05-22-2001, 01:17 PM | #1 |
Member#: 1519
Vehicle:1998 Volvo V70R Silver |
Nice web name, BTW. *chuckle* Farfrumgerman....
05-22-2001, 03:06 PM | #2 |
Member#: 5235
Vehicle:'98 Legacy GT w/ full-Nelson intake |
Thanks for the seat info! I thought I might have to remove the lower first... makes sense.
Yeah, thanks for the name recognition - hehehe a couple of my friends are VW lovers, so I live to torment them Thanks! Chad |
05-22-2001, 03:20 PM | #3 |
Member#: 4679
BAIC
Man, I tought I was trippin'. I have the same noise in the back of my car. So where exactly is the noise from? I am not that technical, so I have no clue what you are talking about (c-piller)... So? Help?
Leo |
05-22-2001, 07:18 PM | #4 |
Member#: 4643
Vehicle:2008 Legacy Outback Atlantic Blue Pearl |
Off-topic - saw a bumpersticker on an early (read: slow) Vanagon the other day: Farfrommovin :-)
Try this for a simple fix - if nobody sits in back often, pull the seatbelt ALL the way out until the tensioner reverses, then slowly let the slack back in, buckle it, and let the rest of the slack feed back. When someone sits there, you'll have to repeat the process of course... |
05-23-2001, 12:00 AM | #5 |
Member#: 5235
rear seatbelt spool CLICKS!
OK, I have finally tracked down the annoying clicking that has been comming from the back seat area....
I had my wife drive the car around as I roamed the back seat (and became car sick ) and found the noise to be coming from inside the back C-pillar (or whatever it's called). When we got home I investigated... I found that the belt spool toggles on it's axle! and I could duplicate the sound by tapping it with my finger that was squezed in there. Now, how do I go about silencing the beast? It's really the only "noise" the car has, and will only become more pronounced once I put my suspension in I'm sure. Does anyone know how to take the back seat out? - I think I need to do this to get at the seat belt spool. I can put some thick self-stick felt between the spool and the carrier... but I can't get in there any experience??? anyone else hear this click/clunking on their Legacy? thanks for reading -Chad |
05-23-2001, 12:41 AM | #6 |
Member#: 768
Vehicle:OB, volt, 911, ram 1500, 1098s, m620 |
taking out the back seat is pretty easy. undo the 2 bolts holding down the bottom cushion, then lift the cushion up from the middle to get it off a latch. undo the 3 bolts that hold the top cushion on. then lift and pull out. there's a hook on each side holding it in.
roger |
05-23-2001, 06:15 AM | #7 |
Member#: 374
SWIC
Vehicle:'98 2.5 GT Wagon Rio Red |
iBlue: He's talking about where the rear seatbelt disappears into the car at the top.
The 'C' pillar is the third set of pillars that support the roof. On a Sedan, it is the pillar between the back door and the rear window. The 'A' pillar is the one by the windshield, and the 'B' pillar is the one between the front and rear doors. And, if you have a wagon (an ultra-cool GT like mine ), the 'C' pillar is behind the door (like the sedan), and the 'D' pillar is at the very back. **- Eric ****'98 2.5 GT Wagon - <a href="http://216.242.153.40/MembersList/ViewMemberPics.cfm?MemberID=143" target="_blank">Pics</a> - <a href="http://www.jeneric.ws/eric/radioflyer.htm" target="_blank">Page</a> - ****ICQ #: 9292601 [This message has been edited by Radio Flyer (edited May 23, 2001).] |
05-24-2001, 10:39 AM | #8 |
Member#: 5235
Cool on the simple fix! will try it today... seems like it should work, putting some tension on the belt.
Thanks! |
05-24-2001, 03:03 PM | #9 |
Member#: 4679
BAIC
AHHHH.... The pillar...! Man, I've been going for a while without know what that noise was, and it has been annoying the crap out of me. Anyway, Thanks!
Caution, rear seatbelt attached to headliner | swingkid | Forester Forum | 15 | 08-23-2004 05:56 PM |
Rear seatbelt squeak | frankb | Interior & Exterior Modification | 0 | 04-29-2004 10:53 AM |
WTB: GC8 rear seatbelts, and driver side windshield wiper | STEALTH-WRX | Private 'Wanted' Classifieds | 0 | 03-18-2004 12:58 PM |
Need help QUICK removing rear seatbelt | just one blunt | General Community | 4 | 09-25-2003 08:30 AM |
3 point rear seatbelts=ready for 5 pint harness? | PatMunits | General Forum Archive | 7 | 01-19-2001 08:07 AM |
