Old 04-08-2006, 04:26 PM   #1
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Impreza WRX How bad is NOS for the stock "03" Pistions & Rods
I have an 03 WRX with cat-free exhaust, VF-34, pinks / fuel pump upgrade, adjustable fuel pressure regulator, larger intercooler, CRY-02 spray system, ECUTek reflash, heavy duty clutch & lightweight flywheel, EGT, Oil pressure gauges, etc, etc..
The engine internals however, are essentially "STOCK". The car has never had any indicaion of running lean or detonating, however I've heard the stock piston's & rod's are a weak part of this breed.
I'm contemplating getting a NOS system hooked up. However I am in no hurry to blow up the damn thing. If properly installed, is this just an explosion waiting to happen or can the stock engine parts handle it???? Are the 03's strong enough to haldle it in the long haul or do I expect to be rebuilding the top end in 10k miles.?
Sorry for the NOOBEE question but I'm just contemplating cost vs performance here and could really use some sound input.
skimobile is offline   Reply With Quote
Old 04-08-2006, 07:51 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
properly tuned/setup you'll be fine...
testes1010 is offline   Reply With Quote
Old 04-09-2006, 03:56 PM   #3
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
If your talking about a 50 shot then that should be fine but You better make sure your fuel injectors support, Why not alky injection it's not hard on internals like nos would be .
boost4life is offline   Reply With Quote
Old 04-10-2006, 01:13 PM   #4
Sharky NRK
Member#: 29549
2003 WRX
205 pistons are cast and will not take nitrous assited knock, so be safe and careful, have adequate fuel and tune, then a reasonable shot will be fine
Sharky NRK is offline   Reply With Quote
How bad is running two different Tire Brands (front & back) BeBop86 Newbies & FAQs 22 07-28-2008 04:34 PM
How bad does NOS shorten the life of our fragile pistons? skimobile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-08-2006 08:04 PM
Curious; how bad is lowering just the front of the car? DANACoOp Brakes, Steering & Suspension 1 09-01-2004 12:10 AM
How bad is it for the Engine ??? morgie Legacy Forum 6 11-19-2002 09:52 PM
How bad is bottoming out the suspension? IMPREZAmike Brakes, Steering & Suspension 10 05-03-2001 05:12 PM
