Old 04-10-2006, 03:38 AM   #1
dj_booduh
Member#: 70861
2005 Scoobie WRX
Default FMIC and AP?
I am just wondering something. Someone told me that running an FMIC with the AP would make me run very lean and could possibly cause detonation. Is there any truth to this? My current mods are...
TXS Turboback with 2 1/2" magnaflow exhaust (catless)
TXS FMIC
AEM short ram intake
TXS RFL BOV (recirc)
I have an AP that I was about to put in, but the guy that helped me install it said that it might not be a good idea because the AP will make me run VERY lean? I just wanted to know if there was any weight to his warning?
dj_booduh is offline   Reply With Quote
Old 04-10-2006, 09:29 AM   #2
intence
Member#: 58477
. Member #1 of
the witty MS Crew
listen to him. you could get it protuned though.
intence is offline   Reply With Quote
Old 04-10-2006, 11:31 AM   #3
hornyturbo
Member#: 108618
2010 10 RX350, 04 A4
12 IS350, 08 STI
wouldnt he be better off with the ap then running that setup without it?
hornyturbo is offline   Reply With Quote
Old 04-10-2006, 12:42 PM   #4
dj_booduh
Member#: 70861
2005 Scoobie WRX
I was thinking the exact same thing as hornyturbo. Wouldn't I be better off running the AP so at least I have SOME sort of EM as opposed to no EM at all.
Old 04-25-2006, 12:57 AM   #5
dj_booduh
Member#: 70861
2005 Scoobie WRX
Any Guru's out there to help out?
Old 04-25-2006, 12:59 AM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
If anything, the Cobb maps on the AP are pretty rich, not lean.
mcowger is offline   Reply With Quote
Old 04-25-2006, 01:59 AM   #7
TeknoWhore
Member#: 37904
2008 Subaru STi
SSK
PROTUNE!
TeknoWhore is offline   Reply With Quote
Old 04-25-2006, 02:06 AM   #8
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Protune or your car will DIAF... But seriously you will have SERIOUS problems without a protune running a FMIC.
-Jason
jay25RS is offline   Reply With Quote
Old 04-25-2006, 07:22 AM   #9
TecnoWRX
Member#: 81474
2008 VW
R32
I am running pretty lean with a TXS FMIC. it is something like 14:1. This has made me rethink to getting the Ebay TMIC and a Cobb or UTEC.
My Dyno #'s with FMIC no EM
TecnoWRX is offline   Reply With Quote
Old 04-25-2006, 12:46 PM   #10
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
It's hard to say without datalogging the car.
Most people without tuning experience barely know the difference between lean and rich.
Your definelty not going to be re-asured by Cobb.
I'd make some datalogs and have a tuner evaluate your map's accuracy.
parker/slc/gc8fan is offline   Reply With Quote
Old 04-26-2006, 11:27 AM   #11
DawgMode
Member#: 113459
i have been running the ap and stock tmic for about 2 months now and i just put on a fmic last weekend and tha car still runs perfect on the stg 2 flash.
DawgMode is offline   Reply With Quote
Old 04-26-2006, 11:33 AM   #12
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
I ran a short ram intake, Spearco TMIC, xover pipe and uppipe on my stage 2 WRX, when i went to get it protuned we did a baseline run and the car ran waaay lean and was overboosting.
I am currently running a VF39 and i would never run a OTS map unless i used their exact mods!!!!!!
markuswelby is offline   Reply With Quote
Old 04-26-2006, 12:50 PM   #13
-Kevlar-
Member#: 82378
lets see some logs....
-Kevlar- is offline   Reply With Quote
Old 04-26-2006, 08:12 PM   #14
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
i ran a stage 2 on mine after i installed my turbo xs FMIC and i had a 10.5:1 AFR. its wierd. everything ive done and i never leaned out just got richer. i did the street tuner and it took about 20 minutes to get 11.5:1 on the first try and according to my LM-1 data log, it was steady straight through.
05 STi with Cobb Street Tuner
Cobb AP
B and B Down Pipe
Megan Cat back Exhaust
Invidia Upipe and Headers
IHI VF 22 Turbo
Turbo XS Short Ram Intake
Turbo XS FMIC
ACT 6-Puck Clutch
ACT Pressure Plate
ACT Streetlight Flywheel
Sportcomp Boost, Airfuel, and Oil Pressure Gauges
Greddy Turbo Timer
VIS Carbon Fiber Trunk
Sparco Siena Seats
Sparco 6-Point Harnesses
Sparco Harness Bar
02 WRX Carpeting and Back Seat
Innovative LM-1 Air Fuel Unit
Bosh O2 Sensor
JDM Front and Rear Strut Tower Bars
JDM SPEC C Type RA Badges
04 STi Emblems
JDM STi Center Caps
Perrin 816CC Injectors (On Order)
Perrin Fuel Rails (In My Closet)
Walboro Fuel Pump (Next To The Rails)
Hyperflow Oil Catch Can (In Said Mentioned Closet)
rek888v2 is offline   Reply With Quote
Old 04-30-2006, 02:04 AM   #15
T_ReX78
Member#: 57177
02 WRX
MidNight Black Pearl
I am currently running a Stage 2 map and datalogged a third gear pull let me know what you guys think with the following mods:
Helix upipe
Helix downpipe
Greddy Evo catback
Greddy Airnix
APS Type R fmic
TurboXS RFL bov
http://www.yourfilelink.com/get.php?fid=93187
T_ReX78 is offline   Reply With Quote
Old 04-30-2006, 12:14 PM   #16
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
That's only partially true.
Yes, they run quite rich on the topend (> 11, tapering down to 10 afr starting at around 5k rpm).
The problem is at the onset of boost. My car would hit 15psi of boost at 3200rpm, but my AFR at the same engine speed was still 12.0. IMHO, that is far too lean, and explains why my car would be VERY picky about the quality of fuel it would run -- and the IAM would definitely show this by varying from 7-8 on crappy brands, up to 15-16 when using BP/Amoco fuel.
wall of tvs is offline   Reply With Quote
Konig Theory Wheels, EJ25 Block, FMIC, TD04, AP Turbo Inlet, DP & Stock Parts... pr4life750 Tri-State Area Private Classifieds 22 02-26-2008 10:14 PM
FS/FT: WRB Front Bumper cut for FMIC and SSAC FMIC/ FP 16g and DW Injectors Gfunk720 NESIC Private Classifieds 14 10-24-2007 02:37 PM
FS:CA: FMIC, And 2 Week Old Cobb AP WhiTe_07_WRx Engine/Power/Exhaust 1 02-09-2007 05:11 PM
FMIC with AP Matth3w AccessPort 7 09-29-2006 01:36 PM
