Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-08-2006, 08:02 PM   #1
njskatchmo
Member#: 94618
2002 Bugeye
Default Running Rich w/ Misfires
Here are the logs,
1399 000 -10.6 00 ECU. 14.7 00000
1415 000 -10.6 00 ECU. 14.9 00000
1397 000 -10.6 00 ECU. 14.5 00000
1387 000 -10.6 00 ECU. 14.3 00000
1390 000 -10.6 00 ECU. 14.5 00000
1397 000 -10.6 00 ECU. 14.7 00000
1381 000 -10.6 00 ECU. 14.8 00000
1358 000 -10.6 00 ECU. 15.1 00000
1352 000 -10.6 00 ECU. 14.9 00000
1367 000 -10.6 00 ECU. 15.4 00000
1405 000 -10.4 00 ECU. 15.1 00000
1411 000 -10.4 00 ECU. 14.8 00000
1396 000 -10.4 00 ECU. 14.7 00000
1411 000 -10.4 00 ECU. 14.6 00000
1410 000 -10.6 00 ECU. 14.7 00000
1429 000 -10.6 00 ECU. 14.6 00000
1427 000 -10.6 00 ECU. 14.3 00000
1430 000 -10.6 00 ECU. 14.0 00000
1404 000 -10.8 00 ECU. 14.3 00000
1403 000 -10.8 00 ECU. 14.6 00000
1397 000 -10.8 00 ECU. 14.8 00000
1379 000 -10.8 00 ECU. 14.8 00000
1380 000 -11.0 00 ECU. 14.8 00000
1325 000 -11.0 00 ECU. 14.9 00000
1348 000 -11.0 00 ECU. 15.0 00000
1348 000 -10.8 00 ECU. 15.1 00000
1373 000 -10.6 00 ECU. 15.2 00000
1377 000 -10.6 00 ECU. 15.2 00000
1383 000 -10.4 00 ECU. 15.2 00000
1386 000 -10.4 00 ECU. 15.6 00000
1423 000 -10.2 00 ECU. 14.9 00000
1433 000 -10.2 00 ECU. 14.2 00000
1438 000 -10.4 00 ECU. 13.8 00000
1432 000 -10.4 00 ECU. 13.9 00000
1406 000 -10.6 00 ECU. 14.3 00000
1392 000 -10.6 00 ECU. 14.3 00000
1373 000 -10.6 00 ECU. 14.8 00000
1365 000 -10.6 00 ECU. 12.5 00000
1356 000 -10.6 00 ECU. 14.8 00000
1361 000 -10.6 00 ECU. 14.8 00000
1360 000 -10.6 00 ECU. 14.9 00000
1342 000 -10.6 00 ECU. 15.0 00000
1379 000 -10.4 00 ECU. 15.3 00000
1372 000 -10.4 00 ECU. 15.4 00000
1409 000 -10.4 00 ECU. 15.4 00000
1397 000 -10.4 00 ECU. 14.6 00000
1392 000 -10.4 00 ECU. 14.5 00000
1388 000 -10.4 00 ECU. 14.2 00000
1404 000 -10.4 00 ECU. 14.3 00000
1170 000 -10.4 00 ECU. 17.0 00000
0937 000 -10.0 00 ECU. 16.8 00000
0706 000 -9.4 00 ECU. 21.1 00000
0507 000 -8.1 00 ECU. rich 00000
0399 000 -6.5 00 ECU. rich 00000
0000 000 -4.7 00 ECU. rich 00000
0000 000 -3.0 00 ECU. rich 00000
0000 000 -1.8 00 ECU. rich 00000
0000 000 -1.0 00 ECU. rich 00000
UUUUUHOME MENUTURBOXS UTEC (Version 5.0) (c) 2005 Key : Function------------------------------------------------------------e or E : Edit Maps (Caps lock must be OFF)d or D : Dashboardl or L : Logger1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format)r or R : Replay Last 25 Seconds of Data (Logger 1) UUUUUHOME MENUTURBOXS UTEC (Version 5.0) (c) 2005 Key : Function------------------------------------------------------------e or E : Edit Maps (Caps lock must be OFF)d or D : Dashboardl or L : Logger1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format)r or R : Replay Last 25 Seconds of Data (Logger 1)LOGGERTURBOXS UTEC (Version 5.0) (c) 2005To log this data use the 'CAPTURE' function in HyperTerminal(tm) <CTRL-x> : Exit to Main <p> : Pause <s> : Start <space> : Toggle   RPM TPS MAP MLP MOD AFR KNOCK  % psia IGN COUNT 1367 000 -7.7 00 ECU. 14.7 00000
1377 000 -7.7 00 ECU. 14.7 00000
1371 000 -7.7 00 ECU. 14.7 00000
1363 000 -7.7 00 ECU. 14.7 00000
1383 000 -7.7 00 ECU. 14.6 00000
1393 000 -7.7 00 ECU. 14.6 00000
1402 000 -7.9 00 ECU. 14.6 00000
1436 000 -7.9 00 ECU. 14.6 00000
1403 000 -7.9 00 ECU. 14.5 00000
1417 000 -8.1 00 ECU. 14.5 00000
1408 000 -8.1 00 ECU. 14.4 00000
1443 000 -8.1 00 ECU. 14.4 00000
1418 000 -8.1 00 ECU. 14.3 00000
1397 000 -8.3 00 ECU. 14.2 00000
1398 000 -8.3 00 ECU. 14.2 00000
1405 000 -8.3 00 ECU. 14.1 00000
1433 000 -8.3 00 ECU. 14.1 00000
1443 000 -8.3 00 ECU. 14.0 00000
1408 000 -8.5 00 ECU. 13.9 00000
1418 000 -8.5 00 ECU. 13.8 00000
1425 000 -8.5 00 ECU. 13.8 00000
1428 000 -8.5 00 ECU. 13.6 00000
1417 000 -8.7 00 ECU. 13.5 00000
1456 000 -8.7 00 ECU. 13.4 00000
1395 000 -8.7 00 ECU. 13.3 00000
1437 000 -8.9 00 ECU. 13.1 00000
1432 000 -8.9 00 ECU. 13.1 00000
1446 000 -9.1 00 ECU. 12.9 00000
1448 000 -9.1 00 ECU. 12.8 00000
