Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-04-2006, 03:22 PM   #1
method6980
Member#: 89073
Default Will 03 utec work on 05?
Hey there,
I was looking to purchase a used UTEC. It was used on a 03 WRX i belive it was purchased in 04.
Will it work on my 05? can you DL the latest firmware onto any utec?
method6980 is offline   Reply With Quote
Old 04-04-2006, 04:06 PM   #2
TurbojonLS
Member#: 38772
2 Cars, No Bling
What Revision is the UTEC?
TurbojonLS is offline   Reply With Quote
Old 04-05-2006, 02:09 AM   #3
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
no it will not work..... at least im pretty sure
spoolindc2 is offline   Reply With Quote
Old 04-05-2006, 02:51 PM   #4
method6980
Member#: 89073
It is a version 5
Old 04-05-2006, 04:43 PM   #5
kcook
Member#: 78074
2005 STi
no it will not. u need a rev6b
kcook is online now   Reply With Quote
Old 04-07-2006, 02:35 PM   #6
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
Default utec
will revision 6b will work on any model 00-05
twrx2002 is offline   Reply With Quote
Old 04-07-2006, 08:02 PM   #7
Lost_Pete
Member#: 100570
Yes.
Engineer speak: All versions of UTECs are compatible with all revisions of firmware.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 04-07-2006, 08:12 PM   #8
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
I know how to make it work. If you are wanted to know pm me I'll show you the steps.
gaby is offline   Reply With Quote
Old 04-08-2006, 01:48 PM   #9
Berts_Wrx
Member#: 99963
2005 WRX
obsidian black pearl
I Have A 02 Wrx Utec On My 05 Works Fine Just Throws A Check Engine Light Because The 05 Comes With A Pcv Valve Sensor And The 02-03 Models Dont Other Than That I Have No Problems
Berts_Wrx is offline   Reply With Quote
Old 04-10-2006, 10:45 AM   #10
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
ok heres the problem, i installed it hooked up everything except the abc because the hex key fitting is stripped. so i have my mbc for now, i also hooked up the remote switch and everythign seems to be working when i look at it through hyperlink the maps do change, i loaded stg1 stg2 stg3 from the txs site but i feel no difference between the maps, over all i feel a difference even when the switch is on 0, but as i change it feels just is it was on 0, any thoughts? thanks guys
Old 04-10-2006, 12:29 PM   #11
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
What stage should you be running?
Crazykev is offline   Reply With Quote
Old 04-10-2006, 12:45 PM   #12
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
stg 2
Old 04-19-2006, 01:15 AM   #13
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
At this point most of your power gains will be found by tuning boost. You won't be able to feel much of a change if you just manipulate AFR and timing. A dyno could show you a few hp here or there, but the butt-dyno isn't calibrated well enough.
eastcoastbumps is offline   Reply With Quote
Old 04-19-2006, 12:47 PM   #14
tmarcel
Member#: 7555
I don't agree with that Most of the time the base maps are so rich and run minimized timing that the car can feel transformed by tuning those variables. No dyno needed to feel the added torque and power. For example, tuning from a rich 10.0:1 up to 11.3:1 or so makes a significant difference that you will feel. Also, adding timing will really make it more lively.
tmarcel is offline   Reply With Quote
UTEC REV 6, will it work on 05 WRX REDWRX05 UTEC 1 03-13-2009 05:49 PM
will 05 utec work on an 06??? cbourbs UTEC 2 07-08-2008 07:53 PM
will 04/05 Sti UTEC work on 06 STi?????????? All4bSpinnin UTEC 7 08-08-2006 02:48 PM
will a version1 utec work on an 03 ecu Sharky NRK Engine Management & Tuning 0 10-24-2005 12:15 AM
I have sold my UTEC so I will not be working on Autologger any more... LiquidForce Engine Management & Tuning 28 07-24-2004 01:08 AM
Message Board Statistics All times are GMT -4. The time now is 01:51 PM.
