Old 04-05-2006, 04:16 AM   #1
Blarghman
Member#: 84958
Default Random question about AP that i always wanted to ask but never did...
Yo guys!
I've had my AP for like 6 months or something on my 05 WRX wagon, and for some reason the Econo map never really flashes. I've tried a few times uploading it, and it takes a few minutes to do so, but after its done, i'll check the current map and it will still be on the last map i left it on. I've changed between stock and stg 1 and stg 2 a few times, and they all work fine.
Any input?
Thanks,
Tre
Blarghman is offline   Reply With Quote
Old 04-05-2006, 04:33 AM   #2
RUrunning
Member#: 68758
15 STi
LE
i'm pretty sure the current map always shows your current base map. one sure way to tell is to read the live boost when in econo mode, it should be much lower than target boost for any other map (other than valet). if all else fails, just try to add the newest version of the map from the website and replace the one you've got.
RUrunning is offline   Reply With Quote
Old 04-05-2006, 11:48 AM   #3
WRXTuan
Member#: 61294
04' WRX
4eAT San Remo Red
I always thought that the econo map and the valet maps are realtime maps which means you flash them over the basemap. So you are running the realtime map (econo/valet) but the basemap is still on the ECU (stock, stage 1, stage 2) so the AP reads the basemap. I'm not to sure about this, you should check that out with Cobb.
T.Vo
WRXTuan is offline   Reply With Quote
Old 04-05-2006, 03:00 PM   #4
Blarghman
Member#: 84958
Okay, i'll give em a call and maybe read the manual more thoroughly, haha.
thanks!
Tre
Old 04-05-2006, 03:03 PM   #5
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Yes the AP will only display your current BASE map, not realtime map.
ihavebettersound is offline   Reply With Quote
Old 04-21-2006, 09:19 PM   #6
slavboy1
Member#: 93620
2005 STi
This may be slightly OT but what is the difference between the base map and the realtime map? I just got my AP and wanna get this all sorted out before i start messing around. I understand that you load a base map onto the ECU but how does the realtime map change if the base map always stays the same? I dunno the manual that came with the AP didn't really do a great job of explaining what the difference was. If there's a thread for this already i appologize and please direct my n00b butt in that direction. THanks
slavboy1 is offline   Reply With Quote
Old 04-22-2006, 09:02 AM   #7
CynicX
Member#: 48199
06 WRX
The base map changes alot more in the ECU and is permanant unless you flash another basemap on it. A realtime map doesnt have all the abilities the basemap has and it can be reset using a variety of ways....
When it comes to the Cobb AP you'll definately want to be running the correct basemap. Of course you have to run there base to marry it to your ecu
CynicX is offline   Reply With Quote
I've always wanted to learn how to play the guitar, but ... SiniC Off-Topic 56 06-04-2008 12:52 AM
Who Was That Fatty That Always Wanted to Buy a Maurauder? OriginalSin Off-Topic 16 10-12-2007 05:45 PM
Everything you always wanted to know about the 5mt but were afraid to ask. nich0lai Newbies & FAQs 2 07-21-2006 01:08 PM
TV series that you always wanted to get into enewtabie Off-Topic 6 06-16-2004 01:09 AM
kinda sumb question but I want to ask anyway NRTmotorsports Proven Power Bragging 2 08-13-2003 12:50 PM