1425 000 -9.1 00 ECU. 12.6 00000
1460 000 -9.1 00 ECU. 12.5 00000
1433 000 -9.1 00 ECU. 12.5 00000
1472 000 -9.4 00 ECU. 12.2 00000
1440 000 -9.4 00 ECU. 12.1 00000
1446 000 -9.4 00 ECU. rich 00000
1459 000 -9.6 00 ECU. rich 00000
1436 000 -9.6 00 ECU. rich 00000
1463 000 -9.8 00 ECU. rich 00000
1443 000 -9.8 00 ECU. rich 00000
1466 000 -9.8 00 ECU. rich 00000
1443 000 -10.0 00 ECU. rich 00000
1434 000 -10.0 00 ECU. rich 00000
1460 000 -10.0 00 ECU. rich 00000
1478 000 -10.2 00 ECU. rich 00000
1500 000 -10.2 00 ECU. rich 00000
1486 000 -10.4 00 ECU. rich 00000
1490 000 -10.4 00 ECU. rich 00000
1486 000 -10.6 00 ECU. rich 00000
1483 000 -10.8 00 ECU. rich 00000
1475 000 -10.8 00 ECU. rich 00000
1460 000 -10.8 00 ECU. rich 00000
1454 000 -11.0 00 ECU. rich 00000
1445 000 -11.2 00 ECU. rich 00000
1443 000 -11.2 00 ECU. rich 00000
1432 000 -11.4 00 ECU. rich 00000
1417 000 -11.4 00 ECU. rich 00000
1415 000 -11.4 00 ECU. rich 00000
1396 000 -11.4 00 ECU. rich 00000
1372 000 -11.4 00 ECU. rich 00000
1361 000 -11.4 00 ECU. rich 00000
1340 000 -11.4 00 ECU. rich 00000
1274 000 -11.6 00 ECU. rich 00000
this is the setup
small 16g pnp ,Injen FMIC, Pink injectors, Fuel Pump, Turbo Inlet hose, APS ram intake, Catless uppipe and Helix down pipe w/ HKS ti muffler,
The 16g and injectors were installed together recently since then its been running rich and misfiring. I put the stg 4 mapss and parameters to try and get it semi-drivable so we could drive it to the tuning shop.
any ideas about what to do?
njskatchmo is offline   Reply With Quote
Old 04-08-2006, 11:43 PM   #2
gpatmac
Member#: 18446
2002 WRX wagon
psm
do you have any #1 logs?
gpatmac is online now   Reply With Quote
Old 04-09-2006, 02:52 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Do you have a scanner to monitor your fuel trims?
cdvma is offline   Reply With Quote
Old 04-09-2006, 06:35 AM   #4
njskatchmo
Member#: 94618
2002 Bugeye
what are #1 logs? no i have no scanner.
Old 04-09-2006, 11:41 AM   #5
gpatmac
Member#: 18446
2002 WRX wagon
psm
when you're on the first screen of the utec, the one with edit maps, dashboard.... just hit 1 and it will start logging.
Old 04-09-2006, 01:51 PM   #6
ejsportcom
Member#: 88905
you should just drive it to where ever your getting the car tuned, then change the plugs when you get there..... either that or get a wb o2 and pull some fuel on your own.... either way, if you misfired quite a bit, then its probably time to change the plugs. also AAA is always an option, if you have plus then its free....
ejsportcom is offline   Reply With Quote
Old 04-09-2006, 09:55 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You don't need #1 logs to see where the issue is, I don't know why people insist on it all the time. Its not like the other ones aren't readable and this one has TPS, RPM, load point and AFR. If he is running rich and misfiring because of it its due to either the injector scaling or the 0% tune.
Old 04-09-2006, 10:26 PM   #8
gpatmac
Member#: 18446
2002 WRX wagon
psm
Don't have to yell at me. I don't know what I'm looking at on anything other than #1. That's all.
Old 04-10-2006, 02:19 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I didn't yell, sorry if it came off that way. Have a look two lines after the "goop" from the home screen. You will see the headings printed out above the data just like it does like the #1.
Please help! Misfire,running rich, wont idle... Bug_i_Sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 06-14-2010 08:37 PM
Halp, running pig rich and misfires (with no codes) FaisalT Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-31-2008 01:28 PM
Running rich- very rich Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 19 04-12-2003 09:11 PM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 11:53 PM
MY00 Running Rich (C.E. Light) w/ Cobb Intake, Stromung Exhaust Swivel1000 Normally Aspirated Powertrain 8 03-11-2001 04:21 PM
