Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 04-07-2006, 03:45 PM   #1
bbren
Member#: 111972
97 Legacy Outback
Exclamation 97 OB Auto...AWD not working!
I've got a 97 Outback, 2.5l, auto trans. The AWD has stopped working. When driving in the rain if take off quickly the front tires will just spin, I can keep them spinning for a long time, 10 sec / 40 ft, the AWD just never seems to kick in. Anyone out there had a similar problem, know where to look to corect it?
Note of interest: my local subaru technician just replaced the duty solenoid C and the clutch pack, previously I was experiancing excesseve drive-line binding while making sharp turns at slow speeds. The AWD problem surfaced immediately after this repair. I wonder if there is an electrical connector for the solenoid that may have not been fully reconnected?
bbren is offline   Reply With Quote
Old 04-07-2006, 04:14 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
What do your tires look like? I would check that first.
If the tires are not the issue, make sure that the FWD fuse has not been installed.
If that's not the issue, take it back and have them take a look at it.
RexyGirl is offline   Reply With Quote
Old 04-07-2006, 06:39 PM   #3
bbren
Member#: 111972
97 Legacy Outback
Tires are good, matching set of four, plenty of tread. I also checked the fuse. It seems like the new solenoid is not functioning for some reason.
Old 04-08-2006, 12:27 AM   #4
97obw
Member#: 109426
97 OUTBACK
mud brown
so the AWD is expected to wear off on the auto's because of the clutch pack wearing out?
97obw is offline   Reply With Quote
Old 04-08-2006, 08:17 AM   #5
RexyGirl
Member#: 63616
with mods :)
Was the fuse in or out?
Old 04-08-2006, 04:52 PM   #6
bbren
Member#: 111972
97 Legacy Outback
As I understand it, solenoid "C" cotrols the clutch pack that sends power to the rear wheels (automatic trans.). When the solenoid goes bad, the AWD system gets locked in a 50/50 split, when you take sharp, low speed turns on hard surfaces it puts a huge load on this clutch pack and evetually wears the clutch plates out. If you don't catch it in time it can do more even more damage to the sysytem.
Old 04-08-2006, 04:56 PM   #7
bbren
Member#: 111972
97 Legacy Outback
The fuse has allways been out. In this model, you insert a fuse under the hood if you want to put the system in front wheel drive only. It's intended to be used during an emergency, such as towing the car a short distance when two of the wheels would be on the ground.
Old 04-08-2006, 09:18 PM   #8
RexyGirl
Member#: 63616
with mods :)
I know that....
Some people think the fuse has to be IN to be in AWD, just making sure you weren't one of them.
Old 04-08-2006, 10:58 PM   #9
bbren
Member#: 111972
97 Legacy Outback
I'm wondering if the tech that worked on it was "one of them"!
Old 04-15-2006, 01:55 AM   #10
97obw
Member#: 109426
97 OUTBACK
mud brown
pull your e-brake at around 20mph with slight gas applied, if your tires immediatley lock up, your not getting power to the rear
97 passanger tail light not work pacotaco Electrical & Lighting 2 02-09-2009 12:31 PM
AWD not working Jutboy Normally Aspirated Powertrain 6 12-24-2008 10:37 PM
Help: AWD not working BakedPotato Legacy Forum 17 09-25-2007 08:42 PM
AWD not working! Help! MekoNY Legacy Forum 14 12-13-2005 01:07 PM
91 Legacy AWD not working - help kooskia Legacy Forum 10 12-08-2005 02:12 AM
