Old 04-05-2006, 08:36 PM   #1
Chris_Lee
Member#: 110667
2006 WRX
Default 2006 WRX What is the whp you get with stage 1?
Okay now I'm confused. I've been searching and can't find a answer. On COBB's web site they say the Stage1 AP produces 260 hp on a 2006 WRX. Then they have a jpeg of a dyno showing a stock run at 202.0 whp and a Stage 1 run showing 202.4 whp. So, is this the wrong graphic? What gives? Anyone know what the whp numbers are for a stock 2006 WRX using Stage 1?
Chris_Lee is offline   Reply With Quote
Old 04-05-2006, 08:47 PM   #2
aimetti
Member#: 96006
2013 Ford focus st 3
TS
probably because the 202 HP is equivlant to around 250 hp to the crank. Subaru underestimated the horse power and torque of the wrx. stage 1 although it flatens out the powerband and brings the power a tad earlier , really isnt worth it for only a .5 hp gain and 7 ft lbs gain. If you are gonna go acess port you might as well go stage 2 with 224 hp / 275 ft lbs to the wheels.
This is just my opinion, I havent felt it first hand so I could very well be wrong. Just my belief.
aimetti is offline   Reply With Quote
Old 04-05-2006, 09:29 PM   #3
Chris_Lee
Member#: 110667
2006 WRX
Okay I found the answer...
Old 04-06-2006, 02:35 AM   #4
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
What's the answer?
sandwi54 is offline   Reply With Quote
Old 04-06-2006, 04:11 PM   #5
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I loved my car after the stage one flash.
re-mapping th throttle by wire made a huge diffirence.
Not in power sure, but the car is much more livable.
parker/slc/gc8fan is offline   Reply With Quote
Old 04-06-2006, 05:44 PM   #6
jsalassi
Member#: 61261
04 WRX Wagon
Wingless+Blue+Stg2
stage one it hink is worth the cost of the AP. Then stage 2 is a whopper of a deal and your already half way there.
jsalassi is offline   Reply With Quote
Old 04-06-2006, 06:59 PM   #7
Chris_Lee
Member#: 110667
2006 WRX
Originally Posted by sandwi54
What's the answer?
http://www.i-club.com/forums/showthread.php?t=114272
What is the going rate for a stage 2 Protune? tommott77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-06-2009 08:52 AM
Notary. What is the point of getting something "notarized"? plunk10 Off-Topic 20 09-14-2007 11:49 PM
98 RS what is the tranny case sealed with? Doscooby Transmission (AT/MT) & Driveline 4 04-09-2005 01:48 PM
My PS2 sucks loading GTA:SA... What is the trick to getting it to work? crowbar Off-Topic 12 10-31-2004 06:57 PM
brake pad installation: what is the goop you smear on the pads? edkwon Brakes, Steering & Suspension 6 07-08-2002 01:25 PM
