Old 04-06-2006, 12:36 AM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default Front 02 Sensor: 22641AA211
I am getting code P0171 and was suggested that my O2 sensor is the cause of the problem.
So I bought one OEM code 22641AA211 for about $150 to replace it. However, I just checked ebay and they seems to have a lot of 02 sensor available and they cost only $40.
So whats the difference between the normal front o2 sensor and the one sold on ebay or any generic o2 sensor?
- Charles
chaddeus is offline   Reply With Quote
Old 04-06-2006, 12:38 AM   #2
-Kevlar-
Member#: 82378
splicing is a pain....
-Kevlar- is offline   Reply With Quote
Old 04-06-2006, 02:47 AM   #3
chaddeus
Member#: 56624
2004 Subaru WRX STi
huh? There are a lot of Subaru specific O2 sensor but not made by Subaru.
- Charles
Old 04-06-2006, 04:56 AM   #4
-Kevlar-
Member#: 82378
if the O2 sensor is $40 bucks, i can almost gaurantee youre going to have to splice some wires. 100 - 150 is around the normal price for a "model specific" O2....
Old 04-06-2006, 05:49 AM   #5
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
They aren't that bad to splice as long as you are handy with a soldering iron.
If you aren't handy with one, practice makes perfect.
specialev is offline   Reply With Quote
Old 04-06-2006, 08:11 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A $40 sensor from Ebay will not work unless it happens to be the exact Subaru replacement with the same part #. The front 02 sensor on the turbo cars is not a generic type, it is a special semi-wideband.
The cause of the code you are getting needs to be properly investigated with the correct troubleshooting procedures, you shouldn't be blindly replacing parts based on what someone suggested. There are a number of possible causes.
If your car has under 36K it is still covered by the full warranty, unless it has mods that may be causing the problem.
Old 04-06-2006, 06:30 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I dunno what's on eBay, but for my previous car, the Bosch replacement, which was $39.99 (vs. over $100 for the Toyota OEM one) had the same connector and flange (it was a bolt on plate, rather than a screw in) as the OEM one - a direct replacement. Since the Bosch lists the WRX one as OEM replacement, and has different part numbers for each location and mt vs. at, I would guess that whatever you pick up on fleabay would work just fine and not require any soldering.
Bosch makes an awful lot of oxygen sensors, and they work well.
Old 04-06-2006, 07:01 PM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Could be the MAF also.
subbyspeed is offline   Reply With Quote
Old 04-07-2006, 08:51 AM   #9
chaddeus
Member#: 56624
2004 Subaru WRX STi
Well, I hope it isn't the MAF that is malfunctioning. The dealer said its the front 02 sensor so I guess I'll let them decide
- Charles
Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff TopEndPull Engine/Power/Exhaust 11 08-14-2009 05:48 PM
Wtb 02/03 Wrx Front 02 Sensor scooby101 Private 'Wanted' Classifieds 7 02-09-2007 04:34 PM
WTB front 02 sensor for 02-03 wrx vale2489 Private 'Wanted' Classifieds 2 12-17-2006 09:28 AM
Front O2 sensor: how many wires ? NicEJ25 Normally Aspirated Powertrain 2 11-28-2003 12:49 PM
