#1 |
Member#: 65166
TXIC
Vehicle:2008 EVO X |
Can 4 ga. power wire be used as ground wire? That may be a dumb question but im S$$$ scared of electricity and better safe then sorry..
#2 |
Member#: 67062
its the same exact thing, just different color. make sure you wrap both ends with some black electrical tape so that you know its the negative/ground.
#3 |
Member#: 86968
South East
Vehicle:02 WRX / 05 350Z '11 335d |
yeah like ^^he said. its the same, my fosgate wire says on it power/ground wire all over it.
#4 |
Member#: 65166
TXIC
sounds good, im making my own grounding kit I didnt realize it woudl be so cheap...
any suggestions on some good wire terminals? I mean keep in mind its for a grounding kit... |
#5 |
Member#: 86968
South East
any will do, gold is a better conductor as i am sure you know though. once you measure all of the locations you want to run a ground wire to, i would cut the wire to length and have an audio shop crimp on your wire terminals. most individuals dont have the proper tools for crimping such large ring terminals properly.
#6 |
Member#: 65166
TXIC
So basically run one from the battery to metal of car, and then one from the metal of car to lets say the intake manifold, another to the other side of intake manifold, one from that end of intake mani to wall again by intake and from there to one of the bolts by the fender...
Hows that sound? Confusing enough lol... How are these terminals? http://www.cardomain.com/item/STIS4PRG Last edited by Inprogress; 04-07-2006 at 03:08 AM. |
#7 |
Member#: 99289
Those should be fine, but get some extras and get a REAL crimping tool, not one of those combined crimper/stripper.
Like this: ![]() And use heat shrink, that rubber stuff may melt. |
#8 |
Member#: 22035
SCIC
Vehicle:2008 STI White |
You could always solder it
![]() Shane |
#9 |
Member#: 104078
Vehicle:2002 SRP VF43 WRX P&L Jorge Tuned |
i grounded mine by way of underneath the rear seat once, and when i did a different car i used a bolt that is in the jack compartment on the left side, basically you're supposed to rub the paint off so you get a good metal to metal contact, just don't make your ground wire too long just for the sake that you may create a short circuit sometime so find some place near that's easy to access, the 1 ft thing is BS but it's a safety precaution, also running the RCA and power wire on serpeate sides is a myth, i've done it every time, my brother has (he's an ME) and it's just a myth, but i agree with all the above lol, it's the same wire, different covering color lol
easiest places though are usually underneath the carpet or rear seat to ground though! |
#10 | |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! '95 Montego Miata |
#11 |
Member#: 104078
ah ha, i don't read well oh well :P
there's some useless info then for someone haha i suck -1 for me |
#12 |
Member#: 99333
NESIC
Vehicle:2006 2.5i Wagon Black |
OH MY GOD YOU'LL BLOW YOURSELF UP!!!!!!!!!!!!!!
NOOOOOOOOOOOOOOOO! Yeah, its fine, its the same crap. |
#13 |
Member#: 104078
| Thread Tools | |
| Display Modes | |
| What would happen if I switched the power and the ground wires to my amp? | Meta4 | Car Audio, Video & Security | 23 | 09-01-2010 07:07 AM |
| no big power, but GROUNDING WIRES A MUST FOR THE SUBY!!! | meat_WRX | Off-Topic | 86 | 01-24-2006 09:49 AM |
| Wiring... shielding speaker wire from power wire | badkid | Car Audio, Video & Security | 3 | 11-14-2003 06:53 PM |
| will there ever be anything as ground-breaking as Win95 again? | -=C=- | Off-Topic | 37 | 11-06-2003 06:33 PM |
| Fuel Pump Power/Ground Wire? | subenutt | Normally Aspirated Powertrain | 4 | 03-05-2001 02:51 PM |
