Old 05-08-2000, 06:47 PM   #1
slide
Member#: 1130
2013 STI Hatch
Post rattle on decel
This is probably a shot in the dark but i have two rattles. the first is on the clutch of a 95 legacy MT. there is a high pitch rattle unless I put a littlr pressure on the clutch pedal. the second is when I decelerate in gear. It sounds like the exhaust system is falling apart, but its not. Any hints or tips or trouble shootin?
slide is offline   Reply With Quote
Old 05-09-2000, 10:30 PM   #2
BG5
Member#: 695
Post
on the clutch: throwout bearing or pilot bearing going bad, or the throwout bearing is binding on the tranny input shaft. Usually full clutch replacement time...
exhaust, maybe there's a torn rubber hanger or broken heat shield?
BG5 is offline   Reply With Quote
Old 05-10-2000, 05:33 PM   #3
WhiteH2O
Member#: 452
'06 GX470
Post
I used to have a rattle on decel, but it is now a constant rattle. I took it to the sube dealer and they couldn't hear it. I think that mine is a transmition rattle, though. It sounds like a bunch of nuts and bolts in a coffee can being rattled around. I have complained about it a few times, but they havn't done anything. Now that it is worse, I think that i will go down there and make them ride with me because I know that i can make the rattle. I know that I am not much of a help, but if you figgure out waht it is, you could let me know. I will do the same.
WhiteH2O is offline   Reply With Quote
Old 05-10-2000, 09:23 PM   #4
slide
Member#: 1130
2013 STI Hatch
Post
I am getiing this feeling that it is either engine/tranny mounts, or something to do with the exhaust manifold. Because on accelaration I don't hear it. Also if I just breathe the throttle a little bit on decel it goes away. this maybe a torque issue moving the motor. I am going to save up for mounts and if that doesn't work, then a borla manifold. If it is still there, then, I am going to go crazy......
Humming on light throttle - no humming on decel akira02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-24-2015 04:05 PM
Car pulls right on accel, left on decel wcbjr Brakes, Steering & Suspension 17 05-14-2010 04:24 PM
Running rich on decel/overrun vacuum wcbjr Engine Management & Tuning 1 11-06-2002 07:07 PM
noise on decel in 2nd and 3rd PerformanceAutoSolutions Tri-State Area Forum 6 11-28-2001 03:41 PM
Rattle on Decel wgs650 Newbies & FAQs 4 11-03-2001 11:37 PM
