Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-02-2001, 03:34 PM   #1
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Question BOV Placement?
Where is the most effective BOV placement on the turbo ducting?
Is mounting it to the IC best?
Or is mounting it to the charge pipe before the IC the best?
I have the option to do either, which is better..
6psi, Ludespeed stage 2
Supersequential BOV
N1 IC from Larry Ganz
STiShawn is offline   Reply With Quote
Old 10-03-2001, 02:55 AM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
Shawn, was your BOV the Apex or HKS I forgot.
I can't really answer this, since we've talked about it, so I'm just gonna give you a bump and one quick advantage of the IC mount.
IC: closer to the TB so it would vent faster before it had a chance to surge.
Also, take a look at some different turbocharged cars out there, see where the BOV is mounted in relation to the IC, before or after. That should help out.
Jewbaru is offline   Reply With Quote
Old 10-03-2001, 04:48 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
as close to the TB as possible
Jeremy
Old 10-03-2001, 11:28 AM   #4
RacerinLSL
Member#: 1174
2011 Subaru WRX
Joel and Jeremy are right. On most cars, attached to the intercooler wouldn't be optimal, but since the intercooler is directly attached to the TB, it's definately the best choice.
Chad
RacerinLSL is offline   Reply With Quote
Old 10-03-2001, 12:28 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Its going to have to on the charge pipe, but I will have it as close to the IC as possible..thanks guys
Old 10-03-2001, 12:34 PM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Mine is on the tubing before my freshly installed intercooler.
How is it advantages to have it close to the throttle body? As soon as you let off the gas and close the butterflies, the entire line between the TB and turbo is pressurized. As soon as the BOV detects vacuum it opens up allowing it to expel the air. The entire point of the BOV is to release the pressure so the air doesn't force itself back through the turbo causing a lot of pressure on the compressor wheel and an almost immediate stop of the wheel which contributes to gear shifting lag and a lower life expectancy of the turbo seals.
So all that said, how is it advantages to have it close to the throttle body?
hondatch: You say close to the TB, but why? What's your reasoning?
I understand if you have a weld on BOV, then it's a good idea to have it on the IC just as a place to weld it, but otherwise it shouldn't matter.
My$.02
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-03-2001, 01:36 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
subachad-
THis is to prevent excess pressure from hitting the throttle plate and keep the air pulsation against it down. the closer your BOV is to teh throttle body the better off you are. It's alost easier to force the air out at the end of the tube rather then in the middle w/ a T in it. Just think of it in velocity, the air is already moving that direction, it is almost at it's run thru the intake(before the throttle plate) and coming out of hte biggest storage chamber in the system. Best spot to vent, the end of the storage tank. It just keeps for a smoother air pattern into the throttle plate.
Dunno if that made sense
jeremy
Old 10-03-2001, 02:02 PM   #8
subachad
Member#: 8488
Teal
Thanks Jeremy, that makes perfect sense.
Chad
93 1.8T
Old 10-03-2001, 03:40 PM   #9
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Thanks Jeremy
Old 10-04-2001, 03:29 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
no problem guys, my pleasure
with any luck i'll have my kit installed and being produced by next spring
Jeremy
bov placement on fmic vien Newbies & FAQs 9 11-04-2009 08:11 PM
Preferred BOV placement ljaviation Built Motor Discussion 1 12-22-2007 01:10 AM
BOV Placement SloRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 02-09-2006 08:58 AM
Custom IC Piping Dia and Bov Placement Joker 13 Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-27-2005 04:24 PM
Question about BOV placement Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-12-2001 10:58 AM
