Old 11-06-2010, 10:06 PM   #1
jospgut
Member#: 235857
2002 wrx stg 2
Default HELP Please
I have a 2002 wrx stage two, accesport, The alternator was not so bad so I decided to change it, i disconect the battery and now dont turn on. but the horn works, le beeping when door is open works, and when i connect the accesport it works, but cannot acces to the computer
jospgut is offline   Reply With Quote
Old 11-06-2010, 10:16 PM   #2
flightwatch
Member#: 231058
2015 F-150
If the alternator wasn't bad, then why'd you change it? Look at the odometer...does it display the mileage or just dashes? It could be a simple grounding issue, or something more serious. Did you search the forums?
flightwatch is offline   Reply With Quote
Old 11-06-2010, 10:20 PM   #3
jospgut
Member#: 235857
2002 wrx stg 2
it doesnt show the mileage, just the dashes, the alternator wasnt dying thats why i change it, im doing research right know
Old 11-06-2010, 10:26 PM   #4
griff9502
Member#: 251477
2006 Subaru WRX
ive never encoutered this problem on a subaru before but i have on a few other cars i have worked on check all the wire connections to the alternator....
a bad connection there could cause a bad ground which will trip the failsafes within the ecu and ignition... get a wire brush and get scrubbing and then makes sure your wires arent broken or cracked
good luck
griff9502 is offline   Reply With Quote
Old 11-06-2010, 10:45 PM   #5
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
I sense some language barriers in this thread.
nhmtns is offline   Reply With Quote
Old 11-06-2010, 10:45 PM   #6
cabikejumper
Member#: 226604
2000 Mustang GT
Make sure you tightened the battery cables down
cabikejumper is offline   Reply With Quote
Old 11-07-2010, 12:46 AM   #7
flightwatch
Member#: 231058
2015 F-150
Dashes mean that the ecu isn't (or can't) be read. It sounds like the ecu might have gotten fried.
Old 11-07-2010, 12:59 AM   #8
jospgut
Member#: 235857
2002 wrx stg 2
ill check that out, thanks for your help
02 bugeye help...04 blob eye help..please help either or sammyswrxsti Interior & Exterior Modification 18 09-22-2008 02:39 PM
O2/egt Help Please Please!!!!! xWrx Service & Maintenance 2 07-16-2006 11:30 PM
blitz gauge wiring help please PLEASE!!! :) orlandowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2002 11:36 PM
HELP PLEASE! FINAL STAGE on hella install.. please shoot me with some quick (repost) gerardchau Interior & Exterior Modification 10 02-26-2001 11:29 PM
HELP PLEASE! FINAL STAGE on hella install.. please shoot me with some quick answer! gerardchau General Forum Archive 2 02-20-2001 10:49 PM
