Old 10-03-2001, 02:29 AM   #1
Dre2932
Member#: 1211
93 Impreza L
Midnight BLK w/ GLD flake
Question Turbo Charging my 1.8L
Like everyone here know's by now, I have a 93 Impreza L and I'm wondering if I could find a turbo charger for it? Plus do anyone know who makes one and where I can check out a website on it?
Thanks,
Andre
Dre2932 is offline   Reply With Quote
Old 10-03-2001, 02:59 AM   #2
PERRIN
NASIOC Manufacturer
Member#: 6776
i could get you a WRX engine and tranny(240hp model) and a Haltech ECU, exhaust, and you're off!! This would be much more durable, this way. The tranny you have is pretty much garbage if you are going to turbo it. They are way smaller that the WRX or 2.5rs tranny.
PERRIN is offline   Reply With Quote
Old 10-03-2001, 05:46 AM   #3
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Try a used stock WRX turbo and stick it on there with some custom work...
Old 10-03-2001, 07:45 AM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
You're pretty much going to have to custom fabricate everything for it.
Keiho is offline   Reply With Quote
Old 10-03-2001, 12:43 PM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
You could use any kit from a 2.5RS. Just about everything is the same, so a Minnam or some other kit would bolt on.
Another option is to make your own kit. And maybe check out the following link...
http://www.uniquemotorsports.com/subachad/mods.htm
So about the transmission, Why is it weak?? My 93 Has been turbo'd for about 40,000 miles now and the only problem I have is the syncro going into 2nd. I did that before the turbo.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-03-2001, 01:04 PM   #6
PERRIN
NASIOC Manufacturer
Member#: 6776
The 1.8 tranny is weak compared to the 2.5 trannys. Being smaller, the gears and shafts can't be as big as a 2.5 tranny. My 2.5 tranny has a 4 puck clutch, with instant engage, and have had no problem. That's no problem running 20psi on the street.
I wouldn't say the 1.8 wouldn't last a long time, because that depends on how you drive it and how much HP you have.
If your budget can't support the 2.5 tranny or something else, then i would stick with the 1.8 tranny till it breaks.
Old 10-03-2001, 01:11 PM   #7
subachad
Member#: 8488
Teal
Jeff,
Did you get the 4 puck from Paul? I bought one from him too when I was in Tigard, but it didn't fit because I actually have the FWD clutch on my car. Subaru even gave me the wrong parts when I replaced the clutch.
There is one other factor to consider. My little clutch will slip before the tranny breaks, so as long as I stick to a weak clutch it's more likely to give than the tranny. It's a stinky mess if I drag race, but I'd rather replace a $300 clutch than a transmission.
How many people have grenaded thier trannies with the stock clutch? Not many. The way I see it, when accellerating hard something has to give. With AWD, it's not usually the tires. With a weak clutch, it will slip. With a really "good" clutch, the transmission and drive lines are the next in line to get the abuse.
Are you really running 20 PSI??? I want to see this, can I check your car out when I'm there for Thanksgiving?
Chad
93 1.8T
P.S. I'll be moving back to Portland, most likely Sherwood in Feb.
Old 10-04-2001, 01:24 AM   #8
Dre2932
Member#: 1211
93 Impreza L
Thumbs up
Thanks for all the help guys and gals. Chad I'll be checking out your site too.
Old 10-04-2001, 03:05 AM   #9
PERRIN
NASIOC Manufacturer
Member#: 6776
No i got my clutch from Lee Shadbolt, he lives a couple of miles from Paul. But it is the same clutch.
your point is good about the weak clutch slipping to provide the "dampening" to the tranny. But as i experienced, the stock clutch began to slip very soon.
It was like a new car when i got the 4 puck clutch.
Let me know when you get to tigard again.
Old 10-04-2001, 03:48 AM   #10
subachad
Member#: 8488
Teal
I think know where Lee lives, or where he did live anyway. Off Tigard street and that road that goes to the school and has a "Jacked up" intersection that finally got a light.
I think when it comes time to do the clutch again, I'll go with a stock pressure plate, 4 puck, and lightened flywheel.
Chad
93 1.8T
Old 10-04-2001, 03:52 AM   #11
PERRIN
NASIOC Manufacturer
Member#: 6776
Yes he does live there. See you in a few months.
Old 10-04-2001, 01:37 PM   #12
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default tranny size
Jeff -
Help me out here. Are you sure the 1.8 tranny is smaller that the 2.5? Or even the WRX, Legacy, etc.? I don't know, thats why I am asking, but when I installed an EJ20 into my 93, the tranny from the 1.8 would have fit exactly the same as the Legacy AWD I did use. If it had been AWD instead of FWD, I would have used the original. Maybe the internals are sized differently? Or perhaps more advanced metalergy for same size?
But I don't see an actual size difference. Am I wrong?
