Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 04-05-2006, 08:39 AM   #1
madmr2
Member#: 102334
Default TurboXS Unichip on a 2004?
Hi,
I tought I had a 2003 ecu (swapped car) so I bought a TXS Unichip (old model) for it and now I found out I have a 2004 ecu/engine...
I know there are differences between 2002-03 and 2004 like open loop/closed loop etc...
But did anybody run the Unichip on a 2004? I plugged it in and it idles fine but I didn't risk running/boosting it...
madmr2 is offline   Reply With Quote
Old 04-05-2006, 08:53 AM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
1. Post in the right forum
2. If you don't know....don't do it
3. You like playing Russian Roulette with your car don't you
Old 04-05-2006, 09:29 AM   #3
madmr2
Member#: 102334
I checked this section and all the others and there was nothing about the unichip anywhere in the section titles, sorry for making the bad choice
Wow thanks... let's all do that, never ask questions and never do anything...
Yes my only goal is to blow my engine... that's exactly why I'm asking this question before I put it on and go boost it...
Old 04-05-2006, 11:41 AM   #4
REX8
Member#: 24038
No, it will not work on an 04. You'll get CEL's etc. because the 04 has quiet a few more sensors than the TXS harness has pins for. You can try to run it, just live with teh CEL's....but I'm not sure if the OL/CL delay gets over-ridden by the unichip on step-over. Not worth the risk for $100 (02-03 ECU price) IMHO.
You'll have to buy an 02-03 ECU if you want to use the chip (not a bad idea anyway!)
Pretty sure we already answered this for you in a previous thread...
Is a 2002 TurboXS Unichip okay to use on a 2003 WRX? Dan00Hawk Engine Management & Tuning 3 10-06-2005 12:16 PM
does the vishnu unichip = turboxs unichip ants wrx Factory 2.0L Turbo Powertrain 3 09-18-2002 10:05 AM
TurboXS Stage 2 unichip on car with different setup... OK? rlavalle Factory 2.0L Turbo Powertrain 2 07-15-2002 02:42 AM
TurboXs Unichip harness without unichip? Ryan23 Factory 2.0L Turbo Powertrain 1 07-07-2002 01:38 AM
Question on TurboXS Unichip? tibikefor2 Newbies & FAQs 3 01-26-2002 09:55 PM
Message Board Statistics All times are GMT -4. The time now is 11:49 PM.
