Old 04-09-2006, 10:20 PM   #1
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
Default Boost gauge on the AcessPort
How's this thing work out? Does it save max psi? Or in that case, does it even read in PSI?
If it doesn't save the max boost # i'd have to hold it or have my passenger hold it and read the max psi to see if I'm hitting target boost or not. (yes i know I should buy a gauge..someone give me $300 so i can get the defi boost and the required control unit!)
AlxSti is offline   Reply With Quote
Old 04-09-2006, 11:08 PM   #2
intence
Member#: 58477
. Member #1 of
the witty MS Crew
it reads in PSI but does not save. if you want to save your runs then get a program like ecuexplorer.
intence is offline   Reply With Quote
Old 04-09-2006, 11:11 PM   #3
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
i dont really need it saved.. its just gonna be hard to mount that thing somewhere visable while im boosting.
Old 04-09-2006, 11:56 PM   #4
Payback
Member#: 41328
2003 WRX Sedan
SOLD - 2/07
Too bad they don't make a small, round, analog device that can be mounted in some sort of "pod" in the car so you can read your boost easily and safely. j/k
Anyway, I had the same problem. Trying to read it while driving isn't easy. If it is just to make sure you are reaching target boost, you can have someone ride shotgun and read it to you while driving. I've seen pictures here of people's AP mounting. If you do a search you might get some good ideas.
Good luck.
Payback is offline   Reply With Quote
Old 04-10-2006, 12:25 AM   #5
USCTrojan4JC
Member#: 51876
2004 Impreza WRX Sdn
WR Blue Pearl
On 2002-2004 WRXs, you can mount it in the upper cup holder right below the A/C vent!
God bless,
Loren
USCTrojan4JC is offline   Reply With Quote
Old 04-10-2006, 06:11 PM   #6
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
thanks guys.. just wanna make sure im not creeping etheir, ya know!?
What should the factory installed boost gauge on an STi read? SithSolo1 Newbies & FAQs 3 01-03-2005 02:54 PM
Factory XT boost gauge on the right or left? SCutchins Forester Forum 6 04-28-2004 03:56 PM
Cheapest Place to order the OEM Boost Gauge and the OEM Gauge panel Schleppy Interior & Exterior Modification 4 03-04-2002 10:36 AM
Question: Which Vac line for Boost Gauge on MY00 RS? [email protected] Normally Aspirated with bolt-on Forced Induction Powertrain 1 07-03-2001 04:00 PM
buzzing from Subaru Boost gauge on boost? Cosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-29-2001 11:47 AM
