Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 04-07-2006, 10:36 AM   #1
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Default cold start AFR
so i have been working on cold starts on my tec
any one have a recomeded target afr for startup
i have been using 12.5to1 from 10-50C then switching to closed loop at 51C
Old 04-07-2006, 01:50 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
That's about what I run. With the Hydra the first 30 seconds are even richer (11-11.5:1) with the post start enrichment. I think I stop adding any enrichment fuel at 70C, but if you car doesn't mind it at 51C, go for it. Currently I idle when warm at 14.5, but may tune up to 14.7 or higher at some point.
Scratching/Scraping sound when cold starting speedracer47 Normally Aspirated Powertrain 14 05-23-2010 04:52 PM
Getting on throttle from idle as well as cold start, causes AFR swings pwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-17-2009 02:04 AM
Rough idle on cold starts, AFR swings lean ogboot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-15-2009 07:08 PM
('93-'01) Cold starting up my Impreza RS 2001 AliasAngel Impreza Forum 17 06-01-2001 09:35 AM
Cold start - revisited Steve00RS General Forum Archive 3 12-18-2000 07:07 PM
