Old 04-19-2006, 02:57 PM   #51
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
So,
You are taking the approach favored by myself and staticfritz. and making it work within the spacer?
Old 04-19-2006, 04:01 PM   #52
SOLUTION
Member#: 43602
2005 Outback Sport
Yep.
BTW, the machine shop said it would cost about $80 for the work (they said not to worry about the aluminum stock).
SOLUTION is offline   Reply With Quote
Old 04-19-2006, 04:45 PM   #53
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
sweet! I may have you get a second one! (you may want to consider getting a few...i'm sure there are other people who will be interested)
staticfritz is offline   Reply With Quote
Old 04-19-2006, 05:12 PM   #54
SOLUTION
Member#: 43602
2005 Outback Sport
If this one works out well I'm sure the machine shop could replicate it easily enough. I'm not sure anyone else is serious about it, other than you, and once it's in use (in my car) everyone else is out of luck.
Old 04-30-2006, 11:37 AM   #55
SOLUTION
Member#: 43602
2005 Outback Sport
Here's a (crappy) picture of the spacer. They drilled out the holes on the TB to make it fit right.
Old 04-30-2006, 11:40 AM   #56
SOLUTION
Member#: 43602
2005 Outback Sport
You see the hose coming off from the TB the routes under the sparkplug wires? What is this for? My '99 TB doesn't have a spot for the hose...
Old 05-02-2006, 07:33 PM   #57
SOLUTION
Member#: 43602
2005 Outback Sport
Bumping this back up...
Old 05-22-2006, 05:02 PM   #58
staticfritz
Member#: 66934
2004 JBP FXT
how did this go? you get it up and runnign on the block, or are you using the old manifold? if so....what did you end up doing all told, and can we get some pics?
I'm thinking about starting the mods on mine for some summer upgrading.
Old 06-02-2006, 09:59 PM   #59
22B-STi
Member#: 116191
I'm also curious because I would like to do this mods to my 01 rs if it work out right.
22B-STi is offline   Reply With Quote
Old 06-03-2006, 01:30 PM   #60
SOLUTION
Member#: 43602
2005 Outback Sport
Well, let's see. I moved 100 miles away and the manifold is at the machine shop where I moved from.....I guess I should give them a call Monday.
Old 06-03-2006, 05:36 PM   #61
FromEvoToRS37
Member#: 91396
is there a difference between an 04 intake manifold and an 05 cause I've got an 04 and that looks like the one I got, although I've heard there mite be somethin changed
FromEvoToRS37 is offline   Reply With Quote
Old 06-04-2006, 12:07 AM   #62
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
edit for dumb question
ImprezaRSX is offline   Reply With Quote
Old 06-08-2006, 08:54 PM   #63
FromEvoToRS37
Member#: 91396
Old 10-01-2006, 09:38 PM   #64
roofis
Member#: 33371
i wanna bump this back up. Solution, did you ever get the manifold back and mount it up so all will work right? i'm toying with the idea of doing this but we'd like to know if you think the effort was worth the gains or not.
has anyone else given this a shot that has info to put in?
roofis is offline   Reply With Quote
Old 10-01-2006, 11:05 PM   #65
SOLUTION
Member#: 43602
2005 Outback Sport
It is sitting in my parent's house. I don't remember if the throttle cable part was fabbed up or not. If so, it is complete. However, things changed and my car is in the shop getting an STI engine.
Old 04-03-2007, 10:00 PM   #66
SOLUTION
Member#: 43602
2005 Outback Sport
This project is for sale. PM me with any questions.
http://forums.nasioc.com/forums/show...6#post17593106
QUESTION: '05 WRX sedan axles into '00 RS kumanchu Transmission (AT/MT) & Driveline 2 12-01-2009 09:16 PM
Will a silicone turbo inlet fit under an EJ25D intake manifold? ASF Normally Aspirated with bolt-on Forced Induction Powertrain 12 09-16-2009 12:36 AM
STI intake manifold onto a 2.5i non-turbo engine? bburd88 Built Motor Discussion 12 06-29-2009 03:51 AM
2007 2.5i intake manifold onto a 2007 EJ255 Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-20-2008 05:51 PM
this might be dumb: but would an STi intake manifold fit on an NA 2.5RS? Impreza2003 Normally Aspirated Powertrain 15 06-22-2005 12:58 PM
