Old 04-05-2006, 09:40 PM   #1
db97
Member#: 7140
2009 WRX
satin white pearl
Default PCV valve replacement
does anyone have detailed instructions on how replace the PCV on a '02 WRX? i'm trying to save money by doing as much maintenance as i can.
thanks!
db97
db97 is offline   Reply With Quote
Old 04-05-2006, 09:52 PM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Test it first. If it ain't broke you'll save money by not fixing it.
Whatever the case may be, it is easy to change. It is located on the back of the intake manifold with a hose going to it from the crankcase breather, the little plastic widget with a hose to it and the intake hose. The PCV is a metal fitting with a hex flange. Unscrew it and it comes out. You can test it by pulling a line off the aforementioned widget and sucking/blowing on the line. The PCV valve should allow air to flow one way and not another.
I know there is a guide for changing it on Scoobymods.
specialev is offline   Reply With Quote
Old 04-05-2006, 09:54 PM   #3
Siper2
Member#: 1134
2007 BMW 328xi wagon
Yes there is, and it should also be on www.northursalia.com.
Probably slightly different location from the one on the RS, like my car. I think it's a 19mm socket. Easiest thing in the world to change.
=S2=
Siper2 is offline   Reply With Quote
Old 04-05-2006, 11:10 PM   #4
en3d
Member#: 5238
GGA Black
an offset wrench makes this much much easier.
en3d is offline   Reply With Quote
Old 04-05-2006, 11:29 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
or a deep socket and a flex joint.
they are cheap enough that I would just pick up a new one and replace it, rather than remove, check, and re-install.
Old 04-06-2006, 10:13 AM   #6
Siper2
Member#: 1134
Regular deep socket is perfectly easy on my car, but yeah not sure about the WRX.
Old 04-07-2006, 08:32 AM   #7
db97
Member#: 7140
2009 WRX
satin white pearl
Default i still can't find the sucker??
does someone have a picture of the darn thing in a 02-03 WRX?
Old 04-07-2006, 08:36 AM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
look under the throttle body on the rear side of the engine - it's grey and has a rubber hose put onto one end. you can see it well from the passenger side of the engine.
Old 04-07-2006, 08:56 AM   #9
Hayes
Member#: 11808
On my 2000 Forester 2.5L the PCV has one hose to the aircleaner box and one hose to the intake manifold. The valve looks to be about 2 &1/2 inches tall. Has Subaru changed the system that much?
Hayes is offline   Reply With Quote
Old 04-08-2006, 09:22 PM   #10
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
I changed mine this summer and it really isnt a piece of cake to get to and you will really need a light to see EXACTLY where it is.
Once you find it, should be a piece of cake.
2k2 is offline   Reply With Quote
Old 04-11-2006, 12:18 AM   #11
kcismo
Member#: 21093
2002 WRX WAGON
BLUE
noob question
..what is a pcv valve for? i'm close to 60k.
kcismo is offline   Reply With Quote
Old 04-11-2006, 01:17 AM   #12
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
west_minist is offline   Reply With Quote
Old 04-11-2006, 09:22 AM   #13
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
guru question...
WHY do you people insist on changing the pcv?
seriously?
109k miles.
OEM PCV
no problems
it's not listed on the maintenance schedule
this is not a dirty nasty V8 engine
so why are you changing the pcv?
inquiring guru's wanna know?
i dont get it.
Jamie
Old 04-11-2006, 11:48 AM   #14
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Neither do I Jaime. If you hear it click back and forth, it's still fine. If not, replace it. But.....it is a cheap and easy part to swap out, so I wouldn't hate.
Old 04-14-2006, 10:55 AM   #15
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
just did my last night after 120k miles, the old one looked like it could go another 120k.
I figured it wasn't listed in the maint. sched as a mistake, although those who change it every 30k seem a little over the top.
dm
dwmoss_68 is offline   Reply With Quote
Old 04-14-2006, 11:46 AM   #16
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I agree that it probably lasts a lot longer than say the recommended replacement interval which some sites claim (15k miles, iirc) - but it's also not easy to tell how well it's working - clicking back and forth is important, but the quality of the seal when it's closed is what determines it's lifetime... I dunno - it's a pretty cheap part, so if you are doing the normal preventive maintenance at 15k or 30k or whatever, if you are going to check it, you might as well just replace it.
Old 04-15-2006, 10:55 AM   #17
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I'm not hating.
I just dont get it.....
but we sell loads of them at work so someone out there thinks they need to do this....
Jamie
Old 04-25-2006, 07:08 PM   #18
fastco
Member#: 77972
2009 Legacy 2.5i
QSM
Originally Posted by Subie Gal
I'm not hating.
Jamie
It's cheap and it can't hurt....
fastco is offline   Reply With Quote
Old 04-26-2006, 12:12 AM   #19
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Hmm could've sworn it was one the maintenance list for 30k.....why the heck did i get it done? LOL
Where did I get at idea from....
Was it on there or not?
Magnum626 is offline   Reply With Quote
Old 04-26-2006, 09:18 AM   #20
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
it's NEVER been on the maintenance list
Jamie
Old 04-26-2006, 01:04 PM   #21
GeoffM
Member#: 30252
2005 996GT3,'15 3500
04 Ducati 749R #249
well duh idk, i changed mine, nothing else to do and it was $3.00
GeoffM is offline   Reply With Quote
Old 04-27-2006, 01:05 AM   #22
Magnum626
Member#: 62856
MBP SQC#197
Talking
Jamie
Really? Or are you just fooling with me now? BTW, caught you on (damn forgot the name of the show) on the SPEED channel a couple days ago...
Wow....$3 for parts...how much would they charge for labor on that anyway?
Since I had it done on my 30k...guess I'll never have to change it....
Old 04-28-2006, 10:18 AM   #23
MDscoob
Member#: 75021
2005 RS wagon
gray
quick question to hijack the thread, is it in a different place on the 05 RS? I looked for it yesterday and I found two hoses on the drivers side of the throttle body, and one hose from the valve cover to the "torque box" behind the throttle body. Thanks.
MDscoob is offline   Reply With Quote
Old 07-01-2006, 12:03 PM   #24
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
well i bought one just because i thought it was required maintenence. im gonna check mine, if it still clicks, ill have a brand new one for sale
WRXDriftR is offline   Reply With Quote
Old 07-01-2006, 12:15 PM   #25
Hayes
Member#: 11808
Not on my 2000 Subaru maintanance schedual and the OEM origional is doing great at 107,000 miles. Ed
Confused on PCV valve replacement goldice42 Service & Maintenance 15 11-27-2010 04:33 PM
PCV Valve REPLACED Idle Problem GONE!! deebee8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-03-2007 10:55 PM
PCV valve replacement interval HudsoN456 Service & Maintenance 10 05-23-2002 03:22 PM
PCV Valve Replacement Interval? Silver2000RS Technical Forum Archive 1 10-12-2000 09:26 AM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 06:53 AM
