Welcome to the North American Subaru Impreza Owners Club Friday October 31, 2014
Old 05-10-2000, 04:36 PM   #1
Ben
Member#: 423
2002 WRX wagon
Post Kg/mm Spring on Stock shocks?
Hi all, I have a 92 legacy Turbo in Toronto, One of the Imperza owner sells his used Japanese Kg/mm Springs to me. But I will go for stock shocks since I have to find a good shocks which good for Road rally and daily drive!!
Does any advantage or disadvantage for just replace springs without new shocks?
Ben is offline   Reply With Quote
Old 05-11-2000, 04:58 AM   #2
mccasksl
Member#: 1208
Post
...on my '97 Legacy GT and '98 Impreza RS I have found the stock struts to be underdamped with respect to the Eibach springs (somewhat stiffer than stock)which caused some problems (adverse tire wear) and is generally annoying (bouncing down the road / around turns) Ideally the springs / struts should be better matched. I had to go the KYB/AGX (adjustable) on both cars to fix it. I guess it depends on how much stiffer the new springs are. I've not heard of nor am familiar w/ the Jap kg/mm springs.
mccasksl is offline   Reply With Quote
Old 05-11-2000, 03:07 PM   #3
BG5
Member#: 695
Post
There are several kg/mm brand spring sets with differing rates/lengths, they all tend
towards the really stiff rally/race style springs out of Japan so I wouldn't recommend using them with stock struts at all...
For a daily driver I would use a set somewhat less stiff than a kg/mm.
BG5 is offline   Reply With Quote
Old 05-12-2000, 12:13 AM   #4
PaulN
Member#: 566
1994 Legacy GTB
Green
Question
What do you mean by kg/mm - surely this is just the spring rate, and my standard springs are 2.5 - 4 kg/mm front and 1.7 - 3.5 kg/mm rear
Paul
PaulN is offline   Reply With Quote
Old 05-12-2000, 01:43 AM   #5
BG5
Member#: 695
Post
there's a brand/company called "kg/mm" also sometimes referred to as "KGM"...
a looksie into a Hyperrev will reveal some pretty whacked out english phrases/words used in Japan to brand/name their products...
Old 05-12-2000, 05:22 AM   #6
Ben
Member#: 423
2002 WRX wagon
Post
The guy who sell it to me and told me the springs will drop the car about 1.5" but I don't really know its for Rally or daily use!?? I still decide to get it or not!!
Old 05-12-2000, 10:38 AM   #7
BG5
Member#: 695
Post
the drop sounds about right, the 2nd gen
legacy kg/mm springs I have specs for are nearly 60% stiffer. BF series springs won't differ by much. If your roads are
smooth and you like a stiff ride maybe they'll work for you?
Old 05-12-2000, 03:28 PM   #8
Gambit
Member#: 102
Post
Err...i could be wrong here, but don;t u need to raise the car for off roading? i know patrick richards uses Outback Sport springs on his modified impreza.
Gambit is offline   Reply With Quote
Old 05-12-2000, 03:48 PM   #9
Ben
Member#: 423
2002 WRX wagon
Post
Gambit, thank for the info, could you tell me more if on those set-up?
Old 05-12-2000, 04:32 PM   #10
PeteH
Member#: 431
Exclamation
Ben, don't bother with stock or even standard replacement struts, you won't be happy. The KYB/AGX's are the best bang for the buck and the damping rates are well suited to the early Legacy's, even with stock springs. I didn't bottom once in the two 'brisk' TSD rally's I was in with the struts set at 3 front and 6 rear.
PeteH is offline   Reply With Quote
Old 05-12-2000, 05:34 PM   #11
Ben
Member#: 423
2002 WRX wagon
Post
Hi PeteH, Thanks for the reply, but right now, I just can afford the springs since its used from the other 2.5RS user, thats why I wants to know more info by you guys on those Spring replacement!!
But I'm sure I will go for the shocks 2 months later!!
F/S 02 Eibach lowering springs on stock shocks ChuckCheeze Suspension/Brakes/Handling 7 09-26-2008 12:15 AM
WTT/GC8 KG/MM springs for stock OBS springs marooned RS VIC Private Classifieds 0 03-29-2007 12:59 PM
progess springs on stock shocks??......wrx 05 Boosto Brakes, Steering & Suspension 1 09-21-2006 01:15 PM
Springs on stock shocks?? tpmann Brakes, Steering & Suspension 24 11-25-2004 12:54 AM
H-R Springs on stock shocks, Ride? Durability? Davenow Brakes, Steering & Suspension 7 10-01-2002 01:18 AM
