Old 10-02-2001, 12:18 PM   #1
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Default Which FMU? And will a ford model 255lph fuel pump work?
I am wondering which Fuel pressure regulator to use because I have heard that some are having difficulties. Also will the Ford mustang fuel pumps work, because they are cheaper by about 50-100 $.
Thanks
scootr is offline   Reply With Quote
Old 10-02-2001, 05:58 PM   #2
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Yes, the Mustang pump will work.
Use a Vortech 4:1 FMU.
blaster88 is offline   Reply With Quote
Old 10-03-2001, 08:43 AM   #3
HRE | giulio
Member#: 481
i had to recalibrate the Vortech FMU to 6:1.
The 4:1 wasnt making enough pressure, i still had to put the SAFC past 15% in some areas to compensate.
With 6:1 i am only added tiny amounts around the rpm range to fine tune.
But... you might want to look into bigger injectors instead of a large(r) FMU.
g
HRE | giulio is offline   Reply With Quote
Old 10-03-2001, 06:24 PM   #4
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Two questions.
blaster88,
what is the part number for the Mustang pump?
giulio,
what boost are you running to require that much of an increase?
Charlie
wcbjr is offline   Reply With Quote
FS: Walbro GSS342 255LPH Fuel Pump and Install Kit lancelucas NWIC Private Classifieds 4 02-02-2010 12:29 PM
Wtb: Downpipe(catless), Walbro 255lph fuel pump, and Cobb Accesport v1 (2006-2007) dansabzz Private 'Wanted' Classifieds 23 12-14-2009 11:09 AM
walboro 255lph fuel pump and perrin turbo inlet JWDWRX Private 'Wanted' Classifieds 3 12-23-2008 08:14 AM
FS in CA: Gimmick Turbo inlet + Aftermaf Hose Red and Walbro 255LPH Fuel pump 06EzSTI Engine/Power/Exhaust 11 05-20-2008 01:28 PM
Walbro 255lph fuel pump and install kit new thurgood498 Engine/Power/Exhaust 2 09-01-2006 09:21 AM
