Old 04-04-2006, 12:31 PM   #1
tomdewing
Member#: 102056
Default EJ20h wiring
Does anyone have a wiring diagram or ecu pinout for a JDM EJ20h ? It came out of a 1996 Legacy. pictures on http://www.tomdewing.co.uk.
I am trying to put it into a hovercraft I am building but it is turning out to be an uphill battle and the hill is steep! I think I have most of the components now, I have the main firewall harness , but that still leaves lots of wires going from the ecu to the smj that I need to connect - including MAF sensor, Crank & cam sensors, solenoid box and others!
Any info anyone has would be greatly apprecieted!
tomdewing is offline   Reply With Quote
Old 04-04-2006, 12:52 PM   #2
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
to make it even worst. that wirin diagram is impossabl to find. i looked for about a month with no luck.
Thats the only poblem w/ the EJ20H. the wiring diagrams are not available...
snowman4us is offline   Reply With Quote
Old 04-04-2006, 01:02 PM   #3
tomdewing
Member#: 102056
great! I have a pinout in japanese if anyone can translate - the online translators dont cut it! what was your solution?
Old 04-05-2006, 01:20 AM   #4
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
i ended up using my stock 94 impreza harness.
Sense most of the sensors are already on the 1.8 harness, i replaced the ej20 harness w/ a ej18 harness in the engine. however sense the 1.8 doesnt have COP igniton, i had to add ignition wires, a wire for the TPS, and add all the wires for ignitor/ignition module, and for the MAP sensor, Pressure exchange solenorid, and the WG controll. Its all straight forward, after that you just need to add a couple of grounds, and ill work.
Old 04-05-2006, 08:35 AM   #5
tomdewing
Member#: 102056
which ecu did you use? presumably the 94 ecu will not run the ej20h? do you have a pinout for the ecu?
Old 04-05-2006, 10:58 AM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
well i was in a little diff. situation then you.
I had a EJ20G w/ a EJ20G ecu, however i didnt have a EJ20G harness. So i bought a Ej20H harness, to only find out that its quite diff. from the EJ20G harness that i needed.
And what pinouts do you need? the info i used was off this website http://www.northursalia.com/modifica...ng/wiring.html ,i had to do a bit of prep work and a good amount of homework before i actualy got to the wiring part of it. It took me about a week to get all my wiring done, but i had to figure some things as i went. The 1st time i tried to start the car, it wasnt pritty. After having some issues i started trouble shooting and all the other fun stuff. all in all i spent about a week and a 1/2 on wiring alone. Be prepared to get frustrated if you do it this way, if you have basic knowledge of electrical it wont be hard to figgurt it out. Try to get a osylascope(sp?) so you can view wave patterns, that things made wiring go by allot faster, and got rid of allot of guess work on seeing if a circuit was working properly.
Old 04-05-2006, 11:08 AM   #7
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
A hovercraft???
tweakling is offline   Reply With Quote
Old 04-05-2006, 03:31 PM   #8
tomdewing
Member#: 102056
yeah I have a reasonable amount of electronic engineering knowledge and an occiliscope, but it takes a lot to work it all out, esp. as I only have half the harness. Reverse engineering the ecu is too time consuming. I have managed to get another japanese diagram (an ecu system i/o) which has proved most helpful. I am still unsure of the pinouts for the three solenoid box plugs, and the plug on the right hand side of the engine if anyone has these appears to be cam and crank sensor amongst others. it would take some working out because I'm not sure which pins on them are power, signal and ground!
Yes a hovercraft! they suggest using the EA-81/82 or EJ22 NA but I figure give it a little more power and put the EJ20 TT in it and I managed to get a *complete* EJ20h with AT (which I'm not using) for $800.
*edit: forgot to add - pictures of hovercraft - http://www.tomdewing.co.uk, its a UH-18 http://www.hovercraft.com.
Old 04-05-2006, 09:15 PM   #9
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
to tell you the truth, the electrical is not hard.
Also if your intrested, i have a COMPLETE EJ20H harness, everything is there, all the relays, all the fuses, its 100% complete. if your intrested ill sell it to you. just let me know.
Old 04-06-2006, 12:44 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
tom was the twin turbo sold in the uk .. you might be able to go to the local subaru dealer and order the service manual?
Old 04-06-2006, 03:02 PM   #11
tomdewing
Member#: 102056
not sure about that, im in the us - houston tx. have tried subaru NA but they are not helpfull. can't find an email for uk or aus which is the other place they might have been sold.
my current wiring problem is the maf sensor. anyone know which pin is which? I don't have the plug, I have a pinout and i/o diagram that I have managed to translate so I have found the wires, i just dont know which pins to connect them to. It may have to be a trial and error job but i'm reluctant to do that cos that may break something! the same is true for the MAP sensotr, nk sensor, cam sensor, knock sensor and solenoid box (I have the solenoids sorted because they are polarity independant) but there is a switch in there with 3 pins which I dont know about! anyone got pinouts for any of this?
@snowman4us - I sent you a pm about the harness did you get it? Can you send me some pictures and do you have the front harness - gray smj to solenoid box, rh engine, MAF sensor etc. if so can you trace some pins for me?
EJ20H Wiring kbone21 Pre-2002 Factory Turbo Powertrain 3 06-26-2008 05:07 PM
does anyone have an EJ20h wiring diagram yet looptit Subaru Conversions 1 07-28-2006 12:27 PM
does anyone have an EJ20h wiring diagram yet looptit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-28-2006 01:39 AM
EJ20H wiring diagrams. please help snowman4us Subaru Conversions 2 01-17-2006 12:45 AM
I need a JDM 1996 BG5 ej20H wire diagram lotus2843 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-04-2005 10:15 AM
