Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-06-2006, 11:48 PM   #1
fzturbo
Member#: 43482
2004 JDM 2 litre STI
Default TXS Pro tuner manual.
I bought an used TXS pro tuner with no installation manual, i already powerd it and instaled the lambda in the exhaust line but dont know how to plug it to the UTEC.
Is there any online instruction manual or installation manual of it???
Also, when replacing the knock sensor for the tuner pro one, what do i have to do with the factory conector??? leave it unplugged???
Thanks and sorry for the dumb questions but i couldnt find any online manual.
fzturbo is offline   Reply With Quote
Old 04-07-2006, 01:43 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
A: UTEC serial cable plugs into the back on the Tuner Pro, you then connect a serial cable to the front of the Tuner Pro and UTEC log as normal
B: DO NOT DISCONNECT THE STOCK KNOCK SENSOR!!!!! Yes that was shouting. The Tuner Pro is designed to use a second knock sensor that you attach to the block yourself. You do not disconnect the stock one. That's bad, very bad
C: http://www.turboxs.com/tunerupdate.htm for the manual. Search is your friend
mick_the_ginge is offline   Reply With Quote
Old 04-07-2006, 02:09 AM   #3
Lost_Pete
Member#: 100570
WHAT HE SAID!!
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 04-07-2006, 07:56 PM   #4
fzturbo
Member#: 43482
thanks a lot mick, i did search but didnt found anything.
I've just tried and works perfectly, but when i try to use the MPS uteclogger from nasioc i dont get the AFR reading, and all i want to use is the Real time logmapper. Do i need to conect them separately to the notebook to get it work?? cause right now i setted wb o2 disabled and no AFR reading.
Thanks indeed
Old 04-09-2006, 09:24 PM   #5
fzturbo
Member#: 43482
anyone knows???
Right now i'm just using the N1 logs from the UTEC, but i want to use the logmapper real time.
I need Sti Pinks or equiv CHEAP! Fuel Pump CHEAP! & 05 manual trans Cobb pro tuner? saab-on-the-cobb Private 'Wanted' Classifieds 0 05-30-2006 11:49 PM
TX: TXS Pro Tuner icantdrive75 Private 'For Sale' Classifieds 7 02-22-2006 06:37 PM
fs: 2004 utec, txs pro tuner Spin4 Private 'For Sale' Classifieds 12 10-05-2005 11:28 AM
since PRO TUNER IS NOW OUT, where are the locations of pro tuners? phamster Engine Management & Tuning 9 06-03-2005 06:03 PM
street tuner and pro tuner question dippi Engine Management & Tuning 0 09-11-2004 12:13 AM
