Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-05-2006, 03:42 PM   #1
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
Default UTEC over an Ecutek
anyone ever done it? My UTEC is throwing a code "LCM" in the boost column and i have no idea what the crap it's doing that for?
gcm05 is offline   Reply With Quote
Old 04-05-2006, 04:16 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Launch Control Mode - It's not a code. I bet it only happens when you push the clutch in. If not it means you have launch control enabled and no clutch switch installed.
Loads of people run a UTEC over an EcuTek flash.
mick_the_ginge is offline   Reply With Quote
Old 04-05-2006, 05:50 PM   #3
gcm05
Member#: 105948
nope that's not it. It's throwing the code in the boost column and it's just around 4300 - 4400 rpms when the it's switch between the open and closed looped fueling. The UTEC has the launch control mode off and has even been reflashed. The Ecutek right at that point in the rpm band takes over timing and won't let the UTEC have it.
Old 04-05-2006, 06:02 PM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Post a UTEC log then.
Does it look like this?
Code:
 6653 +15.8 4.1 104  70    00   W/B  +18.6   65.5 +20.0  -0.5 320.00 4.1  11.30
 6775 +15.8 4.2 104  70    00   W/B  +18.8   65.9 +20.0  -0.5 320.00 4.1  11.37
 6802 +15.6 4.1 104  70    00   W/B  +18.8   64.9 +20.0  +0.3 320.00 4.1  11.48
 7002 +15.4 4.1 105  70    00   W/B  +18.8   68.1 +20.0  +0.5 LCM. 4.1  11.52
 6071 +15.4 4.0 105  70    00   W/B  +17.7   54.2 +18.9  -1.5 LCM. 3.9  14.92
 5564 +15.4 4.0 104  70    00   W/B  +10.9   57.5 +18.0  -1.5 320.00 4.0  >25:1
 5564 +16.5 4.1 105  80    00   W/B   +9.4   60.6 +18.0  -1.3 320.00 4.0  14.92
Or like this:
Code:
 6653 +15.8 4.1 104  70    00   W/B  +18.6   65.5 ECU  -0.5 ECU 4.1  11.30
 6775 +15.8 4.2 104  70    00   W/B  +18.8   65.9 ECU  -0.5 ECU 4.1  11.37
 6802 +15.6 4.1 104  70    00   W/B  +18.8   64.9 ECU  +0.3 ECU 4.1  11.48
 7002 +15.4 4.1 105  70    00   W/B  +18.8   68.1 ECU  +0.5 LCM.   4.1  11.52
 6071 +15.4 4.0 105  70    00   W/B  +17.7   54.2 ECU  -1.5 LCM.   3.9  14.92
 5564 +15.4 4.0 104  70    00   W/B  +10.9   57.5 ECU  -1.5 ECU 4.0  >25:1
 5564 +16.5 4.1 105  80    00   W/B   +9.4   60.6 ECU  -1.3 ECU 4.0  14.92
LCM = Launch Control Mode. LCM is on even in switch position 0.
Something is screwy if you are sure LCM is off. What is the switch position?
FYI - I have been running an EcuTek under my UTEC for many years, no issues.
Old 04-05-2006, 06:08 PM   #5
gcm05
Member#: 105948
man can we talk on the phone? It'll be easier for me to explain
Old 04-05-2006, 06:11 PM   #6
gcm05
Member#: 105948
it's like that only it's happening around those other rpms i was talking about
Old 04-05-2006, 09:50 PM   #7
gcm05
Member#: 105948
i think i'm screwed
Old 04-06-2006, 05:46 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
Did you pass the correct boost signal around the Utec? I have been running the Utec over Street Tuner for ~8 months. The first thing I noticed was that even on Utec map0 the boost signal was changed. To correct this I had to jump the MAP signal line from the input of the Utec to the input of the stock ECU, and cut the conection for the MAP between the Utec and ECU. This lets the stock ECU "see" the correct MAP level.
TMS
TheMadScientist is offline   Reply With Quote
Old 04-06-2006, 11:39 AM   #9
gcm05
Member#: 105948
do you have any suggestions on what i may be able to do to figure this out?
Old 04-06-2006, 11:46 AM   #10
TheMadScientist
Member#: 23717
2005 Big red
Post a log from logger 1.
TMS
Old 04-06-2006, 11:50 AM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I just ignored the boost. ECU is mainly MAF based and I used TurboXS DTEC for boost control. I did re-calibrate the ECU and UTEC to read the 4.5 bar MAP sensor that I am using. I did this for the ECU a while back when I was running with the UTEC uninstalled and was testing the ECU boost control capabilities.
Old 04-06-2006, 12:04 PM   #12
gcm05
Member#: 105948
i don't have any logs now. the tuner didn't capture any info and when he unplugged his laptop he said he would have lost the info anyway
Old 04-06-2006, 10:25 PM   #13
12secscooby
Member#: 110171
Talking GET THE Ecutek!!!!
The Ecutek is the best thing out there! I had a UTEC and it was good but, you have more control over the stock ecu with the ECUTEK. You cannot go wrong with tuning the stock ECU when you have the capabilities to do so. The Utec is good but your still fooling the stock ecu. Let the ecu be tuned and be more safe by using the stock ecu. Trust me...I gained over 30 whp by changing to an Ecutek.
12secscooby is offline   Reply With Quote
Old 04-06-2006, 10:48 PM   #14
gcm05
Member#: 105948
Sorry man but i'm using both....i'm not trying to choose one or the other
Old 04-07-2006, 01:41 AM   #15
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Default i agree with the ecutek
i was about to do that myself.... i called ecutek since i got a crappy tune (which cost me 520$) and my car knocks terribly in high 4 at WOT and all of 5th... timing was advanced to high so im most likely gonna sell my VF30 once i get my GT-12 on.
All4bSpinnin is offline   Reply With Quote
Old 04-07-2006, 01:49 AM   #16
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I've been drinking this evening so I will respond to this, I usually would not.
The UTEC is not fooling the ECU at all, please take a little more time and read up on actually how the UTEC works. The UTEC runs as a piggy back when it's letting the stock ecu control the engine then completly takes over control of both timing, fuel and boost of you want it to. No fooling going on.
gcm05's issue is a strange one. Without logs or at least him posting UTEC parameters and stuff like that we may never be able to help.
Old 04-07-2006, 12:59 PM   #17
TurbojonLS
Member#: 38772
2 Cars, No Bling
If this is true you didn't have a good tune on the UTEC. Properly tuned all EM will yield approximately the same results.
To the OP: You really need to drive around and log what is going on so we can see it in action.
TurbojonLS is offline   Reply With Quote
Old 04-07-2006, 02:41 PM   #18
gcm05
Member#: 105948
i'm currently trying to get a hold of a lap top so i can log
then i will try to get it all posted up here
thanks to everyone who has helped me out thus far
Installing UTEC over EcuTek Strtwre UTEC 6 11-23-2007 01:41 PM
UTEC over poor Ecutek flash JustA4 Engine Management & Tuning 7 03-21-2006 12:51 PM
Can you run a "blank" UTEC map over an EcuTek reflash, in which the reflash controls? scooterforever Engine Management & Tuning 42 05-04-2005 11:27 PM
im getting an APS cold air intake and an ECUtek flash done soon on my sti FAST CO STi Proven Power Bragging 35 07-06-2004 03:39 AM
should i BUY an STi/WRX over an e46 M3? bimmer>rice Tri-State Area Forum 61 03-14-2004 08:57 PM
