Old 04-07-2006, 12:04 PM   #1
origonalp
Member#: 86255
2006 STI
Subaru Stars Questions on Rough idle on 06 STI with the following mods...
All,
I've got an 06 STI. 3000+ miles, did her first oil change. All seems nice.
I've got the following mods to the vehicle (have since 1000 miles).
Side note I've done a proper break in. The rough idle acts as follows. The engine after being warm (run for 20+ mins), will initially idle at around 500-750 rpms, smoothly, then on a cycle (no timers) it will dip and the car will just slighlty shift side to side, while the RPMS drop, and then come back up.
List
APS 3" TBE catless
5Zigen Header
APS CAI 65mm
UTEC
Note that I havent taken the UTEC tobe tuned yet. But shouldnt matter at idle the stock eCU is still running things there. Running with throttle the car runs beautifully (could be better w/ tune but still very nice).
Don't need an answer specificaly, more than anything I want some ideas on ways to trouble shoot.
Thanks in advance!
origonalp is offline   Reply With Quote
Old 04-07-2006, 12:17 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
Bets on your intake giving you issues at idle, as you said the stock ECU is running things and it is getting funky MAP readings from your APS causing idle hunting...once you are into the tune (UTEC) it is running properly (from what you are saying).
tora is offline   Reply With Quote
Old 04-07-2006, 12:26 PM   #3
origonalp
Member#: 86255
2006 STI
Subaru Banner
Correct. The UTEC is in control at that point.
That makes sense.
I believe I can tell the UTEC to adjust that setting at idle, I could be wrong.
Any ideas on ways to smooth that out?
It's not horrible but I'm definately curious how to clean it up a bit.
Thanks for the reply!
Old 04-07-2006, 12:34 PM   #4
StiChiara
Member#: 107541
2006 WRX STI
I'm not sure, but i might be something common to all 06 STI's.
My 06 STI has 4000 miles on it and no mods, yet i also sometimes get the same problem.
It usually lasts for about a few seconds, while waiting at a red light, the rpm will drop below the 500 rpm mark, and the car shakes a little, but then everything goes back to normal.
I was going to go in and have them check it, but it stopped doing it about 1500 miles ago.
StiChiara is offline   Reply With Quote
Rough Idling on 2009 STi :( debbieandherrexy Engine Management & Tuning 0 04-06-2010 07:13 AM
06 sti with lots of mods evo 3ater Private Vehicle 'For Sale' Classifieds 25 06-23-2008 03:43 AM
THE REAL STORY OF WHAT HAPPENED LAST NIGHT TO MY BUDDYS 06 STi with the Pink wheels get sydwayz Mid West Subaru Owners Club Forum -- MWSOC 52 03-14-2007 06:28 PM
Pics of 06 sti with the wrx wings or other types of wings Shabib67 Member's Car Gallery 3 02-23-2006 11:21 PM
What's the HP/torque with the following mods... Geoff Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-04-2004 06:25 PM
