Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-01-2006, 07:13 PM   #26
dedrooster
Member#: 32278
2000 2.5RS SRP Sedan
MB 190E 2.3-16v
PCV isn't on any of the service manuals I have seen, but it probably should be replaced at some point. I have replaced the one on my RS at 30k intervals and the old ones I have taken off are a bit gummed up but still seem to open and close ok, just slower than a new one.
I changed the pcv valve on my brothers Legacy at 100ksomething and it didn't move at all when shaken. He swore the car felt a little more powerful after changing it.
dedrooster is offline   Reply With Quote
Old 07-01-2006, 10:00 PM   #27
jsbush
Member#: 12874
2005 Outback XT 5spd
What are the symptoms of a bad PCV?
jsbush is offline   Reply With Quote
Old 07-05-2006, 11:32 PM   #28
Boxologist
Member#: 21118
examine the pcv valve every year. if it rattles, just zap it w/ some wd40 or liquidwrench to clean it anyway. if it doesn't rattle, clean it and let it drain. if it rattles finnally, put it back in and check if there are any other problems. its only a check valve.
Boxologist is offline   Reply With Quote
Old 03-30-2009, 10:29 PM   #29
jeffk182
Member#: 150649
2014 STI
Originally Posted by kcismo View Post
noob question
..what is a pcv valve for? i'm close to 60k.
The PCV valve gets rid of crankcase pressure caused by blow-by...its recirculates Hydrocarbons (oil, fuel) back into the intake...its just a one way check valve. Yeah its a real simple part, but a bad PCV can cause some retarded problems. I usually change it out every 30-60k miles (whenever you feel like it basically)..its a really cheap part.
jeffk182 is offline   Reply With Quote
Old 03-30-2009, 11:51 PM   #30
LorenzoS
Member#: 50995
2002 WRX Wagon
It's a very inexpensive part that is a royal pain to get to. So if I've gone through the trouble of removing it to test it, I might as well just put a fresh one back.
LorenzoS is offline   Reply With Quote
Old 04-23-2009, 01:39 PM   #31
PolarisSnT
Member#: 85905
2004 WRX
The PCV on my 04 WRx is located just behind the manifold in a plastic T. If you buy a PCV valve and try to unscrew the old one from the plastic it will break the plastic.
Does anyone have a part number for the plastic piece? Im due for a replacement PCV as when I let off the throttle the RPMs still climb.
PolarisSnT is offline   Reply With Quote
Old 04-26-2009, 09:09 PM   #32
mikercp
Member#: 166465
1994 Civic Cx
Frost White
mikercp is offline   Reply With Quote
Old 04-27-2009, 01:05 AM   #33
Engmus
Member#: 115645
I changed mine out on my 04 for a simple reason.
To be proactive.
Was it borked? No.
Did it need done, nope.
Was it a waste of cash, yup.
Did I change them on previous cars that weren't subies that needed it, yes.
I just did it to do it, and avoid any possible failure in the crank case ventilation system.
Cheap part, cheap insurance.
Rather safe, then sorry.
Engmus is offline   Reply With Quote
Old 05-17-2009, 08:27 PM   #34
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
Originally Posted by Subie Gal View Post
it's NEVER been on the maintenance list
Jamie
Yea but that doesn't mean PCV's dont go bad I just changed mine w 178,000 miles the spring inside lost some of its tension and stopped working not to mention it was also a little gummed up w sludge
Dragon Wagon is offline   Reply With Quote
Old 04-07-2010, 02:21 PM   #35
rideAC1
Member#: 210441
2002 Tarmac SpecC RA
I've been checking in to the PCV's and oil/air separators. A poorly working PCV can cause the engine to run lean by venting the positive ventilation system. If you're not a stock car (boost and engine modification wise) it may be a very important, bad problem if you're running lean. Check out mild-extremely modified turbo cars, many have oil/air separators, which get rid of the PCV valve for a better working system to not have this problem.
And by changing out/cleaning a dirty/bad one, it may cause your car to run better by letting the correct amount of blow-by through rather than the possible lean condition.
rideAC1 is offline   Reply With Quote
Old 10-29-2010, 11:36 PM   #36
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
guru question...
WHY do you people insist on changing the pcv?
seriously?
109k miles.
OEM PCV
no problems
it's not listed on the maintenance schedule
this is not a dirty nasty V8 engine
so why are you changing the pcv?
inquiring guru's wanna know?
i dont get it.
Jamie
Got a part number for it Jamie? For a 2005 WRX. Thanks!
eurospek is offline   Reply With Quote
Old 11-07-2010, 07:04 PM   #37
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Just to add an observation - the first time I replaced the pcv valve (which was on there for the first 25k miles) it was a little gummed up - nothing too serious, but noticeably gummed up (probably could have cleaned it with carb cleaner) - the second time (this weekend) with an additional 30k miles, the one I removed was pretty much perfect - no gumming up, just a drop or two of clean looking oil in it. Rattling the new one and the one I just removed, they sure felt/sounded identical... the only difference I can see between the first and second interval, was the first included break-in (when I was running a conventional oil), and the second was from a period when I only ran synthetic... maybe that's the difference - I dunno.
Either way - it's a cheap part, and if I am going to go through the trouble of taking it off to check it, I'm just going to slap a new one on instead - better safe than sorry, I guess.
Old 11-07-2010, 08:31 PM   #38
rideAC1
Member#: 210441
Just a note; I would think that running a thicker oil would cause less blow-by to go through the PCV valve. If you have changed oil types/thickness that may also contribute to more/less "wear" on the valve.
Confused on PCV valve replacement goldice42 Service & Maintenance 15 11-27-2010 05:33 PM
PCV Valve REPLACED Idle Problem GONE!! deebee8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-03-2007 11:55 PM
PCV valve replacement interval HudsoN456 Service & Maintenance 10 05-23-2002 04:22 PM
PCV Valve Replacement Interval? Silver2000RS Technical Forum Archive 1 10-12-2000 10:26 AM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 07:53 AM