For my money, I would replace the 1.8. Dollar cost for a used EJ20 already turbo built will be comparable to putting a turbo on the 1.8. BTW, if you need a spare 1.8, I have one in excellant condition for sale!
MM
MZM is offline   Reply With Quote
Old 10-04-2001, 09:29 PM   #13
PERRIN
NASIOC Manufacturer
Member#: 6776
I too have a spare 1.8. My 1.8 4wd tranny is smaller than the 2.5 tranny i put in the car, but they all bolt in the same.
All EJ motors and EJ trannys bolt to each other, so yes your would have fit.
Old 10-05-2001, 10:05 AM   #14
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
My '96 1.8L tranny is holding up fine w/the EJ22T motor I put in. I have an ACT pressure plate from a friends '98 and a WRX/RS clutch disk. My 1-2 syncro is going, but that was started before the motor went in. As long as you don't abuse your car the tranny will last you a long while.
Scoobyslack1 is offline   Reply With Quote
Old 10-05-2001, 11:43 AM   #15
PERRIN
NASIOC Manufacturer
Member#: 6776
But abuse can be fun!
Old 10-05-2001, 11:59 AM   #16
Scoobyslack1
Member#: 2780
junk yards rule!
Thumbs down
yeah, but changing and/or paying for a tranny is not
Old 10-05-2001, 12:27 PM   #17
PERRIN
NASIOC Manufacturer
Member#: 6776
i was just kidding.
Old 10-05-2001, 01:02 PM   #18
subachad
Member#: 8488
Teal
Scoobyslack, What flywheel do you have? I have the smaller FWD one even though my car is AWD. Appearantly I have one of the first AWD imprezas or something...
Chad
93 1.8T
Old 10-05-2001, 06:10 PM   #19
DoinkMobb
Member#: 3787
2008 Gay
Car
How much would a custom fab turbo kit for a 1.8L cost vs. throwing in an old turbo Legacy engine? I may be selling my old crappy car soon and hope to use the money to mess around with my Impreza.
DoinkMobb is offline   Reply With Quote
Old 10-08-2001, 10:52 PM   #20
Dre2932
Member#: 1211
93 Impreza L
Hey Chad,
I can't get into your website. Is it down or something?
Old 10-09-2001, 12:43 AM   #21
andyC
Member#: 1607
2002 Silver
double you are ecks wagon
so about how much would this whole operation of adding a turbo and parts cost?
andyC is offline   Reply With Quote
Old 10-09-2001, 02:00 AM   #22
subachad
Member#: 8488
Teal
Dre... and everyone else who happens to be trying. The server was moved to a different location and my friend can't get it up until Friday of this week...
Chad
93 1.8T
Old 10-09-2001, 02:08 AM   #23
PERRIN
NASIOC Manufacturer
Member#: 6776
for a custom kit ask chad, for the engine it will be around $3000 but that gives you engine, Haltech, exhaust.
Old 10-09-2001, 02:44 AM   #24
andyC
Member#: 1607
2002 Silver
okay, chad: how much $$??
Old 10-09-2001, 12:39 PM   #25
subachad
Member#: 8488
Teal
How Much???
Here's a quick run down of what I have and the cost. Remember this is to run 5psi, if you want more then fuel management becomes even more important.
Turbo off XT: $45
Machine work on turbo to get the outlet to 2": $60
Gasket set from Carparts.com for the turbo: $25
oil feed line from autocaresubaru.com: $30
oil return line: $50 (used some earls #12 fittings and tapped into my pan)
Complete exhaust: $400 @mieneke (it sucked and I just redid it)
I Used my Weapon-R for the intake going into the turbo
Intake tube between turbo and throttle body: initially this was about $200, but now that I can weld I can do it for about $50
OK, that was the initial kit. Now I have a new 2" up pipe I made and a 2.5" downpipe that will go into a 3" exhuast and cat with a Borla muffler.
>Replaced the stock wastegate with a Deltagate since the stock one sets boost too high at 10psi.
>I pick up my SFC which is REALLY needed today
>I now have an intercooler off a SAAB (about $80 on Ebay)
>I still need a Walbro fuel pump and Cartech RRFPR to get some more power out of it
>I bought a hood scoop that I'm still waiting on shipping
I keep updating my site with more info, the only problem is the site is down for the week. On another note I'm now making custom up and down pipes. PM me for more details.
Chad
93 1.8T
Some questions on adding a turbo to the 1.8l Yulri Normally Aspirated with bolt-on Forced Induction Powertrain 9 02-15-2010 07:42 PM
turbo charging my 98 legacy and want stoping power GotTurbo Legacy Forum 12 06-29-2004 07:23 PM
turbo on the 1.8l lsedan ? cindergarden Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-12-2002 10:26 AM
Turbo Charge My 2.5 RS redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 8 02-27-2002 02:04 AM
Turbo charge my 2.5RS or... RallyBlue2.5RS Mid Atlantic Impreza Club -- MAIC 22 07-27-2001 10:02 AM
