 | |
Member#: 69170
Reason I ask about this topic is bacause I want fuel economy from CLF and power from OLF when i step on it. Thanks |
#9 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
It can be either sensor for closed loop. Running closed loop will target an AFR of 14.7.
Running in Autotune all the time (not practical with a laptop plugged in) will target whatever AFR is in the Target Table. You need a wide band to run in Autotune. Low RPM, (idle) is controlled by at PID feedback loop coupled to a min/max PWM. This is not a UTEC with all the open loop/closed loop transition crap. |
#10 | |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
I would use the Hydra WB O2 to tune your Open Loop fuel maps, after you've got it all dialed in, then take it out and switch to using the rear O2 sensor for CLF. I would do it this way because WideBand O2 sensors are known to have much shorter lifespans compared to regular O2 sensors. |
#11 | |
Member#: 54918
| Thread Tools | |
| Display Modes | |
| Does Hydra have CL boost targeting? | Nixlimited | Other Engine Management | 17 | 12-08-2006 02:19 PM |
| Closed loop / open loop controlled by throttle position sensor? | boxxxer | Engine Management & Tuning | 9 | 05-16-2005 12:12 PM |
| What exactly is closed loop vs. open loop fuel control? | Neek | Engine Management & Tuning | 5 | 03-09-2005 12:50 AM |
| Does Link have a launch control? | neversatisfied | Engine Management & Tuning | 6 | 05-21-2004 05:44 AM |
| What does closed loop/open loop mean? | FuJi K | Newbies & FAQs | 4 | 04-22-2004 07:19 PM |
